SOURCE: lid lock stays on and constant beep on excellence washing machine
I am having the same issue and hope someone can post a solution. I have found a work around though. Mine does it when it is on a 'Regular' wash cycle, I found that if I put it on Permanent Press it works fine.
SOURCE: Lid lock light beeping continuously and flashing
It appears your timer/main controller/CCU has failed in this instance.
For replacement parts - head on over to PartSelect.com or RepairClinic.com and enter in your full model number for a full parts listing.
I recommend both sites because ...
FixYa has no affiliation with either site - I have been using and recommending them for years - trouble free.
PartSelect has a great schematic database for locating the part on your unit and great "testimonials" for each part that often times includes HOW-TO information.
RepairClinic has pictures of each part they sell and also a great how-to and troubleshooting for basic repairs.
If your unit has never been serviced - there should still be an original service manual enclosed in plastic taped to the inside of the shell.
In the service manual are Error codes, maintenance procedures, and troubleshooting steps you can follow.
Anything too complicated or beyond your scope should be handled by a professional.
If you think you want to tackle the repair - and have gotten stuck on a step - reply to your question and I will be glad to help you out.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question!!!!
SOURCE: Simpson ezi sensor 8.0 kg won't spin lid lock flashes and alarms
Did you fix this, Leila Bell?
Also having this problem with Simpson EZI sensor 802 model washing machine. This type of error message (flashing lid lock plus beeping) is not in the manual. I suspected blockage (a sock?) so checked connection of drain hose with bottom of machine, but nothing there. May try taking the back off and looking into the pump.
Better if someone has an easier approach.
SOURCE: hi i have a simpson
We had the same problem. Electrolux repairman came last week and replaced the lid switch parts with a new designed part. Told me the original part was subject to recall because of a problem with the design, was getting wet and stopping the maching operating correctly, and causing shocks. Ring Electrolux, should be covered under the two year warranty (but because the fault was there when the machine was bought, shouldn't matter even if warranty period had expired)
