Question about Whirlpool Duet GHW9150P Front Load Washer
Duet Washer Leaking Water Into The Tub When Not In Use
Hi -
Mine does this too! Were you able to get your washer fixed? If so, how?
Thanks,
Mary
  • 4 more comments
  • alanz01 Oct 08, 2008
    Same here. Water slowly fills up the tub when the washer is off.
  • Wingnut1111 Oct 09, 2008
    Mine leaks as well, Any help?
  • Peter2Pam Oct 22, 2008
    I have the same problem. Mine is about 2.5 yrs old and we have to drain it before each use. Anyone have a solution on how to fix........ without having to call a repairman?
  • kerstar Oct 23, 2008
    Water leaks from main inlet tube into washer while not in use, model GHW9100L
  • libbymundy Oct 24, 2008
    I have the same problem, the other day I left the door open and went to work and the washer was off and when I came home their was water all over the floor. Then a few days later the washer was closed and it did the same thing. If I don't get my clothes out right away they smell. I thought for a while that the water was not spinning out correctly but now I think the water is coming back in the tub. Can someone please help me find a solution to the problem
  • Anonymous Nov 13, 2008
    My Kenmore 110 also is dripping water into the tub when the machine is off. Would love a tip on how to fix this.
    Problem Solver:
  • 8 Answers
Replace the water inlet valve, it not closing all the way.
Posted on Feb 22, 2010
Maytag washer leaking water into tub when idle
A intake water valve is leaking and will need replacing.
Dec 30, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Water is leaking from the bottom of the door while in the wash and or rinse cycle
  • Check the pump & all of the hoses first.
  • If you see water leaking from the bottom of the tub this could indicate a bad tub seal.
Jan 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Leaking water from dispenser
Hi, the problem here is going to be a blockage between the dispenser and the tub. Take the top off the washer (3 screws along the back) then once the lid is off you will see the large pipe between the dispenser and the tub. Take this pipe off and check for a blockage (most likely a sock) Once the blockage has been cleared you will be all fixed :) If you have any other questions please feel free to comment. Mike
Dec 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer tub slowly (over several days) gets water inside
yes this is more than likely a leaking inlet valve, to confirm turn of water at wall valves
Sep 16, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water is pooling in the wash tub even after the cycle has completed. the next day, the tub is full of water and leaking out the front
Your Mixing Valve (water valve) is not shutting properly.
Replace it to solve your problem.
Thanks for using FixYa!!
Jul 29, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Water leaking from under washer
Hi
You'll need to open the machine and check for the leaks in the hose connected to the drain pump. Also check if the clamp connecting the drain filter and hose is tight. Also check these things for leaks---
Main tub seal - The main tub seal is located between the transmission and the outer tub. It's the primary water seal in the outer tub for the transmission-shaft entry point. If this seal leaks, you can see the leak by opening up the machine's main access panel while the machine is full of water with a small amount of detergent in it. The leak appears at the underside of the outer tub, at or near the center. This seal is difficult to replace.
Pump - If the pump leaks, you can probably spot the leak when the tub is full of water. The pump has two or more black rubber or plastic hoses attached to it and usually has a drive belt that spins the pump. If the pump is leaking, you'll need to replace it.
Please do rate this solution as FixYa if found useful and revert for further assistance.
Thanks
Rylee
Apr 21, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer is leaking water when it starts from the soap dispenser
the fill tube is located at the top tub cover and more than likey the tube is defective or the discharge anti spash guard is cracked. nbcrca:)
Apr 11, 2009 | Washing Machines
Water leaking on the floor while filling
Open the back of the washer. Start the fill cycle and observe where the water is leaking from. You are not going to get a full view of the entire tub by only opening the lower front access.
Feb 23, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Leaking Duet Washer
hi there,
looks like you may have a pinched hose or the fitting is overtightened or not tightened enough. turn off the water supply and check the water inlet hose. you can usually tell if the fittings are stripped or not tight enough.
Sep 29, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Duet leaking
leaking water inlet valve very easy solution!!!chat with me online and ill step you through it save up to $65 (my in-home rate in florida is $75!!!!!!!)
Sep 16, 2007 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
90 people viewed this question
Dan Webster
Dan Webster
Sal De
