I have to replace my Whirlpool Duet HT washing machine. I have decided to purchase the Whirlpool Duet WFW95HEXW and was wondering if my existing Whirlpool pedestal (LAB2700MQ1) is compatible with the new machine.
SOURCE: whirlpool duet washer sport ht - error codes
FYI: The pump cleanout is located on the front of the machine, bottom right corner. There are only three screws holding the bottom cover on. It is easy to get to if you prop it up a few inches off the ground. Just thought this would be helpful as I just did this as of 5 min ago. Should take 10 min. or less.
Posted on Jul 28, 2008
F21 According to Whirlpool:
"This error code indicates that drain times are longer than expected.
Is the drain hose kinked or clogged?
Make sure the drain hose is not kinked or clogged. Straighten the hose for adequate water flow. Remove any blockage from the drain hose, drainpipe or utility sink. Use the U-shaped drain hose form on the drain hose, and secure the drain hose. See the Installation Instructions for details; find them by entering your model number in the search tool below."
Also
"Are you using HE High Efficiency detergent?
Use only HE High Efficiency detergent. Using non-HE detergent, or more than the manufacturer's recommended amount of detergent, can cause excessive suds. The excess suds will slow or stop the removal of water from the washer.
Concentrated detergents labeled 2x and higher will require a small amount of detergent based on load size. Always follow the manufacturer's recommendations."
Regards,
Eric P.
Posted on Oct 18, 2008
duby1990
  • 370 Answers
SOURCE: How long should a normal wash cycle take on the whirlpool duet?
One hour and 10 minutes is normal for your washer. All front load washers take a long time. They wash a lot better than top loaders. So to answer your question.. yes its normal.
Posted on Nov 19, 2008
  • 12 Answers
SOURCE: washer vibrates and walks across the floor
Theres a few things you can do to stop it from walking.
but the best way i know is to use washer anchors.
Whirlpool part# 155P3 $22.95
Im going to assume that you have eaither the wfw8300 or wfw8400
the main differences is the suspention system in them. the 8300 uses a 5 point system that work but really you should only use the washer on solid flooring like concrete. the 8400 uses a 6 point with better shocks.
if you have this washer on a main floor with basment underneith it you might want to check the floor. grab a glass of water when it starts to shake and walk and put it on the floor, if the water is jumping then the floor is the problem.
eaither way the anchor kit i have listed above will stop your issues with it moving and walking.
Posted on Feb 07, 2009
catriver
  • 878 Answers
SOURCE: Maytag Neptune Washing Machine electronic malfunction.
barry, sounds more like the keypad is stuck or shorted. You can try to do a membrane test by putting it into the service mode. Have the unit on, press and hold the delicates and heavy soil key together until it shows 00 on the display. Then press the wrinkle free key. This will let you test every key on the keypad. You can toggle them off and on and see if they are responding. If they are not responding then you can assume that the keypad is your problem. At repairclinic.com you can order the part you need and if it doesn't solve the problem they will take it back no questions asked. A lot of people are not too fond of these washers because of the many issues they had with them. You would have to weigh the price of the part versus a new washer. The keypad is not hard to install. Just a ribbon that plugs into the board. You may want to try to clean the end of the ribbon with a eraser and see if that fixes the problem. Make sure the unit is unplugged before going in there.
Posted on Mar 07, 2009
Whirlpool duet ht will not agitate or spin
Front load washers don't "agitate". Did you mean it doesn't tumble during the wash cycle? I need more information. Complete model # and a more detailed description of the issue.
Mar 16, 2014 | Whirlpool Duet Sport HT WFW8400TE Washer
Error code F06 and E01
Here is what the F06 code stands for
Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down.
If a failure occurs during high-speed spin the door will be unlocked after 3 minutes.
Potential Causes
• Check wire harness connections between the Drive Motor/Tachometer and the
Motor ControlUnit (MCU), and between the MCU and the Central Control Unit
(CCU)
• Check the Drive Motor
• Check the MCU
• Check the Wire Harness
Dec 14, 2013 | Whirlpool Duet Steam WFW95HEXW
How long is the warranty on the whirlpool 8400te duet
For one year from the date of purchase, when this major appliance is operated and maintained according to instructions attached to or
furnished with the product, Whirlpool Corporation or Whirlpool Canada LP (hereafter "Whirlpool") will pay for Factory Specified Parts
and repair labor to correct defects in materials or workmanship. Service must be provided by a Whirlpool designated service company.
This limited warranty applies only when the major appliance is used in the country in which it was purchased
One year...
Jun 16, 2011 | Whirlpool Duet Sport HT WFW8400TE Washer
Duet GHW9150P Front Load Washer: My whirlpool duet ht washer shows an L20 error mes...
L20 is not a valid error code.
Unplug for 40 minutes and re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
We have a duet sport ht, it seems to leaving greasy/oily spots on our clothes? any idea/cause? thanks
Be sure to use the quantity of wash powder recommended on the packet and not less. This will help keep the clothes AND machine clean.
Mar 23, 2010 | Whirlpool Duet Sport HT WFW8400TE Washer
I have a whirlpool duet ht. Model# ghw9250ml1.
replce the board located on the top right side of the chasis
Feb 11, 2010 | Washing Machines
WHIRLPOOL DUET HT FRONT LOADING WASHER
This is a strange problem. I work on these all day, and never have a problem getting these boards. Might want to try and calling local part houses for this part.
Oct 18, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Whirlpool Duet HT
its a door lock error a door lock error occurs if the door cannot be locked it will try to lock 6 times before displaying the error
Mar 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
96 people viewed this question
Top Washing Machines Experts
