Question about Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher
Dishwasher is going on 3.5 yrs old, it worked well for the 1st year but for the last year & half it has been leaving gritty residue on all the dishes. To the point, dishes are being hand washed to remove residue. Switch from a power to a liquid soap and use jet dry as a rinsing agent. Inside the tub, on the racks and the rubber gasket around the soap dispenser are all coated with white powdery residue. Water temp is good and all else seems to be working fine. Is this a filter issue? Manual does not provide instructions on how to clean the filter. Appreciate your input.
  • Kenmore Master
  • 43,501 Answers
The scum, film and white residueproblems have started since the reductionof phosphates in dishwasher detergents.
Here is a tip that will help you to solve the problem of films, residue, and scum in your dishwasher.
DishwasherResidue and Film on Dishes
heatman101//
Posted on Mar 29, 2011
My maytag W10199645 is leaving gritty residue on my mugs & glasses. how can i troubleshoot this?
Try using a dishwasher cleaner. You can get it at any supermarket that sells dishwasher soap.
Nov 06, 2014 | Maytag Dishwashers
My LG LDF7920ST dishwasher is 2 years old. Suddenly its leaving heavy gritty white residue inside cups. This isn't just a film. The first time, I thought maybe white house paint had gotten into the cup...
heatman101
Jul 06, 2011 | LG 24 in. LDS 5811ST Stainless Steel...
Glasses and dishes have a gritty residue...dishwasher is just a year old and this problem has been happening for as long as we've had it. What should i do...This is gross
heatman101
Jun 02, 2011 | Bosch SHU9915UC Dishwasher
I Have a candy dishwasher about 4 years old after washing it seems to leave a gritty chalky residue I have tried added salt, rinse aid and putting a diswasher cleaning solution through it nothing seems to...
The problem is most likely that there is still water residue at the bottom of your machine. If the machine is not fully drained it picks up some of the residue and sprays that onto the dishes during the final rinse, leaving an unhealthy and unsightly film on everything.
Remove the bottom strainers and make sure that there is nothing obstructing the outlet pipe and the pump. If possible back flush through the outlet pipe and try draining the machine again before using it again.
Feb 13, 2011 | Candy CD623X Free-standing Dishwasher
My jenn - air dishwasher (installed 3 yrs ago) is leaving residue in the dishes & glasses. Is there a pump or filter that needs to be cleaned and can I reasonably do that myself?
Check your heating element..
A bad heating element causes many problems in dishwashers…
Dishwasher Problems The Heating Element not Working
Dishwasher Maintenance
heatman101
Asker's Testimonial " explanation very clear. will give it a go and see how simple it was. thanks Ronnie " - ronnieshomes
Sep 05, 2010 | Dishwashers
Dishwasher leaves behind gritty residue i am not sure of what to try...
We have a Kitchen Aid dishwasher, 10 years old, never any problems until 2 weeks ago, then we started noticing a gritty subtance on the dishes and glassware. We're on well service, psi 40-60. water hardness is 6 grains. small trace of sulphur, and we have a Mermaid sulphur system, then a complete house carbon filter, and finally a Culligan water softner. Checked everything, Water temp. at kitchen was 120, all cycles on dishwasher were operating. Called in repair service, he says something is breaking down in the dishwasher, best to buy a new one. That'll be $150.00. Thank you very much. Tried the white vinegar, no change. Next bought 2 bottles of Dishwaser Magic. Slight improvement. Next bought 1 bottle of Finish Dishwasher Cleaner. Bingo. The thing is like brand new. even the trays slide in/out much easier. None of the dishsoaps contain phosphate, which is what helps disolve the minerals in the water. I'm not sure what the gritty stuff is, maybe the buildup over time, and it just keeps getting redistributed through the wash and rinse cycles, and finally baked on in the dry cycle. According to a tech with many years repairing appliances, the majority of their calls are for dishwasher poor performance, all because they removed the one compound that's been cleaning our dishes for years, Phosphate. We've always used Cascade gel soap. best on the market today, Finish Quantum. We tried it and dishes look terrific. It's a small tablet that fits in the soap dispenser. All Mfg's. today recommend that you run a dishwasher cleaner once a year, Experienced tech recommends every 3 months maybe more if you're on hard water. Good luck.
Mar 25, 2010 | Maytag Dishwashers
We get a gritty / sandy residue. what can I do?
The cause may not be your dishwasher.
Especially hard water may leave the residue. If you don't have that problem when you hand-wash, then check your pipes. Homes more than 40 years old may have galvanized pipes that eventually rust on the inside. The grit could be grains of rust from the pipes. If you do have galvanized pipes (rather than copper) then you may need to replace them. You could put in a filter as a temporary work-around, but that will eventually clog with the gritty material.
Feb 16, 2010 | Bosch Dishwashers
JDB2100AWS - Leaving a gritty residue in the tub
May need to look into a dishwasher cleaner. I perfer Glisten but there are many more out there.
Jun 08, 2009 | Jenn-Air 24 in. JDB2100AW Dishwasher
Cloudy residue on dishes after washing dishwasher is only a year and a half old what can i do ?
you need to check out this new product designed especially for this problem. it is guaranteed to work! it filters the water going into your dishwasher removing the hard minerals that cause these spots. get it at www.dishwasherfilter.com
May 10, 2009 | Dishwashers
Bosch Excell Dishwasher
drain pump is running all time. cause is a leak. remove bottom front panel and mop out water or can also tilt at 45deg and water shud run out. machine shud then run but you then hav to find leak
Mar 04, 2007 | Bosch 24 in. SHU66C05 Stainless Steel...
Kenmore 24 in. 17482 / 17484 / 17489 Built-in Dishwasher Logo
589 people viewed this question
Top Kenmore Dishwashers Experts
Ken Johnston
Ken Johnston
Level 1 Expert
vince
D. E. Hev
Are you a Kenmore Dishwasher Expert? Answer questions, earn points and help others
