Question about Logitech Labtech Verse 524 Microphone
I dropped my microphone and it wont work - Logitech Labtech Verse 524 Microphone
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 116 Answers
Maybe its broken try to disarm carefully the parts of the mic
and check if all the cable stills connected
Posted on Mar 22, 2011
My chrystaleye webcam wont work with skype
SKYPE VIDEO PROBLEM
To test if the Logitech QuickCam is functioning, check the USB cable; make sure it is connected properly. Then click on Start - All Program - Logitech - Logitech QuickCam and see if you can get the camera to capture your image/video. If this works then the fault is with the Skype configuration. Sometimes the WEBcam settings drop off and the WEBcam need to be selected again. Open Skype - Tools - Options - Video Settings and select the Logitech QuickCam Also check the Audio Settings for the Microphone THEN click on Save. Avoid connecting the WEBcam to an USB hub. SKYPE MICROPHONE PROBLEM
If the person cannot hear you then, either your microphone driver not installed or not working OR the microphone is not configured in Skype.
To test your microphone then click on Start - All Programs - Accessories - Entertainment - Sound recorder. Then record your voice and then play it back. If this is OK then the microphone need to be configured in Skype.
To configure the microphone - Open Skype - Tools - Options - Audio Settings for the Microphone THEN click on Save.
Sep 03, 2012 | Acer Aspire 5500 5570-2609 Laptop
Hp microphone wont work on skype
open skype go to tools from the drop down list select options scroll to audio settings
you can make a free test call before you try to make a call
make sure the microphone is using the same as your computers audio
you can make a free test call if you cant get the microphone to work you can select learn about setting up your audio equipment also
click start control panel sounds and audio devices audio and also voice its the same make sure that you have the right default microphone selected you should be able scroll to video settings to make sure you have the right settings
open skype go to tools options scroll to audio settings or video settings on the right you will see webcam setting you can change the settings from there click apply after changing any settings also
you can see the webcam there you can even take a snapsot also make sure your settings are correct for a video call
also
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick also
select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or
select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope it helps
May 27, 2012 | HEWLETT-PACKARD Pavilion dv2600 Laptop AC...
The microphone wont work on my laptop
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or
also
click start control panel sounds and audio devices then select voice then select volume from the microphone you can increase the volume or you can test your hardware in XP in
W 7 click start control panel hardware and sound manage audio devices recording right click on microphone you can configure speech recognition
or
you might have to boost
hope this helps you
Mar 22, 2012 | Toshiba Computers & Internet
Im trying to setup my orb gp1 headset for my pc but the only thing that work is the sound the micro phone wont work am i the cables in the wrong places can you send me a diagram and describe what i have to...
the headset should have 2 plugs one green one red they usually plug into the back of the computer with the speaker plug in the middle you could alternate these also make sure the microphone settings are correct
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it or select audio from the microphone drop down list make sure you have the right one selected and in the volume box make sure the microphone box has a tick in it or select the voice tab and make sure that you have the right media selected also select volume make sure the box for microphone has a tick in it
hope this helps
Jun 09, 2011 | Computers & Internet
Have a beta 57a it wont work ? nothing
I'm assuming that you have tried the obvious stuff like using a different cable and a different amplifier?
The Shure beta 57a is a very robust and reliable dynamic microphone and there is very little to go wrong with it apart from
  1. A wire broken off inside
  2. A broken capsule - can be caused by dropping it
You can inspect for broken wires by very gently unscrewing the microphone head and peering inside - however the wiring is quite short so be careful not to pull any wires off in the process.
A broken capsule can be replaced - contact your local dealer for parts.
Feb 09, 2011 | Shure SM87 Professional Microphone
Dropped nokia e90; now others can't hear me
The microphone is located under the last set of keys . you can open it up and see if when u dropped it a connection came loose but my guess when u dropped it you damaged the mic itself therefore the only way to fix it would to be to get a new phone
May 29, 2009 | Nokia E90 Smartphone
I dropped my e90 exactly onto the corner where the microphone resides. I disassembled and have found that the microphone is broken.(!) Now I am looking for a spare microphone to mount. But I am not sure if it is to be soldered or simply put on its place..
Mar 23, 2009 | Nokia E90 Smartphone
I need to know how to get my webcam mic to work!
Normal 0 Go to Control Panel and Click on Sounds, Click on Audio, then Click on the Microphone. Then Click on the drop down and select Camera Microphone.
Click OK and it should work.
Hope this helps. Bud
Feb 16, 2009 | Microsoft LifeCam VX-3000 Web Camera
Dont Know How To Turn On Microphone on webcam
Dec 25, 2008 | Logitech QuickCam Communicate Deluxe...
Not able to speak with mic while using messengers
when in yahoo messenger go to actions then call setup, this will set your microphone up within messenger and let you use it. You may need to try all three types of microphone on the drop down list in messenger to set yours up correctly.
Nov 18, 2007 | Compaq Presario Notebook
Logitech Labtech Verse 524 Microphone Logo
54 people viewed this question
Top Logitech Audio Players & Recorders Experts
Michial Gueffroy
William Covington
Level 1 Expert
Are you a Logitech Audio Player and Recorder Expert? Answer questions, earn points and help others
