Question about Dell Dimension 2300 PC Desktop
Dell Dimensions 2300 hard drive replacement
Will this work?
Maxtor 300GB Ultra16 PATA Internal Hard Drive Designed for power users, video editors and multi-media PC users who need the ultimate in performance.
  • 300GB
  • Parallel ATA (PATA)
  • 659 Answers
That one looks like you would need a Serial ATA-enabled motherboard or adapter card find one that is pata/ide
Posted on Aug 03, 2008
Dell Optiplex 260 IDE hard drive dead. Would like to replace it with external Sun Brite hard drive. Windows 2000 installation stopped because it couldn't gain access to ext. drive. Says that special...
Windows 2000 cannot access USB drives for installation.
You need to replace the dead drive with a new IDE or PATA drive. That machine will not accept an SATA drive.
Feb 03, 2011 | Dell OptiPlex GX260 PC Desktop
I want to get a new internal hard drive but I,m not sure of the hard drive interface type. The specs say Serial ATA 300. The drives I am looking at say SATA?
Dear friend. in fact Serial ATA is SATA.
and i checked your Hard drive out.
your hard drive uses SATA technology to connect with the PC.
please vote
Jan 15, 2011 | Dell OptiPlex GX260 PC Desktop
I have a dell dimension 4500, I need a compatible internal hard drive for it. Which one to buy?
Check the manufacturer's web-site:
http://support.dell.com/support/downloads/driverslist.aspx?c=us&cs=2684&l=en&s=pub&os=WW1&osl=en&SystemID=DIM_PNT_P4_4500&catid=-1&impid=-1
for your (7-year-old) model, and you'll find a list of PATA (Parallel-ATA) disk-drives recommended by Dell, up to 120GB. Any PATA disk-drive that you can buy, up to 500GB, should also work.
Aug 09, 2010 | Dell Dimension 4500 PC Desktop
Can i replace internal hard drive with 320 scorpio in dell 6400
as long as its the correct physical size in terms of dimensions and its the correct connector type ie SATA, PATA then it should be fine.
If its IDE you will need to check the jumpers are set correctly
Apr 14, 2009 | Computers & Internet
Adding second hard internal hard drive
Sure it will, put the jumper setting on the hdd to cable select mode.
Sep 01, 2008 | Dell Dimension 2300 PC Desktop
Dell Dimensions 2300 hard drive replcement
Seagate Barracuda 7200.10 750GB Hard Drive
goes for about 180 bucks and it a IDE PATA Drive I do belive since your dimensions 2300 motherboard 3T237 is only IDE and does not have SATA
your motherboard can also handle 1 gig of ram so if you havent maxed out your motherboard yet I would highly suggest it. Ram for it wont cost you much either.
I would add the newer drive as a secoundary drive since I am sure that your operating system is pre loaded.
or you can also add external drives to your system as well for more storage as well and they are starting to come down in price as well. you have options it all depends what ya wanna do with it.
Aug 03, 2008 | Dell Dimension 2300 PC Desktop
Maxtor harddrive jumper setting
If you only have a single hard drive (or multiple hard drives for that matter), you should leave the jumper setting as "Cable Select" or CS.
See if this PDF matches your hard drive:
http://www.seagate.com/staticfiles/maxtor/en_us/documentation/quick_specs/dm10_ata_quickspecs.pdf
Apr 22, 2008 | Compaq Presario SR1800NX Desktop PC
Hard drive installation
You should be able to install that drive. The biggest variable is if it is a SATA or PATA drive. This model was built for SATA drives, but I think you may be able to get a PATA drive to work with the right adapters.
For the step by stem directions see the link below. It will take you right to the Dell support page. Refer to the "Adding a Second Hard Drive" section.
https://support.dell.com/support/edocs/systems/dim5150/en/sm/parts1.htm#wp1366406
Feb 21, 2008 | Dell Dimension E510 Dual Core 2.8 Ghz...
Dell Dimension 2300 PC Desktop Logo
128 people viewed this question
Brian Sullivan
Brian Sullivan
mukhtar21 shaikh
mukhtar21 shaikh
