Question about Texas Instruments TI-86 Calculator
When i turned on my calculator and began typing numbers, the numbers appeared really light on the screen and could barely be seen. what is wrong with my calculator? can it be water damage?
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Adjust the screen contrast. Turn the calculator on. Press and release the 2nd key, then press and hold the up-arrow key until the numbers darken. If you go too far, repeat the process with the 2nd and down-arrow keys.
Posted on Mar 22, 2011
I can barely see the numbers on the screen--changed batteries but it doesn't make any difference
LCD screen is separating. It happens over time to all LCDs. It is shot. Should be able to lightly press on it while you are calculating and see the numbers fine.
Apr 18, 2016 | Office Equipment & Supplies
TI-81 when turned on, screen is totally black, can perform calculations & barely see results on screen. is this a battery problem?
Adjust the screen contrast. Turn the calculator on. Press and release the 2nd key. Press and hold the down-arrow key to lighten the screen. If you go too far, use the 2nd and up-arrow keys to darken it.
Aug 08, 2012 | Texas Instruments TI-81 Calculator
Screen began flashing then went dark
If your laptop appears to boot up and the hard disk LEDflashes, then the problem is probably a back light fault. This can be a faultyinverter or a faulty CCFL lamp. Please click on this link and follow myinstructions to identify the fault and possible fix :- http://www.fixya.com/support/r3598095-faulty_laptop_lcd_screen
Jun 16, 2012 | Computers & Internet
My son's TI-83 calculator screen is very dark. The calculator appears to be working but I can barely read the screen. Any suggestions?
Try adjusting the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the down-arrow key to darken the text. If you go too far, use the 2ND and up-arrow keys to lighten the text.
Feb 09, 2011 | Texas Instruments TI-83 Plus Calculator
The words and numbers that show up on the screen are really hard to make out. They are really light and barely noticable.
Adjust the screen contrast. Turn the calculator on. Press and release the 2ND key, then press and hold the up-arrow key for a couple of seconds to darken the screen. If you go too far, repeat the process using the 2ND and down-arrow keys.
Addition of significant numbers
Press SHIFT DISP then a digit for the number of digits desired after the decimal point.
Feb 10, 2009 | HP 10bII Calculator
Blank vertical lines are appearing on the screen.
Hi, and sorry for my english !
Maybe the LCD driver voltage is wrong or noisy. I had the same problem: some vertical lines (not constant), pulsing contrast after powerup, pixel crosstalk, sometimes no screen
Solution: Try to replace the LCD power negative voltage buffer capacitor.
In my hardware version it is in the middle of the two T6B07 column driver IC (U3&U4) on the right side. Colored black, electrolytic type and the Value is : 10uF/25V. Chage it to around the same type.
There is enought space, so you can use a small sized non smd type capacitor. Be care of the polarity.
I hope it will help... ;)
Greetings from Hungary!
Jan 04, 2008 | Texas Instruments Voyage 200 Calculator
Display is so light that I can barely read it, I've replaced the batteries and no change
Have you attempted darkening the display on the calculator through the function keys? Push "2nd" and then push "up" a few times. After resetting the calculator, this setting will always revert to a lower, unreadable setting. I'm sure TI knows about this, but they probably arent too inclined to fix it.
Jun 04, 2007 | Texas Instruments TI-83 Plus Calculator
Texas Instruments TI-86 Calculator Logo
55 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
