Question about Brother GX-6750 Typewriter
Type the number but no function - Brother GX-6750 Typewriter
  • 86 Answers
If you hold down the ALT button and then hit a number key to access the function printed above the number and it just prints the number, then the ALT button is not working, usually because the contact is dirty. you can remove the keyboard and clean the switches. to do this - first remove the two screws behind the platen, in the holes. then pull apart the case slightly, and gently, where the cord storage area is on the back of the machine. while doing this locate the latches on each side of the machine (inside) in the middle of the opening, on the top of the case, and pry out on the bottom of the latch, carefully, with a long screwdriver until it releases and the case starts to come apart. do this on each side. now the case will be fastened only at the bottom of the keyboard. to unfasten the four latches here you have to push down on the case, right under the keys, and pull outwards at the same time. if you don't do this properly some or all of the latches will break. now that you have the case off and set aside, you can see the latches that hold the keyboard down. pry these outward while pulling up on the keyboard, untill the keyboard comes loose. now you have to pull the keyboard cables loose from the cirduit board. the flat cable at the left just pulls straight out, to remove the other cables, first pull up on the white part of the connection the cable are plugged into, then the cables will come right off. to dissasemble the keyboard, just pry the plastic latches at one side of the metal plate on the back of the keyboard, and work your way across, untill you get the plate off, pull the rubber pad off and clean the contacts with microfiber cloth or lint free cloth and alcohol then assemble parts in the oposit order. or take it to a repair shop or get a new one.
Posted on Mar 25, 2011
Keys won't type letters or numbers. can't type in password to unlock e-machine 1603
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator.
Mar 29, 2013 | E-Machines eMachines Desktop PC
My MS Excel vlookup function ASCII type table contains both upper case and lower case letters, characters like ( and % or *, and numbers. It seems to return the numerical equivalent of upper case letters...
Correct a #N/A error blueup_clv.gifShow All bluedrop_clv.gifHide All This error occurs when a value is not available to a function or formula.
  1. Optionally, click the cell that displays the error, click the button that appears ooui1_za06043871.gif, and then click Show Calculation Steps if it appears.
  2. Review the following possible causes and solutions. blueup_clv.gifMissing data, and #N/A or NA() has been entered in its place
    Replace #N/A with new data.
    Note You can enter #N/A in those cells where data is not yet available. Formulas that refer to those cells will then return #N/A instead of attempting to calculate a value.
    blueup_clv.gifGiving an inappropriate value for the lookup_value argument in the HLOOKUP, LOOKUP, MATCH, or VLOOKUP worksheet function
    Make sure that the lookup_value argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) is the correct type of value — for example, a value or a cell reference, but not a range reference. blueup_clv.gifUsing the VLOOKUP, HLOOKUP, or MATCH worksheet function to locate a value in an unsorted table
    By default, functions that look up information in tables must be sorted in ascending order. However, the VLOOKUP and HLOOKUP worksheet functions contain a range_lookup argument (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) that instructs the function to find an exact match even if the table is not sorted. To find an exact match, set the range_lookup argument to FALSE. The MATCH worksheet function contains a match_type argument that specifies the order the list must be sorted in to find a match. If the function cannot find a match, try changing the match_type argument. To find an exact match, set the match_type argument to 0.
    blueup_clv.gifUsing an argument in an array formula that is not the same number of rows or columns as the range that contains the array formula
    If the array formula (array formula: A formula that performs multiple calculations on one or more sets of values, and then returns either a single result or multiple results. Array formulas are enclosed between braces { } and are entered by pressing CTRL+SHIFT+ENTER.) has been entered into multiple cells, make sure that the ranges referenced by the formula have the same number of rows and columns, or enter the array formula into fewer cells. For example, if the array formula has been entered into a range 15 rows high (C1:C15) and the formula refers to a range 10 rows high (A1:A10), the range C11:C15 will display #N/A. To correct this error, enter the formula into a smaller range (for example, C1:C10), or change the range to which the formula refers to the same number of rows (for example, A1:A15).
    blueup_clv.gifOmitting one or more required arguments from a built-in or custom worksheet function
    Enter all arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function.
    blueup_clv.gifUsing a custom worksheet function that is not available
    Make sure that the workbook that contains the worksheet function is open and the function is working properly.
    blueup_clv.gifRunning a macro that enters a function that returns #N/A
    Make sure that the arguments (argument: The values that a function uses to perform operations or calculations. The type of argument a function uses is specific to the function. Common arguments that are used within functions include numbers, text, cell references, and names.) in the function are correct and in the correct position.
Oct 31, 2008 | Computers & Internet
My laptop want let me type letters in to log onto my laptop but i can type numbers
NUMBER LOCK
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock. b>
Nov 03, 2012 | Dell Computers & Internet
What's your problem?when i type o its come 6 then i type L it become 3 ...
NUMBER LOCK
Oct 06, 2012 | Samsung N150 Series Netbook
Cant find the number lock key on my acer 6920 laptop
I think for your laptop the number lock key is a second function... Try holding down the function (Fn) key and pressing the F11 key, hopefully that will turn your number lock on/off.
Nov 23, 2008 | Acer Aspire 5100 Notebook
Numbers locked in on Dell Laptop
Look for the Num Lock key written in blue, press the FN key and press it. It will turn off the number keypad.
Jun 20, 2008 | Dell Latitude D600 Notebook
Brother GX-6750 Typewriter Logo
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
