Question about Envision Computers & Internet
I have an Envision 7100 Monitor. Before going on vacation 2 weeks ago it was operating perfectly when connected to my Hewlett Packard PC. However, on my return the monitor screen remains blank (dark) even although the amber light is on. When I disconnect the monitor from the PC the screen lights up and changes color in a rotating basis. My computere is useless without a monitor display. What is the problem? Thanks.
  • 11,361 Answers
The power supply may have become unstable due to bad DC filter caps, the power supply is always running 24/7 even when the power switch is OFF.
Look for bad cpas with domed tops.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on:
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm/
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you.
Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Posted on Mar 22, 2011
Monitor won't change from power save mode and keyboard won't light up. Checked connections and it's connected. Was working 2 days before.
If both symptoms started at the same time, I would suspect your motherboard has gone bad. Have you tried the monitor and keyboard on a different computer?
Jul 07, 2014 | HEWLETT-PACKARD Computers & Internet
Monitor, mouse and keyboard suddenly stopped working.
There could be several issues. 1) if they are wireless the connection may need to be reestablished. Also, check the power source for all of the items, possibly the electrical cord came out of the receptical.
Dec 10, 2013 | HEWLETT-PACKARD Hewlett Packard Pavilion...
Dell HP Pavilion screen scrambled
Either your monitor died or your video card/chip died. Test your tower with a different monitor or test your monitor with a different tower.
Aug 25, 2012 | HEWLETT-PACKARD Hewlett Packard HP...
Connect 2nd monitor to small form factor dc5800
Hello.
You have 2 options to connect an additional monitor to your desktop:
1. install a low profile video card that has multiple video outputs
2. purchase a USB to VGA/DVI device to allow a 2nd monitor to be connected.
Your model PC does not have a DisplayPort on it (newer PC's have this and this provides another monitor connection). So you will need to add hardware to the PC so you can connect the 2nd monitor.
Because you have the "Small Form Factor" model, standard height video cards will not fit in it. You would need to get the shorter model video card - typically labeled "low profile".
The other option is to purchase a USB to VGA or USB to DVI adapter that would allow you to connect the second monitor to your PC. The only thing to watch for when getting this type of adapter is to make sure your current Operating System is supported by the adapter. Many adapters that work on Windows XP will not work with Windows 7 or 8.
Mar 07, 2012 | HEWLETT-PACKARD Compaq DC5800 Small Form...
Can HP Compaq nc6320 monitor work on the nc6230 laptop
you will need to connect the monitor to your laptop to create an extended desktop usually the monitor connection is on the side of a laptop
click start control panel display change display settings adjust resolution this may vary depending on your operating system you should a no 1 and a no 2 with detect and identify keep an eye on the screen when you select the number tabs this may vary depending on your operating system when you select the no 2 tab this should be the extended desktop always click apply after making any changes or you might have to
click start control panel administration tools computer management device manager scroll to monitors right click select scan for hardware changes
hope this helps
Jun 26, 2011 | HEWLETT-PACKARD Hewlett Packard 413671-001...
I have a HP s5660f for 1 month now, last week the computer dint start up, the monitor is black and the hd led dint blink. I think that the problem is the motherboard, since the computer turn in but nothing...
My computer has been out of commission since 3 months after I bought it, HP does not stand by it's warranty or it's product. TERRIBLE, TERRIBLE, TERRIBLE customer service!
Mar 30, 2011 | HEWLETT-PACKARD Hewlett Packard Pavilion...
My desktop pc just beeps and the monitor does not do anything
Welcome to FixYa
Dear User,
First Re-seat your RAM ..check all cables connected properly inside CPU...Also let me know how much beep you heard .It is to provide a better solution..
Thanks for Connecting FixYa...
Dec 05, 2010 | HEWLETT-PACKARD Hewlett Packard Compaq...
Have a hewitt packard computer, want to add on envision monitor 7100s The system is not accepting monitor. what do I do?
To reinerate,do you have the driver for it? I am sure that  the old monitor was made by HP for your HP computer.
Go to the Envision website and download the LCD driver and install same.    Link provided below:
http://envisiondisplay.com/support.asp?EPage=support&SMenu=driver
Mar 23, 2009 | MPC Computers Envision EN 7100s 17 in....
My Envision 7100 Stop Working
These are all some component failure problem in the monitor circuits. This may have been caused by faulty components or overheating of the components causing intermittent or permanent failure of some components in the circuits.This causes the feedback circuits to sense incorrect voltages or currents in the circuits and turn on the protection circuit. It may also cause total failure of the power supply circuit and a loss of power to the monitor. These units should be returned to dealers for servicing. Hope this helps you .
Jan 09, 2009 | Envision EN-7100e 17" Flat Panel LCD...
Computers & Internet Logo
80 people viewed this question
Top Envision Computers & Internet Experts
Steve
Martin Murray
Dimitar Todorov
Are you an Envision Computer and Internet Expert? Answer questions, earn points and help others
