I have dishnet with two TVs connected. The main one works fine no issues. The issue with the TV in the bedroom is that the remote control does not work well. The distance to the base is just a little too far. I am able to go to the receiver and the remote works fine. How to solve the distance problem and make the remote control work? I called Dishnet several times. They sent an attenuator - still does not work.
  • 8,457 Answers
Tries put somthings under the receiver box unit make it higher for a better signal ranges to receive the remote infer red signal to the box.
Posted on Mar 22, 2011
Purchased used last night. Working fine until I tried to hook the Xbox up then screen went black sound went out. Blue light indicates TVs on. Menu or input no longer displays on this TV y is that?
Hi. It could be one of a few parts
I.e main board you say the TV stays on I.e standby light stays on OK.
if so try shining a torch into the screen while the TVs on see if you see any pictureor menu when pressed on remote .if so possibly backlight issue.
try darken thye room your in when shining a torch at the screen
. What's your make and model number
as it could be tcon or main board issue even
Feb 03, 2017 | Televison & Video
Need Supersonic SC-1911 remote code for Dishnet
0023,0020,0027. Try these codes. If you wish to get more details; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. Common set-up codes to check with TVs and other devices are given, in the order of the "device's brand name list" in alphabetical order. Pull up older posts. Surf the site with patience. Surf the sites by type in the brand name to your set, in its search box.
http://electro-medical.blogspot.com/
http://remotesearch.blogspot.com/
http://electrohelponline.blogspot.com/
Oct 14, 2014 | Supersonic 19" LED 720p 5ms - SC-1911
I need remote control codes for my symphonic model WF24T5 to use my dishnet remote please
Use the remote dishnet to automatically detect your code for the tv. Most of the time the procedure is on the remote.
Mar 11, 2012 | Symphonic WF20D4 TV
Comcast remote does not work after dark, works just find in day
I have had the same problem I have two bell receivers one in the bedroom and one in the living room, in low light the remote in the living room would work much like yours, but if I took the same remote into the bedroom it worked fine in low light, the second remote responded exactly the same, the problem in my situation was the TV had a light sensor that adjusts the picture depending on the light in the room, with this option turned off. The remote works just fine in low light situation.
Oct 20, 2009 | DISH Network IR Remote Control
The two TV are synced. Do I unconnect them? I have one TV in the living room, one TV in the bedroom. Whenever the TV in the bedroom is on, it is on whatever channel is on in the living room. Both remotes...
If you have a dual tuner it is in sigle mode. Go to the front panel on the receiver and press the mode button. This may be behind a push open door based on the receiver you have. If this does not work let me know. Thanks for using Fix Ya.
Aug 15, 2009 | DISH Network IR Remote Control
I have a bedroom ceiling fan that recently started to have a surge issue. It was working fine before (although the remote control for this fan also worked on the Hampton Bay fan in the living room and the...
Sounds like you could have a problem with the fan....but there is also an equaly good chance it's the wiring of the fan. Perhaps a loose connection. If you are not familiar with checking electrical connections, you probably need to call an electrician to check the wiring SOON, before there is a short. If all connections are good, then you will know it's the fan (or the remote receiver on the fan).
Hope this helps!
Chad
Oct 14, 2008 | Hunter 52" Ceiling Fan With Light And...
One T.V. snowy on Sat., clear on local channels, others are fine?
if you recently got dishnetwork call the company that installed the system for a repair person, they HAVE to fix it. if you put it in yourself it sounds like the lnb is bad or the dishnetwork splitter is bad or not hooked up right. this kind of problem is a reminder that paying an extra $5 a month for service warranty is a good deal. if something is wrong with anything then, a phone call to dishnetwork will get new equipment sent to you or a service tech sent to fix it. i don't presently work for dish or direct or a cable co but i know that's how things work.
Apr 16, 2008 | DISH Network 311 DTV Receiver
Should be controllng one box. is controlling 2 boxes
Unfortunately, there is no solution for this issue.  The remote control sends out an infrared signal, which can be picked up as far as 40' away from the device.  And to make things worse, the signal will reflect off any surface such as glass, mirrors, or even brightly painted walls.
The only way to solve the problem is to block the path of the beam to the other room.  This may require closing a door or drawing heavy drapes closed.
Mar 03, 2008 | Logitech Harmony 880 LCD Remote Control
Mitsubishi CS-35505
Had the same issue. Try hitting the input button on the remote. Then chose aux. 1 option. Worked for ours.
Dec 28, 2006 | Mitsubishi CS-35505 35" TV
Televison & Video Logo
66 people viewed this question
Top Televison & Video Experts
