SOURCE: whirlpool Accubake Duo Oven Not Heating up
the oven not heating up. it's start up some time and other time u just hear it try to click on but don't hear no fire turn on
SOURCE: Whirlpool gold accubake oven won't re-ignite
i have a whirlpool gas accubake range and only two burners will ignite. The other two burners make a clicking sound and release gas but never light. I have to use a match to light the other two burners and the flame is uneven on one. What should i do?
SOURCE: whirlpool accubake oven problem
I had the same problem and followed the process listed above....yes, I
did unplug/turn off the circuit and am alive to share this update!
Right off I noticed that the ribbon cable was loose. For those who have
tinkered around with other electronics such as a PC, etc., note that
this ribbon cable is not secured by the connector (atleast in my case).
Reseated the cable and turned the power on. Voila- the bake option
works. Tested it by turning it on for 20-30 seconds. Touched the bake
element and got proof that it was working fine (via a singe of the ring
finger ;-)).
About three minutes or so later, the display started to beep with an
error code - E0 F2. A shorted keypad is what it stands for. The clock
was still operable. I could still select the bake option, broil option,
etc. Ran a test bake cycle but it turned off after a minute or so and
started to display the E0 F2 code again.
Started the process all over ie turn power off, take panel off, reseat
ribbon cable. Turn power on and test by holding the Cancel button for
five seconds. Still displays the E0 F2 error. Waited for 10 minutes but
this time no more beeping or error display. Ran a preheat cycle for 4+
minutes without any problems. The oven warms up and the bake element
glows red. Hopefully, all is well. Will see what it does when we bake
something the next time.
Thanks to PropHeadTwo and others for their contributions.
SOURCE: Whirlpool Accubake Super Capacity 465 gas range. Oven won't light
Some gas ranges may take 10 or so minutes to light.
Other than that you may have a defective glow bar ignitor.
If it glows and does not light the reistance in the ignitior has failed.
SOURCE: I need to replace the
Remove right (looking from front) side panel . Lift up insulation near bottom . Remove one screw slide toward back and pull out.
