Question about Linksys Wireless-G WRT54G Router
I wish to connect a laptop to my wireless network linksys _SES_34573 but do not remember my security key or passphrase. Any suggestions?
    Sniper:
  • 52 Answers
Connect the ethernet cable from your router to your computer. (basically don't use wireless)
Go to Start -> Run -> Type "cmd" (no quotes)
A black box should then appear, type "ipconfig" (again don't use quotes). You should then see something where it says Default IP.
Most likely 192.168.1.1 or 192.168.0.1. It does not matter if it's different. Go to Internet Explorer type the Default IP into Internet Explorer address bar http://192.168.0.1
It will most likely prompt you for a username / password - If you do not know the username nor password - try looking it up your router in the list on this website http://www.anameless.com/blog/default-passwords.html and use the username/password they suggest.
If that doesn't work - Unplug your router's power cord, and press the reset switch found on the back of the router. Leave unplugged for a few minutes, then try logging into the Default IP address again.. http://192.168.0.1 with the username/password that is suggested at the site above.
Once logged in you can change or Lookup the WEP key. Source(s): http://www.anameless.com/blog/default-passwords.html
Posted on Mar 26, 2011
Find network key
Network Key (WEP, WPA, WPA2 Encryption key)To connectyour computer to a wireless router, you click the Refresh networklist, then Choose your wireless network and then click Connectto your secured Wireless Network, it will asks for a Network Keybefore allowing you to connect into your wireless network. This NetworkKey is either the WEP, or WPA or WPA2 Encryption key that is used toconfigure the Wireless Router. The Passphrase is an alternate way tosetup the Encryption key.
When you are requested for a Network Key, you can just enter the Passphrasethat was used to configure the Encryption key in the wireless router.http://www.fixya.com/support/r5270415-network_password_network_addressFor information on securing your wireless network,configuring the wireless router and configuring the wireless card in thelaptop/computer, please click on this link and follow my instructions :-http://www.fixya.com/support/r3559128-wireless_router_security
Jun 28, 2012 | Linksys Computers & Internet
How to put password? I have the same Wireless
When youclick Refresh network list, then Choose yourwireless network and then click Connect to your secured WirelessNetwork, it will asks for a Network Key before allowing you to connectinto your wireless network. This Network Key is either the WEP, orWPA or WPA2 Encryption key that is used to configure the Wireless Router. The Passphraseis an alternate way to setup the Encryption key.
Feb 07, 2012 | Linksys Wireless-G Broadband Router
I have a sony ps3 and i have a linksys router , but my sony ps3 is not picking it up or connecting to it , it keeps asking me about the wpa key and i dont know it, what am i doing wrong ?"
Dec 04, 2011 | Linksys Wireless-G WRT54G Router
Linksys 64bit passphrase
The passphrase is a phrase you create instead of using hex numbers (phrases are easier to remember than hex numbers) to setup the wireless encryption key.
To configure the Linksys wireless setting, connect a LAN cable from the Linksys LAN port to the computer's LAN port. Open a browser and enter the Linksys configuration URL
http://192.168.1.1
The default login = admin
The default PW = admin
Then go to the wireless settings and configure the SSID and WPA or WPA2 encryption.
Use a passphrase to setup the encryption key
To secure your wireless network from unauthorized access, please click on this link and follow my instructions :-
Nov 08, 2010 | Linksys WRT300N Wireless Router
Cant find wep key
Your printer is saying that you should secure your wireless internet. Try resetting the router by holding the reset button located on the back for at least 30 seconds.
Nov 20, 2009 | Linksys WRT160N Wireless Router
Where do I find the network key for my linksyswrt150N?
This is located under the wireless settings on your linksys. This is something you would have set up when installing the router. If you don't remember or it is confusing.. Change it. I usually use the KTIP security because you can use a normal passphrase that is easy to remember. Hope this helps
Sep 12, 2009 | Linksys Wireless-N WRT150N Router
Need to get laptop connected to wireless connection
The passphrase only means that there is a security enabled on that wireless network. You are correct, you need to know that passphrase for you to be able to successfully connect your laptop to that wireless network.
If you need more help on how to get this passphrase just let me know.
Dec 17, 2008 | Linksys Wireless-G Broadband Router
Linksys wusb100 usb adapter
Did you put in your WPA passphrase on the software for the adapter?
Click on the linksys icon in the lower right corner, go to site survey select your network then click connect. Put in your security key. That should do it.
Jul 22, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
I dont know my passphase
hello!
If you dont remember your passphrase or network key, you need to access the router page to check the router wireless settings. make sure that your computer is directly connected to the router to check your passphrase
Step 1: Access the router’s web-based setup page
Step 2: When the router’s web-based setup page appears, click Wireless
Step 3: Click Wireless Security and take note of the current Security Mode
Step 4: You will see your wireless network key or passphrase on this window
May 19, 2008 | Linksys Wireless-G WRT54GS Router...
Security Keys or Passphrase
  1. Now we will secure you wireless connection to prevent others from connecting. Under the Home tab, click the Wireless option from the left.
  2. Beside the SSID option, enter the name for your wireless network connection.
  3. Beside Security, select WPA. If you can’t connect using WPA, then select WEP. Using WPA will provide a much more secure connection that using WEP. For more information about WEP and WPA please read Wireless Security: WEP and WPA.
  4. Click AES beside the Cypher Type.
  5. Make sure PSK is selected beside PSK/EAP.
  6. Now you must get very creative. Specify a long Passphrase with a mix of upper and lower case letters, numbers and punctuation. Once again, please read Creating Secure Passwords for tips on how to do this. In this case the longer the better. Make sure you write down this key somewhere, either on a piece of paper or in a text document on your computer. You will need this information when you connect to your wireless network.
  7. Enter your passphrase next to Passphrase and again beside Confirmed Passphrase.
  8. Click Apply to save your security settings.
  9. Now you are all done securing your wireless router and network. All you need to do is connect to your network, and enter your Passphrase exactly as you specified it. I won’t go into detail on how to connect to your wireless network, as I will save that for another post.
May 10, 2008 | Linksys WUSB54GC 802.11g/b Wireless...
Linksys Wireless-G WRT54G Router Logo
57 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
