Question about Fuji FinePix S2 Pro Digital Camera
Whenever I take a picture it shows only purple vertical lines in monitor
    Champion:
  • 226 Answers
Hi towens27, sensor ?.....Please contact Fujifilm for service.
Regards
Posted on Mar 22, 2011
Got a playstation display and it has a bluish purple vertical line down the tv but it disappears when any red shows up in thae area of the line any ideas what's wrong with it and if it can be fixe
The display unit is defective, some IC seems to be damaged, it can be repaired from any repair shop, but I don't think the cost will be low, as the display is manufactured by Sony and the spares are not available easily .
Aug 28, 2012 | Sony PlayStation 3D Display - 3D LED...
Hi. I'm running two monitors off my HP notebook. a Planar and Dell, both 13". The Dell just got vertical lines and is mostly purple. what happened?
Disconnect the monitor from the back of the laptop . Check if the monitor is still purple in the self test feature check . Or there is a vertical line. If the color and the line is not there in the self test. Check the signal cable for any bent or broken pins. If the same is not the issue .
Check the video card drivers for problems.
Thanks
Proton
Feb 02, 2010 | Dell E173FP 17" LCD Monitor
Vertical lines on monitor
there is no way to fix monitors on laptops all it could be doene is replace but it its more expensive than to just buy a new one
Oct 29, 2009 | Dell Inspiron 1525 Laptop Jet Black
Green/blue/purple vertical bars on my viewsonic va712b
you're video card is failing, try the secondary port if you have one, artifacting such as different colors, shapes and lines are VGA related, you need a new VGA card and for more info contact http://tinyurl.com/m7ghqz
Jun 18, 2009 | ViewSonic VA712B 17" Flat Panel LCD...
Laptop monitor have vertical lines apearing out of nowhere...
LCD needs to be replaced.
Common problem called "Tab separation".
Jan 10, 2009 | Toshiba 14" LCD Monitor
Purple screen vertical lines picture comes & goes
I would suggest that You should check your monitor with another PC. If it still has the same problem, there will be something wrong with your monitor.
Using these following steps to examine your monitor. After you turned PC on and monitor went purple, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 14, 2008 | Polaroid 15'' HDTV Monitor FLM-1511
Coloured lines on picture screen
I have the same issue, Although My camera is a samsung N46, It was working perfectly the night before, then my friend switched it on and it came up with a black backround and pink + purple vertical lines going through it.
Nov 12, 2007 | Olympus FE-120 Digital Camera
Boka monitor problem
Below are images of the vertical IC of a Boka MO-15NF. The first shows its general location which is almost at the center of the board.  The second is a close-up.  Hope this be of help. Good luck and kind regards.
Oct 26, 2007 | Gateway FPD2275W LCD Monitor
Fuji FinePix S2 Pro Digital Camera Logo
190 people viewed this question
Top Fuji Cameras Experts
Steven Wander
Steven Wander
Parshiv Luthra
Are you a Fuji Camera Expert? Answer questions, earn points and help others
