Question about Uniden DECT 6.0 Cordless Phone ID
I do not have a dial tone or display on my phone. however, after testing with a multimeter in several spots i have 2.7 volts at battery. I have 2.4 volts on several terminals on 3 sides of the display itself. what can my problem be?
  • 106 Answers
If those are normal. The problem is within the cable of the telephone company provider not in your own telephone. Contact the CO or central office of the telephone company to resolve the issue
Posted on Sep 18, 2011
No dial tone cant make calls
No dial tone and inability to receive ring signals are symptoms of connection problems. The installation instructions should indicate how your telephone system should be connected to the network.
Dec 30, 2013 | Lands Phones
Hi, I have a Panasonic Cordless phone with 2 bases. I have moved one from upstairs to the phone jacket downstairs. Our third phone worked fine until I switched two of them around. Now only the plugged...
You could plug your non-cordless phone into suspicious phone jack to see if you have dial tone-if you dont have dial tone, the line maynot be connected and you should open the jack to see if there is more than 1 cable attached. If there is more than 1 cable attached and you dont have dial tone at other end of cable the cable might be cut or shorted somewhere inbetween. You can test continuity by tying 2 wires together and test with a multimeter on resistance to see if it is open circuit or maybe even short circuit. To test for short circuit, untie the cables and you should not get a reading. If you do have dial tone when you plug in non-cordless phone the distance might be to far for receiver to pick it up(ie..greater than 10 metres). I hope this has been helpful.
Aug 26, 2011 | Panasonic Lands Phones
There is no dial tone, only a busy signal.
It is possible that your dialer IC could have failed or the optocoupler or the pulse dialing semiconductor/ transistor, Disconnect the phone and use a multimeter to test the line voltage, then connect and test, if the voltage has come down then it is possible that the above mentioned parts needs a check. Often it is the failure of the pulse switching transistor hence you can trace it from the telephone line. Use the multimeter in the contiinuity mode to see for a short here, even for a zenerr diode which is used a protector. disconnect and see if the dial tone returns. In this case replace the shorted diode or transistor or the IC. Hope you try this out. Good day
Jul 30, 2010 | Uniden Lands Phones
I have two questions. The first is what is the
The dial is for selecting which of the "multi" things you need for measuring (metering).
Set the dial to the DC area and select 20V or whatever is the lowset DC voltage setting that is higher than the battery voltage.
The meter does not put a "load" on the batteries, so the test is just an estimate of freshness of the battery.
Notes:
The meter voltage does not present any danger to the user. If you are not experienced, do not check any AC voltages.
Oct 12, 2009 | Kitchen Appliances - Others
Semi Dead Panasonic KX-TGA100N with ''C533'' displayed.
Panasonic KX-TG1050N Cordless Phone. Base handset (No. 1, KX-TGA100N) does not work, no keypad response or dial tone. Green indicator message light ON (should only work with the TG1000N base unit) all the time till battery runs down. Display shows message ?C533?. Can still send and receive calls on extension phones 2 and 3.
Nov 11, 2008 | Panasonic KX TG1000N Cordless Phone
Nokia 6500 wont hold ring tone
did u try removing the battery and reinserting after 2 min..
and if already tried,
then try dialing from other phones, or check the assign tone in ur phone contact from which ur testing to be assigned with some ring tone...
Jul 17, 2008 | Cell Phones
Uniden DECT 6.0 Cordless Phone ID Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
