Question about Garden
My Centurion 15000 can't start because there is no spark to spark plug.
    Sergeant:
  • 259 Answers
It could be a bad spark plug. When you get a new one make sure it is gapped properly .030. If still no spark it could be a bad on off switch. Take one of the wires off the switch and see if you have spark. If no spark suspect the coil is faulty.
Posted on Mar 22, 2011
I have a centurion 15000 generator that starts and runs but wont put out ant electricity
Have the voltage regulator tested as well as the control circuit board
Aug 26, 2017 | Electrical Supplies
Centurion 15000 generator wont put out any electricity
go to youtube and search reflash generator
2008 WONT START WHEN HOT
If you have over 15000 miles I would change the spark plugs and clean the air breather for starters to see if that will help.
Jul 01, 2014 | 2008 Harley Davidson FLHX Street Glide
IDLE FLUXUATES
could be a number of things , a fuel filter change won't hurt but i'd be checking the vacuum pipe's , the distributer , spark to plugs condition of plugs , air intake pipe's and air filter , keep me posted if you wish
Jun 20, 2014 | 1992 Toyota Cressida
07 chevy uplander transmision slips at take off from stop
I had a similar problem thinking my tranny was slipping. Turned out it was the spark plugs miss firing, had 100,000 mi. Changed the plugs & wires problem went away.
Dec 19, 2012 | 2007 Chevrolet Uplander LS Minivan
15000 mile hd heritage recommended maintanence
Change all fluids. Adjust clutch. Check spark plugs. Adjust primary chain. Lube cables. Check air pressures. Check all lights. Adjust throttle cables. Check spoke tightness. Check fall away (neck bearings). Check rear belt tension. Tighten critical fasteners. Check proper operation of all controls.
Aug 25, 2012 | 2005 Harley Davidson FLSTC - FLSTCI...
2002 mini cooper non turbo. Replaced head gasket, cranks good, fuel pump turns on, no codes on scanner. No spark at plugs, all fuses good. Was in a light wreck at some point and airbags deployed. ...
No spark means that it has a problem in the HT coil that converts 12 volts to 12000 - 15000 volts to create spark. Have you run it long distances? Like 50 or more miles? Does it stop or stutter?
Oct 20, 2010 | 2002 Mini Cooper
My 1986 F250 with a 6.9 diesel engine will not start on a warm day unless it is plugged in for an hour before. Once it fires up, it will run great and I can turn it off two hours later and it will still...
Sounds like your batteries are not producing like fully charged batteries. You may have to replace them do you have the tool to load check them? Hope this helps you. Darrell S
May 22, 2010 | 1986 Ford F 250
02 Yamaha vstar 650 No spark brake side
Hi, Hairartist_t and the usual suspects are:
1. Fouled spark plugs.
2. Severely discharged or a damaged battery, should have 12.5 volts or better and be able to pass a load test if necessary.
3. Check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Loose connection at ignition coil or plug between ignition sensor and module.
5. Spark plug cables in bad condition, shorting / leaking, spark plug cable connections loose.
6. Faulty ignition coil or ignition / electronic module
7. Faulty CKP, CMP, or BAS sensor.
8. Faulty ignition switch.
9. Tilt sensor needs a reset.
10. Security alarm failing to disarm needs reset
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
http://www.starbikeforums.com/forums/18-engine-work/2886-no-spark.html
no start or no spark
http://www.sloneservices.com/SilverBack/Other-Stuff/V-StarShopManual99-07.pdf
OEM parts for Yamaha
http://www.starmotorcycles.com/assets/service/manuals/2003/LIT-11626-16-05_22.pdf
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/gregg_c0ec1df182c7330e
Apr 07, 2010 | 2004 Yamaha V Star Classic
1995 honda civic constantly needs spark plugs replaced (every other month) or car will not start.
Are they fouling out? Too much fuel making them load up? Or is a weak coil causing them to fail when the car sucks in more fuel under load?
Have your coil tested at a parts store or take it to a mechanic and have it given the once over.
Leaky injectors could be fouling them out too. If you coil checks out you may want to pull the injectors and have them leakdown tested.
This involves taking the injectors off the engine so you will probably want a mechanic to do this for you as well.
1995 Civics are great cars. My friends gets over 40 mpg and still has lots of spunk!
Good luck and be careful.
Mar 03, 2010 | 1995 Honda Civic
Garden Logo
90 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
