Question about Realworld Technology Inc. Sicuro 5.1 Computer Speakers
What do I need to do to get my Sicuro 5.1 speakers to work??? I'm not getting any sound
  • 27,725 Answers
If your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers make sure you have selected the
(((appropriate speakers))) also audio you will find 3 drop down lists make sure you have the correct settings there
also
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can change your settings there you can also tick in the box place icon in taskbar
if his does not fix the problem
have you tried this control panel sounds and audio,volume,advanced,speakers select the appropriate speakers from the drop down list or navigate to the device manager scroll to system devices + to expand,system speaker right click properties then select use this device (enable) also you might check
the speakers plug/outlet is usually at the back of the computer you will have to open up the computer to check the lead attached to the rear of the input plug make sure the connection is good
try cleaning your computer of dust using a fine air blower from a compressor making VERY sure that there is no MOISTURE in the air line specifically around the sound card and the CPU central processing unit dust causes static to build up in a computer
hope this helps
Posted on Mar 22, 2011
Cant hear audio when switched to enhanced mode. no audio when testing subwoofer or center speaker
You say this is a 5.1 system. Five satellite speakers and 1 Bass woofer. Do you have a 5.1 or better sound card? If so, have you connected all of the colored plugs to your sound card? If your sound card only has 3 to 4 audio connections you will not be able to run in enhanced mode.
Mar 09, 2010 | Sicuro RealWorld 670XL-BK 5.1 Gaming...
Realworld Sicuro RW-670XL 5.1 speakers. The front speakers (L, R) have stopped producing sound. I know it is a problem relating to where they plug into the subwoofer - since I can take any of the...
F4 is typically related to a drainage problem. If the water is not draining from your dishwasher, verify the following: Verify that there is not a clog in the drain hose or air gap. This is typically the reason that a dishwasher won't drain and the clog is usually where the drain hose attaches to the garbage disposal or sink drain pipe. Remove the hose and clear any clogs, then reinstall. Verify that the pumps drain impeller is working. You can reach the impeller from inside the dishwasher after removing the lower rack, spray arm, and arm support. This typically involves removing a few screws. Once upper parts are removed, inspect the drain impeller, which pushes the water toward the drain port, for any cracks or missing blades. If the impeller is defective, the water will not drain properly and you would need to replace it. Inspect the sump area for any debris or broken glass that could be blocking any ports. Verify that the drain valve is working; many are controlled with an electric solenoid that opens the valve, sending the water to the drain. There is a chance that the solenoid or the diverting lever could be stuck which would prevent the water to drain. If so, try to free up the solenoid and lubricate the lever. Otherwise the solenoid or pump assembly may have to be replaced. Verify that the motor is turning/ working and verify that there is power to the motor. If the motor hums but doesn't turn, it may need to be replaced. Motors can get stuck if not used regularly. If the motor is defective, the water will not drain and you would need to replace it. There are ways to test the pump and motor with a multimeter. If you are not comfortable with doing this, you may want to have a plumber test it for you.
Feb 16, 2010 | Sicuro RealWorld 670XL-BK 5.1 Gaming...
No sound from Creative Labs Speakers- Please help
to localised your problem, try to plug your speakers to other sound source like mp3 player ,stereo system. if still no sound coming from it,your problem is within the speaker system. perhaps the audio power amplifier ic inside, need to be replaced.
Oct 12, 2008 | Logitech X-530 Computer Speakers
Speakers
Test the speakers by changing source to the disc mode, and inserting a dvd into the HTS. If you get sound on all 5 speakers in DVD mode, then your speakers are still good. If you don't get sound on all 5 speakers, then press the "SURR" button to try the sound in stero, dolby, or other modes - one of these should give you sound on all 5 speakers. If you still don't get sound on all 5 speakers in dvd mode, then there is a problem with the speakers or speaker wires.
If you do get sound on all 5 speakers in disc (dvd) mode, but not when in TV mode, then take out the red and white AV cable, go buy a digital audio or SPDIF cable, and plug in the digital audio or SPDIF cable from the digital audio OUT of your TV or cable/satellite box to the "DIGITAL IN" of the HTS.
-Tha Mp3 Doctor
Feb 17, 2008 | Philips HTS3440/37 System
Lights dont work
your speaker working willbe okay
If it not working check the power uspply voltage
some time its due to dry soldering
  • clean the LED leads and resolder it
It may due to LED trouble
  • Replace the LED
Jan 24, 2008 | Sicuro RealWorld 670XL-BK 5.1 Gaming...
Head Phone
ohhhh .... open the screws of the head phone and see for a broken wire.
if you find one just join in by getting it soldering
Dec 10, 2007 | Sicuro : RW-350XL Gaming Speaker 2.1 Black...
Only 2 of my 5 speakers are working
Press the SURR button until you get sound on all five speakers. If you don't get sound on all 5, there are a few possibilities:
1) the program you are watching only gets stereo sound or lower (only two or one speaker will play in this case)
2) you need to get a digital audio cable instead of using the red/white AV cable
3) a setting on the TV, cable, or satellite box needs to be changed to allow surround sound in full
Apr 30, 2007 | Philips MX3700D Digital Surround Sound...
Realworld Technology Inc. Sicuro 5.1 Computer Speakers Logo
Top Realworld Technology Inc. Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Realworld Technology Inc. Audio Player and Recorder Expert? Answer questions, earn points and help others
