Question about HP Computers & Internet
My printer dos not scene. before it work but not now. if i try to scene something i can't scene anything because it not working.
  • 79 Answers
Reset your printer by holding down the power button until it turns off, wait 10 seconds for it to turn back on, and then see if you can scan. If not contact HP by phone or online here.
Good Luck!
Posted on Mar 22, 2011
Why does the scene look wobbly on view finder?
Your in zoom mode. Go back to wide angle mode,.
Aug 13, 2014 | Cameras
I can't print
if your using printer with usb cable
dos print will not work
try lpt port
or
try dos to usb softwre
Nov 19, 2013 | Epson FX 2170 Matrix Printer
I cant use usb printer to get print out from dos base softwear
If you are using a NT based Windows (ex. win nt, win 2000, win xp, etc...) you could try sharing the printer than MAP it as a network printer and direct it to a virtual LPT port with a DOS command ex: net use lpt2: \\ComputerName\SharedPrinterName /yes
Than setup the DOS software to print on LPT2 it should worke, i've done this many many times
Note: if you absolutely have to use LPT1 dont forget to change the physical LPT 1 port in Windows hardware manager to something els so it do not conflict with the virtual one
Feb 15, 2011 | Epson LX-300+ II Matrix Printer
HAVE A DOS BAKERY PROGRAM THAT IS USED DAILY. OUR XEROX PRINTER BIT THE DUST AND MY BOSS HAD ME RESEARCH AND PURCHASE A NEW ONE. PURCHASED A CANON MF6540. ONLY PROBLEM IS, NO ONE TOLD ME IT HAD TO BE A DOS...
There is a workaround that will work for many dos based programs.
It will remove several of the advanced feature from your printers functionality but may solve the problem.
Try this:
Open control panel, switch to classic view if not already in it. Open the Printers folder, then Right-Click on the Canon MF6540, select properties.
Once it opens the instruction may vary slightly for your printer but should roughly be:
1. Select the advanced tab, then click print processor, then select one of the RAW modes on the right and Ok twice to close the windows.
2. Try printing in the DOS program, if it fails, repeat step one and try the next option. If none of the RAW modes work, try the TEXT mode.
If none of these methods work you may need to emulate a LPT Port for the DOS program to Print to, forward it to the Printer and then repeat the above process. DOS programs are notoriously finicky about settings so you will likely have to try several settings to find one that matches.
If your first attempts fail and you need to emulate the LPT port get back to me by adding a comment to this post and I will see if I can find a good emulator to try for you. Or you can buy a router to connect the printer to that already has emulated LPT software such as the Linksys WRT610N. Sharing the printer through such a router creates a virual LPT port on your computer which may work.
If you need more direct help, try clicking my name and clicking Ask Me for paid support. If you can handle the normal speed here in the forums simply reply and we will help you as soon as we're able.
Hope this helps FixYa,
Chris
May 14, 2009 | Canon Office Equipment & Supplies
Printing from 1989 DOS program "Labels Unlimited" with same
sound like a parallel connection.
Try this:
open a dos command prompt and type this command:
dir>lpt1
this would try to print through the dos mode if you connections is good it should print something.
Mar 26, 2009 | OKI MICROLINE 320 Turbo Matrix Printer
Scene Editor Won't Work!
You may not have the hardware requirements to have Scene Editor to have it function properly. Check the system requirements.
Oct 24, 2017 | Ubi Soft Petz: Dogz 5 and Catz 5...
Help me with Zebra TLP 2844
The printer only understands EPL code. (Eltron Programming Language) If you are trying to print text from DOS it wont understand (interpret) the txt codes.
To verify that the printer is working.
Open a DOS box, start the dos editor. Type Edit. Dos editor will open.
Type a single capital letter U. and print. Send to printer. The printer will print a configuration label.
EPL code to reset printer is
^default.
If you want to print a text file. use the Zebra Universal Driver. Zebra TLP2844. Open any windows application. E,G, Notepad. type text and send it to printer. Print as normal.
Jul 24, 2008 | Zebra LP 2844 Thermal Printer
Extra Line when printing from a dos-based program
well..that EOJ line, is possibly farther down in the program settings, and is like a page break. the Dell is only doing what it's reading, so the answer is in the programming of the application. Perhaps you might query that company about how well that program interfaces with the Postscript quality printer you have?
check your computer warranty here for FREE
Feb 26, 2008 | Dell 3100cn Laser Printer
Konica Page Pro 1350 - Not printing from DOS
When you install your printer, you may notice an message asking whether you want to print from DOS based programs. If you answer yes You could print from DOS based programes too. To do this you may need to unistall and re-install your printer again ! If it doesn't work you should download any ultility from the internet to get the printer supported on DOS.
Oct 06, 2007 | Konica Minolta PagePro 1350W Laser Printer
Computers & Internet Logo
22 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Alun Cox
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
