Question about Car Audio & Video
Changed battery then radio will not work - Car Audio & Video
Most likely the fuse for the radio is blown. If the radio is factory, check the interior fuse box (normally located on the lower drivers side of the dash) for any blown fuses. Normally the fuse that will blow will say something like "Radio", "Audio", "Interior", or "Cig" near them. If the radio is aftermarket, check the fuses noted above and also check for a blown fuse located on the rear of the radio (Usually next to, or on the main power harness).
Posted on Mar 22, 2011
Need the radio code to reset after battery was disconnected.
Afraid there is no radio code as such....the Saab headunit is paired to the car with Saab Tech 2 software.
A dead battery swap shouldnt lose the radio if it was working before you changed the battery.
Have you checked the fuse for the radio?
You should also post on Saabcentral
Jan 14, 2016 | Saab 95 Cars & Trucks
Tip
DISCONNECTING YOUR BATTERY without losing the RADIO CODE
I constantly read frequent requests for RADIO CODES referring to the disconnection of battery power ( whether its for changing the battery, etc.) and the radio is now INOP. Here is a simple way to save radio codes, radio stations, clock time and computer settings. Purchase from an auto parts dealer, a 9 volt battery powered lighter socket connector. Plug into lighter, do your battery work, After work is completed, disconnect, and radio will work as before. Unit will cost less than 20.00 and well worth it.
on May 11, 2009 | 1993 Cadillac DeVille
Change the battery in my 2007 Hyundai Sonata and now my radio won't work how do I get a code and put it in?
Hyundai Tiburon Questions - how do i reprogram my lock ...
www.cargurus.com > Questions > Hyundai > Tiburon
CarGurusAug 17, 2009 - how do i reprogram my lock remote to my car? i changed my battery an ... i change my battery an now my lock an un lock buttons dont wor. ... I have aHyundai 2003 Tiburon, and the following worked for me, get in your ... The unlock codeis inside the case. ... Now my radio interior lights and clock wont work.
Hyundai replaced car battery now radio doesn t Cars ... - Fixya
www.fixya.com > ... > Cars & Trucks
Hyundai cars & trucks replaced car battery now radio doesn t questions and answers ... replaced my battery,, now key remote radio & clock does not work.. thank you ... ...car If you didn't do this before you replaced the battery, then there is another code ... I put a new battery in my 2003 sonata and now the radio doesn't work.
Jan 06, 2016 | Hyundai Cars & Trucks
Radio will not power up.
there is it should be located on the back of radio itself. if that doesn't work you may need to check your fuses
Aug 19, 2013 | 2005 Subaru Forester 2.5
Radio doesn't work on batteries
same problem here, but with my radio shack scanner. When I disconnect the cord, however, the low battery indicator symbol comes on for a bit so radio seems to be taking in juice. May try a better brand of battery or some rechargeables.
Apr 30, 2013 | C. Crane SWP AMFM Radio
Changed battery in car and now XM radio does not work
Take the radio out and note the serial number, give that serial number to the dealer and they will give you a code to punch in to get the radio working.
Jan 11, 2013 | Honda Cars & Trucks
Radio doesn't work after battery change
check your fuses to the radio and check to make sure it wasnt wired to the battery direct
Dec 13, 2011 | Cars & Trucks
Radio and console does not work after replacing battery
Radio may need code, radio should display "code, loc, ..." IF no power at all, check all fuses. Sometimes spark from changing battery can blow radio fuses easily.
Aug 21, 2009 | Volkswagen Touareg Cars & Trucks
2002 xjr 100 radio will not power after battery change
If the battery went dead and you charged it, you need to reboot the system. It has lost them function of radio.
Disconnect both side of the battery and with the battery disconnected, crank the car 3-4 times (This just discharges the computers). Then reconnect the battery cables (pos + first) and you should have a working radio again.
Oct 06, 2008 | 1995 Jaguar XJ6
Dewalt Radio
dewalt radio works fine on mains
will not work off battery
Aug 13, 2007 | Dewalt DC011 AM/FM Radio
Car Audio & Video Logo
124 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
