Question about Refrigerators
I have a kelvinator impression series 210 freezer, the indicator light globe has blown. i removed the old indicator light from the light sky blue & red wires not taking notice what number terminal (e.g. 1,2,3 & 4) on the indicator the wires go back on to with the new one?
5 Suggested Answers
  • 11 Answers
SOURCE: PTC relay on compressor
Try to find the "secret" wiring diagram.  Almost all refrigerators have a hidden paper wiring diagram.  It is usually tucked into a slot under the refrig, behind the front grill, or otherwise on the inside of the lower rear cardboard fan cover, or sometimes inside the back area near the fan.  While you're in there, it's a good practice to clean the coils.
Posted on Oct 23, 2007
  • 1314 Answers
SOURCE: Periodic tripping of earth leakage switch.
your not supposed to run an appliance on a ground fault circuit because most of the components ground to the body og unit do you have it on a gcfi well here in america anyway
Posted on Jan 01, 2008
abhishek33
  • 1239 Answers
SOURCE: shelf locators broken of the
hi When a refrigerator gasket (usually a rubber seal around the door) becomes hard or cracked, its seal is broken, and the unit's efficiency drops sharply. Test the door gasket for leaks by placing a dollar bill between the gasket and the door jamb and closing the door. Pull the bill out. If it offers some resistance, chances are the gasket fits properly. If the bill comes right out, or falls out, the gasket is faulty and should be replaced. Test the gasket at several locations around the door. Before you replace the gasket, check the door hinges for leakage.
Posted on Oct 17, 2008
tborn6
  • 700 Answers
SOURCE: I have a Kelvinator upright
the clold cointrol wil cost around 50 dollars and theyt are not that hard to replace. take the model number and make to the parts house and they will be able to set you up with a new one. good luck
Posted on Jan 21, 2009
The light in my Kelvinator fridge will no longer work, can it be fixed, globe has been replaced , also
Barbara: You can remove the globe and replace the light bulb with an appliance light bulb. If it still doesn't work, try wriggling the socket a little bit with the light bulb in place (so you don't get shocked). If it STILL does not work, yes, a socket can be replaced and rewiring can be done.
May 25, 2015 | Kelvinator Refrigerators
Fridge Ices Up Even on the Warmest Setting (Freezer Working Fine)
Sounds like the cold control has stuck . Unplug the two wires from the cold control and plug them together. Turn one wire over and plug it into the other. away from the cold control.
If it runs then that cold control is the problem.
Sep 15, 2017 | Refrigerators
Freezer serial # 845440256 age?
Replacement thermostats depends on whether the fridge is a double door or single door model. You can buy this part from your appliance parts store/supplier.
Feb 20, 2014 | Kelvinator Freezers
I have a kelvinator impression series 300 and bought it second hand. The fridge component is freezing all our food and there is icicles on the back wall of the fridge. I have tried changing the thermostat...
I have the same fridge.only a week a go my wife bumped the temp control in the freezer. It ended up freezing up so much. The fan that blows the cold air down to the fridge, couldn't . If you take everything out of the freezer. There are little plastic round caps covering the screws in the back panel. Remove the caps ta
Jan 27, 2014 | Refrigerators
I have a Kelvinator impressions series 390 fridge(no freezer) it keeps icing up and then thawing all over the floor. I have it set just left of "Mid". Can you help,it is driving me crazy!!!
There should be a drain tube that allows the freezer to drain into a pan under the freezer. Over time, the drain tube can become plugged with dust and food debris. Try clearing the tube and it may just take care of itself.
Feb 27, 2011 | Fisher and Paykel Refrigerators
I have a Kelvinator upright freezer (360 Impression series) that i bought 2nd hand and the thermostat runs constantly. Do I need to replace it? Can we DIY? How much is it likely to cost? Thanks if you can...
Jan 21, 2009 | Frigidaire FRT15G4B Top Freezer...
Refrigerators Logo
142 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
