Question about Dream Maker Spas Dream Maker Ez Spa Hot Tub
How can I get my dream maker to heat up faster? Or how can I get it to hold the heat in faster? It is a x-400
3 Suggested Answers
jj505
  • 195 Answers
SOURCE: dream maker 400 cover always fill with water
You will need to either get a new cover or buy a new extralarge tarp and use as cover. Thanks jj505
Please rate
Posted on Apr 05, 2009
jasondinscor
  • 38 Answers
You can always cut small holes in the bottom of the cover to allow the water to drain out until you deside to buy a new cover. When you do deside to buy a cover try and get one that doesn't have a solid bottom but one with a mesh cover on the inside this way the water can not build up in it.
Posted on Oct 27, 2013
Program my dream maker spa
If it is heating up, it IS doing something!
What do you mean: "Wont do nothing"?
Apr 16, 2014 | Dream Maker Spas Dream Maker SpaDition...
Tip
How to care for and maintain your Dream Maker spa cover
For a great overview of what you need to know about caring for your hot tub and spa cover, check out this article on Care and maintenance
Tips include:
  1. Stay on top of regular monthly cleaning
  2. Avoid using too much chlorine as it will deteriorate covers faster
  3. Use armor all or some other type of vinyl protectant
on Sep 02, 2016 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream maker spa will not heat up
bad heating element or temp sensor or recirculation pump
May 04, 2013 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream maker spa x-400 won't shut off keeps heating. I have turned it off and let it tottaly cool down the temp max temp is set to 95 and it never shuts off until it gets to 105 and overheats.
I had the same problem last year, I talked to a spa guy and he stated that the temp sensor was probably covered in bio crud. He also stated that the tub should be cleaned with a hot tub flush. After doing that I have not had a problem with the temp settings.
Jan 19, 2013 | Pool & Spa
Dreammaker 400 spa won't heat up
make sure recirculation pump on then check heater element then pressure switch then loud motor you hear
May 21, 2012 | Dream Maker Spas Dream Maker Ez Spa Hot...
Motor will not come on. flashing OH on tub display dial. Dream maker Model #8003 x 400 series 86L Just purchased used spa and have no manual or directions. thanks
OH stands for Over Heat situation.
If the motor is not working at all, you are getting the OH code because of that. The OH happens when there is not enough circulation in the hot tub which causes the water near the heater to overheat the sensor located in that area. It sounds like either the pump has failed, the wiring has shorted to the motor, or the control board is not telling the pump to come on.
Its probably a bad motor since the heater is obviously activating, which it wouldnt if the pumps motor was getting no power. Replace motor and all should be well again.
Apr 14, 2011 | Dream Maker Spas Dream Maker Ez Spa Hot...
Power is on but jets arnt going and pumps not pumping
I was looking for an answer to your question. I have the same problem with my Dream Maker X-400 and it is less than 2 months old. The power is on but the tub is not heating now, its down to like 82 degrees and the pump is not working but it has power. It just stopped yesterday.
Dec 18, 2010 | Dream Maker Spas Dream Maker Ez Spa Hot...
I bought a home and my coleman spa 400 series has a problem, the jets 1 don't come on, jets 2 do. the water isn't heating up. was wondering what the problem could be
Pump one is the pump that does all the work in your spa. It handles the heating and filtering. If pump one does not work, It will not heat. It is likely pump one is gone but a technician would be needed to determine if it is the pump or the spa pack.
Dec 23, 2009 | Dream Maker Spas Dream Maker Ez Spa Hot...
Dream Maker Spas Dream Maker Ez Spa Hot Tub Logo
48 people viewed this question
Top Dream Maker Spas Pool & Spa Experts
john h
Craig Butler
Craig Butler
wadingriver
wadingriver
Are you a Dream Maker Spas Pool and Spa Expert? Answer questions, earn points and help others
