I hooked up my vizio tv to a suddenlink cable box and everytime i change the channel, the channels wont stop changing. Whats wrong?
  • 44 Answers
Hi - My name is Tina and I am with Suddenlink. I'd be happy to help you solve this problem, but need a bit more information. Could you please contact me directly at tina@suddenlink.com. Thanks!
Posted on Mar 22, 2011
Suddenlink cable remote will turn tv on and off but wont change the channels. is it the remote or the tv?
Try to program the remote again if its universal, if its not then something is wrong with the remote or its in the TV
Feb 11, 2018 | Televison & Video
When connected to cable box will not let cable box change channels with tv on but with tv off cable box works fine
Cable box not changing channels on VIZIO TV - Comcast Help and ...
forums.xfinity.com/.../Cable-box-not-changing-channels...TV/.../164607...
Apr 3, 2013 - I was able to connect my cable box and activate it without an issue. ... My problem lies in that the cable box will not change channels. Channel 8 comes in ..... I just unplugged the DTA ( you already did) and I let it sit for a while. No Audio with cable tv
Nov 15, 2012
remote not working cable box
Oct 13, 2012
Cable box not responding to remote (sporadic)
May 29, 2012
Remote doesn't want to work for the cable box
Oct 19, 2011
More results from forums.xfinity.com
Connecting Cable Service, Satellite Service, or Antenna ...
vizhdtv.com/connecting-cable-service-satellite-service-or-antenna-chann...
Mar 10, 2015 - If you are connecting your cable or satellite box using an HDMI cordyou will ... You just need to change the input of your TV then scan for channels. ... Except the Vizio TV will not receive a channel that all the other TVs get.
Jan 11, 2016 | Televison & Video
I have a element tv and I can't get any channels programmed in but ch.3. It is hooked up to suddenlink box.i have tried autoscan and nothing
The suddenlink box transmits on channel 3 and is the only signal being transmitted. When the TV looks for all channels it will only see the one coming into it. This is normal because it is assumed you are controlling channels with the sudden link box, not the TV. If you are using an antennae then you need to go into the TV's setup menu and change the settings from cable to antennae.
Oct 09, 2015 | Element Televison & Video
Can't change to channel 3 to use the dvd player
Your Vizio TV should have provisions on the rear panel for direct connection of your DVD player. Use those connections and select your DVD player as a video input.
Mar 08, 2018 | Vizio 42 in. LCD TV
Remote does not change channels when cable box is hooked up is this the way it is suppose to be?
If you use a cable box IT's remote should change channels via the box--some set remotes can also be programmed to do this.
Apr 10, 2012 | Vizio 42 in. LCD TV
Blank, snowy screen,cable box on, tv on, volume control on, wont change channel, just snowy screen
have you check your cable? is it connected to your cable box? have you change the channel vhf to uhf?
Apr 06, 2012 | Televison & Video
Phillips dvdplayervideorecorder connect w/zinwell converter box
First off get the TV on the right channel. It will either be ch3 or ch4. If you are using a cable box the dvd/vcr combo will have to be on ch3 or ch4 as well. OK, Make sure the input connector on the combo is hooked to the output connector of the cable box and the output connector of the combo is hooked to the input connector of the tv. Deal with one part at a time. First hook the combo to the tv and get the tv on the right channel (ch3 or ch4) so that you can see a pre-recorded dvd or video play. Then you will know what channel the tv is supposed to be on. When you find it don't bother the tv channel any more. Stop the dvd or video and hook up the cable box and turn on the cable box and set the box to a known good channel. Now put the combo on ch3 or ch4 with the combo's channel selector buttons until you see the cable box playing on the tv (remember you already set up the tv channel). Change channels on the box but don't bother the channels on the tv or combo anymore. You can put the box on whatever channel you want. The box will be your channel selector. I certainly hope that this helps. I know it can be confusing but don't give up. Just remember that the tv and combo have to always be on ch3 or ch4 (which ever one you found before). Good luck and thanks.
Nov 01, 2009 | Televison & Video
Vizio 320m. I set it up wrong. Instead of choosing
You should be able to use the input/source function on your remote to select which signal sources you want the TV to display, find out which input on the TV you have the cable box hook it up to then just select that input. Do you still have the user manual?
Oct 31, 2009 | Vizio VL320M 32 in. HDTV LCD TV
Is there a reset default setting?
Do you recieve any channels if you run the cable directly from the wall to the TV and do a channel search? You may have to switch your TV over to a different input source if you are using a box. Please email me at tina-AT-suddenlink-DOT-com for more information. Thanks!
Oct 15, 2009 | RCA Televison & Video
I recently changed from Cable to Direct Tv now when I change channels the screen goes blank for 15-30 seconds before the actual show begins. the picture is fine but there is a delay when changing channels
When you switched from cable to Direct TV you went from a direct connection to having a box in the middle. The box is required to to decode the signal. There is nothing wrong with the tv, you just may not have the best signal.
Jul 06, 2009 | Vizio VO47L 47 in. LCD TV
Televison & Video Logo
96 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
