Question about HP Photosmart C3150 Printer
I want to view ink levels on my HP 3150. - HP Photosmart C3150 Printer
2 Suggested Answers
SOURCE: Can't find ink levels on my printer
I just had this same problem on my Deskjet 5550 printer. The orange light (ink indicator) was staying on. I found out that all you need to do is just open the front cover to the printer. If your printer is running out of ink, the print cradle will move to either the far left or far right side. If it moves to the far left side, the BLACK cartridge is low or empty and should be replaced. If the print cradle stays on the far right side, the COLOR cartridge should be replaced. Normally, when you open the front cover, the print cradle should move to the center. Hope this helps!
Posted on Sep 02, 2008
Hp inkjet 6400 printer does not print
  • First try turning the printer off and then on again.Does it print now?If not:-
  • Check whether you've run out of ink by confirming ink levels on your printer.Here's how to:-
  1. On the start menu,move to all programs and then to HP.
  2. Click on the HP solution center option.
  3. Click on settings and select printing settings.
  4. Click on the printers tool box and view the ink levels under the 'estimated ink levels tab'.
  • Replace cartridges if dry.
Hope it helps.Thanks!
Oct 05, 2011 | HP Officejet 6500 Wireless All-in-One...
Finding estimated ink levels
Open HP solution center
Then go to settings
Then go to status
Then go to view ink levels
Then select estimated ink levels
Jul 09, 2011 | HP Photosmart C6380 All-In-One InkJet...
How do I check ink levels on my HP deskjet D4160 printer?
Here is what I found on the Web. You can click on the link below, to see Full Instructions. If you find this helpful, pls rate me.
http://h10032.www1.hp.com/ctg/Manual/c00687555.pdf
View estimated ink levels
Follow these instructions to view the estimated ink levels of the print cartridges that are installed in the printer:
1. Open the printer Toolbox.
2. Click the Estimated Ink Level tab.
Note If the print cartridges were used before being installed in the printer, the
estimated ink levels will not appear on the Estimated Ink Level tab.
The Estimated Ink Level tab also contains print cartridge ordering information. To view
this information, click the Print Cartridge Information button.
Thanks and good luck.......
Pls rate me
Jan 01, 2010 | HP Deskjet D4160 InkJet Photo Printer
How can I check the ink levels?
Just Open HP Solution Center--> Go to Settings---> status--> View Ink Levels--> Then Select Estimated Ink Levels you have your answer right now.
Regards
Rajneesh Pandey
Nov 17, 2009 | HP Photosmart C6380 All-In-One InkJet...
How do I check the ink level in the printer
Most printer will let you check the ink level using the Menu and it is sometimes under a category called Supplies or Ink Levels. If this is a laser printer you are working with Toner and its not exactly the same.
Sep 09, 2009 | Kodak Office Equipment & Supplies
How to check ink levels
to check the ink levels go to hp director in your computer START>ALL PROGRAMS> HP or HP DIRECTOR. Click on PRINTER SETTINGS>TOOLBOX. and then view the estimated ink level of the print cartridges
Aug 31, 2009 | HP PSC 2175 All-In-One InkJet Printer
Ink level didn't change
s.gif Deskjet 5100 series
  1. Click Start or c01319360.gif , click All Programs , click Hewlett-Packard , and then click Printer Assistant .
  2. Click Utilities .
  3. Click View ink levels .
    • If a cartridge is low on ink, discontinue these steps, replace the cartridge, and then try printing again.
    • If the cartridges contain a sufficient amount of ink, continue to the next step.
  4. Click Printer Maintenance .
  5. Click Clean Cartridges .
  6. Follow the on-screen instructions.
ISSUE: After installing a new HP Inkjet print cartridge, the ink level indicator remains at the previous level. SOLUTION: Continue to print and ignore the ink level indicator. The print cartridge is full of ink, it just is not being measured accurately.
May 29, 2009 | HP Photosmart D5160 InkJet Printer
How do I check ink level in my HP Photosmart C4200 printer?
If your HP is installed you have "HP digital imaging monitor" on your toolbar.
1. right click, you will see "HP Photosmart..." - "Display status"
2. Click "View Ink Levels"
May 08, 2008 | HP Thin Client - AMD Geode NX 1GHz - 256MB...
My C3100 HP all-in-one printer prints a test page everytime I want a single copy. How can I print before wasting ink on a test page?
cannot load new ink cartridge c 3150 black cartridge keeps popping out when you close acces door help thanks harry
Apr 23, 2008 | HP Office Equipment & Supplies
Ink level
1. First go to your HP Solutions Center (for a PC it's START --> PROGRAMS --> HP --> HP Solutions Center
2. Once that comes up click on SETTINGS --> STATUS --> VIEW INK LEVELS
3. To set your computer up to automatically tell you the ink levels everytime you print, then click CONFIGURATION and check the box that says "Display Ink Status Window", click the APPLY button.
Mar 19, 2008 | HP Photosmart C3180 All-In-One InkJet...
HP Photosmart C3150 Printer Logo
67 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
