Question about Car Audio & Video
Sumas Media SM-30BT 3" car stereo. Can not find
5 Suggested Answers
sandrew
  • 2961 Answers
SOURCE: i want to format my
Nobody and nothing uses the FAT system, since windows 98 only FAT32 or NTFS is used, i can't understand why you need FAT?
Posted on Sep 08, 2008
  • 5 Answers
SOURCE: how do i bypass the brake
Most wiring harnesses have a solid orage wire for illumination of the radio and also have an orange wire with a white stripe for dimming purposes. Most radios do not use this dimming feature. Connect the brake wire to this wire and your able to watch your movies whenever you want. All the wire is looking for is a signal. It cannot differentiate between a parking brake signal and a non-parking brake signal.
Posted on Apr 22, 2010
  • 7 Answers
i have this model sumas 30bt and worked in a stereo shop for the past 10 year an all i did was ground the wire to the chasisas on the fram of the dash and i hooked my friends stereo up the same way i have a 2009 fusion and there is a place to put the wire into the fran of the car and my friend has a 2008 mustang and i did the same thing and it works great i hope this helps every thing on the stereo works good even the ipod works good the back up camera works good the blue tooth works good it my not play all ur dvds but it is not a bad stereo.
Posted on Aug 17, 2010
Ezrahite
  • 2632 Answers
SOURCE: Can I reformat a 4GB SD card from FAT32 to FAT for
Welcome to Fixya. FAT16 does not support drives over 2GB. You would need to setup partitions on the drive that are smaller than 2GB in order to format this drive using FAT16. FAT16 is a very inefficient file formatting for a large drive. FAT32 or NTFS are much better for larger drives. Since your using a SD card there is no way that you can set a partition on it.
Thanks
Posted on Jul 30, 2011
How do I trouble shoot my usb port?
Quote from the manual:
The USB port provides power only, and will not playback music from a USB device.
You can download the manual here:
http://www.dualav.com/support/manuals/xd250.pdf
May 07, 2014 | Dual XD250 CD Player with Auxiliary Input...
Tip
How to Download Files to USB Flash Drive
MS Windows Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. <br />Depending on your computer, there can be USB ports on the back, side or front. The flash drive can also be connected to an external port hub device. Once you connect it, the computer will automatically recognize it as a removal device.<br /> 2.Double-click "My Computer" on the desktop. You should see your USB flash drive's icon listed together with other removal devices on your computer.<br /> 3.Double-click the flash drive's icon to open the flash drive window and <br />reveal the contents saved on it. Locate the file you want to download to the <br />flash drive from its current location on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive.<br /> 5.Close the flash drive when you are done. Click the "Safely Remove Hardware" icon on the system tray. A new window will open. Left-click the flash drive and click "Stop." A message will pop-up indicating that it is safe to remove the device from the computer. Disconnect the USB flash drive from the computer (or external hub).<br /> <br />Mac Users<br /> 1.Connect the USB flash drive to an empty USB port on your computer. The computer will automatically recognize the device and display its icon on the desktop.<br /> 2.Double-click the flash drive icon on the desktop to open its window and <br />reveal the contents on it.<br /> 3.Locate the file you want to download to the flash drive from the location <br />where you have it saved on your computer and right-click it. Click "Copy."<br /> 4.Right-click an empty spot on the flash drive window and click "Paste" to download the file to the flash drive. Close the flash drive window when you are done and drag the flash drive icon to the trash can to safely eject it from the computer.
on Feb 01, 2011 | Computers & Internet
Usb problems on Jensen vm9215bt unit
Too many subdirectories is most likely the problem.
The stereo may have limitations like 8.3 standard. That means a file can only be 8 characters long with a 3 character extension. Or 256 for folders, including paths. This is old school naming restrictions.
Oct 14, 2012 | Sony Micro Vault Classic 4GB USB 2.0 Flash...
It doesn't recognize USB flash drive anymore
The flash drive itself may be faulty or damaged, and sometimes this is not apparent from a physical inspection. Try attaching the drive to a USB port that you know is operational, and try plugging another USB device into that port to verify that the port is working.
Jun 19, 2012 | Kenwood KDC-MP445U CD/MP3/WMA/AAC Receiver...
Mga boss ayaw mag format ng usb transcend 16.GB ko"ayaw nya rin ma open "mga sir pa help naman po thankz"
solution 1: click start rightclick my computer select manage click diskmanagement
change drive letter of your usb. if your cdrom drive drive letter E: change drive letter of your usb to F:
Sep 25, 2011 | Transcend 4GB JetFlash 110 USB 2.0 Flash...
It keeps saying "media card
SaveMyUsb.com can recover data from most damaged faulty and corrupt flash memory devices including memory cards and usb flash drives for just £39 - give them a try it worked for me!
Dec 28, 2010 | SanDisk 8GB microSDHC Memory Card with...
How do i bypass the brake
Oct 06, 2009 | XO Vision XO9013 Car DVD Player
Sumas Sm788BT
Did you ever get an answer, or figure it out?
Jun 12, 2009 | Panasonic CQ-VA707W Car Video Player
Motherboard for a e-machine t6420
CPU: AMD Athlon™ 64 3400+ Processor (with AMD 64 technology)
(2.20GHz, 1600MHz system bus, 512KB L2 cache) Operating System: Genuine Microsoft® Windows® XP Media Center Edition 2005
Chipset: NVIDIA® nForce™® 410 Memory: 1GB DDR (2 × 512MB), 400MHz dual channel
Expandable to 4GB Hard Drive: 200GB HDD (7200rpm, 2MB cache) Optical Drive: 16x DVD±RW multiformat double layer drive Media Reader: 8-in-1 digital media manager (Secure Digital™ (SD), smart media, micro drive, memory stick, memory stick PRO, compact flash, multimedia card, USB 2.0) Video: NVIDIA® GeForce® 6100 GPU
up to 128MB of shared video memory
PCI-Express® (PCI-E x16) slot available Sound: 6-channel (5.1) high definition audio Network: 10/100Mbps integrated Ethernet LAN (RJ-45 port) Modem: 56K ITU V.92-ready fax/modem (RJ-11 port) Peripherals: Premium multimedia keyboard, 2-button wheel mouse, amplified stereo speakers Ports/Other: 5 USB 2.0 ports (4 in back, 1 in media reader), 1 VGA external connector, 1 serial port, 1 parallel port, 2 PS/2 ports (keyboard and mouse), 5 audio ports (2 in front, 3 in back) Dimensions: 14.25"H x 7.25"W x 16"D Weight: 22.5lbs
LInk to spec page : http://www.e4me.com/support/product_support.html?cat=Desktops&subcat=T%20Series&model=T6420
Sep 29, 2008 | Brother CS-8150 Computerized Sewing...
Car Audio & Video Logo
Top Car Audio & Video Experts
xxxxxx xxx
Marvin
Marvin
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
