Hai,I'am having problem with the car it won't start.The fuel pump is ok and it's distributing fuel,sometimes it starts and sometimes it does't.The other thing is check engine lights does't come on so what do you thing,is it a machanical problem or electrical problem (Mitsu-Pajero ECI V6 3000
    Genius:
  • 1,015 Answers
Where I would look first would be in the electrical system.I would recommend that you take it to a auto parts store and have them run a diagnostic on it. Most of them like auto zone will do it for you free of charge.It probably won't tell you exactly what it is but it can point you in the right direction and possibly save you some money if it's a sensor or something easy for you to fix.Good luck and thanks.
Posted on Mar 22, 2011
Car will start and run for awhile .But when u turn it off it won t start . And sometimes will just cut off
check ur fuel pump or fuel pump relay have an auto do a diagnostics on it the comp will def tell u whats wrong and where
Sep 16, 2013 | 2003 Volkswagen Passat
1994 Mazda PU Truck sometimes won't start if shutoff for 5-10 minutes.. Several tries later, it will start. spark seems ok, it gets enough fuel for a second, but then poops out. fuel pump shuto
Well there is no shutoff relay, but there is a fuel pump relay that powers the pump.
I would check it first. The computer grounds the relay for 3 seconds when you crank the engine to boost fuel pressure. Once the engine starts the pump is powered only if you have oil pressure.
Apr 12, 2013 | Cars & Trucks
No spark, no fuel just turns over
what is the make and model
Dec 02, 2012 | Cars & Trucks
2004 chrysler pacific will start sometimes but sometimes won't
I would suspect the fuel pump is the problem, it may be sticking at times and this causes a no start. The pump is located inside the fuel tank and it is electric.
Mar 28, 2017 | 2004 Chrysler Pacifica
2001 jimmy sle. I just replaced the fuel pump. Fuel guage works. Pump does not. Checked fuel pump relay- its ok. Trucks turns over but won't start. Whats next?
Test for ground and power at your fuel pump connector. Also, the sending units sometimes come without the pump itself wired in. You have to actually splice in connections sometimes. If you get stuck, dropping the tank again and removing the sending unit to inspect could be your next step.
Jan 29, 2012 | 2001 GMC Jimmy
Won't start
Check the fuel injectors, with the key on one side of the two wire connector will have battery voltage, if none is present then check the ECM fuses in the underhood fuel box.
Jun 22, 2017 | 1999 GMC Sonoma
My 2000 buick lesabre want start fuel pump comes on when i turn the key i have spark at the coils.checked all fuses. Changed fuel filter but car still won't start its trying to start but just...
It could be the fuel pump. Sometimes you can hear them engage, but they are not pushing enough fuel pressure to run the car. This can be checked.
Jun 16, 2011 | Buick LeSabre Cars & Trucks
1997 gmc sierra 4.3l new fuel pump and wont start
I have 1993 gmc 4.3 vortec v6 turns over but want start. replaced fuel pump, fuel pump regulator ,ecm, tps, coil
Oct 16, 2009 | 1993 GMC Sierra K1500
1995 e34 520i won`t start
i would check the fuse for the fuel pump and the relay.
May 26, 2008 | 1994 BMW 5 Series
Heating & Cooling Logo
60 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
Marvin
Marvin
