Question about Integra DTM-5.3 Receiver
Showing protected then turn off of DTM 5.3 - Integra DTM-5.3 Receiver
    Brigadier General:
  • 8,546 Answers
Generally speaking, an amp protects itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Posted on Mar 22, 2011
My nikon dtm 322 does not read distance above 100 meters.
are you sure about your instrument setting? you try press button "MRS1" or "MRS2", hold around 1 second n 1/5. Then at monitor come out "Target","Const","Mode","AVE" and "Rec mode". At "Target", u choose "prism". Good Luck.
Dec 10, 2013 | Nikon Dtm-322 3" Standard Total Station
Going to protective mode with load sounds, why?
Sounds like a speaker going bad or being over-driven.
Feb 28, 2013 | Integra DTM-5.3 Receiver
I want a charger for my Nikon DTM-A20LG
If your DTM comes with a Li-ion battery, try this universal charger product - http://www.hahnel.ie/?page=chargers&pId=54
Feb 22, 2013 | Nikon Dtm-a20lg Total Station, Surveying,...
Protect mode
Check to make sure that NONE of your speaker wires on the outputs are touching each other or that there is anything obstructing any the output terminals. Also since this a 5.3 model check all the SUB outputs for the same condition (although probably not as much an issue since they are line level outputs) as well as the condition of all interconnects and speaker cables. After that check all the physical connections at every speaker to make sure you haven't shorted out an output at that location.
Feb 12, 2013 | Integra DTM-5.3 Receiver
Protect message
Protect means that a fault was detected, disconnect all the speakers
and connect one at a time to find the cause.
If symptoms persist , it needs repair, output stage or power supply
circuits should be the preliminary things to check.
Sep 24, 2012 | Integra DTM-5.3 Receiver
Integra DTM 3.5 AV receiver. The unit goes into protect mode when I try to turn it on and then shuts itself off. How do I fix it?
Do more triage first.
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Check for loose speaker connections at the speaker as a possible root cause for intermittent shutdown.
Jun 11, 2011 | Integra DTM-5.3 Receiver
Display shows "protect" and shuts down
There is a short on one of the speakers cables or the speakers themselves. Test all of them with an ohmmeter.
Mar 01, 2010 | Integra DTM-5.3 Receiver
My integra dtm 5.3 flashes protect when i turn it on and then shutdown and the standby light start flashing. cant seem to find an answer.
disconnect all speakers. do this with the power cord unplugged from wall. then re-try without speakers. if still in protect --shorted channel-which is repair/parts will be needed.
Feb 27, 2010 | Audio Players & Recorders
I want an instruction manual for a Nikon DTM-330 Total Station
You can visit the web address below and create a free account to access all tech info on the DTM-302 series which includes the 330.
http://www.tdsway.com/support/nikon_tstations/documentation/dtm-332/BF_788
Mar 30, 2009 | Nikon Measuring Tools & Sensors
Integra DTM-5.3 Receiver Logo
212 people viewed this question
Top Integra Audio Players & Recorders Experts
Larry Stiles
Larry Stiles
Michael Galve
Michael Galve
Are you an Integra Audio Player and Recorder Expert? Answer questions, earn points and help others
