Question about Cameras
I dropped my pentax k1000 and the lens is stuck. wont focus, wont move at all. do i need to buy a new one and if so, how much/what kind am i looking for?
  • 79 Answers
While turning the camera on, or zooming gently push and pull the lens to get it unstuck. If you have to buy a new one it will cost you $75 here.
Posted on Mar 22, 2011
Can you usePentax k1000 or me super film caamera lens on a Pentax ditigal camera?
Yes, with limitations. The lenses will fit on any Pentax (now Ricoh) digital SLR. You may lose autofocus and/or auto exposure metering.
Oct 19, 2014 | Pentax Cameras
Film cartage broke missing parts
To repair this camera will be well over $100; my opinion not worth it. You would be better served purchasing another camera of the same type from ebay. An alternative terrific camera is the Pentax K1000, better yet K1000 SE. The SE has a split viewfinder, easy to focus. The K1000 have microprism that are more difficult to focus with especially in lower light; need good eyes. Then there is the Pentax K2, that at the time was their top of the line camera. All three cameras can be purchased for about $100-ish. Most will come with the Pentax 50mm f/2.0 lens.
Feb 06, 2014 | Minolta Photography
Asahi pentax sv film advance lever stuck
Without film in the camera it may well read before zero, my K1000, K1000Se, and K2 do that. Press the film rewind button, maybe that will release it for you.
For camera repairs look to:
Eric Hendrickson: http://www.pentaxs.com/index.html
Oct 02, 2012 | Pentax K1000 35mm SLR Camera
I recently dropped my Pentax K1000....oops! The only damage I noticed was a small dent in the metal side of the lens....hardly even noticeable. But now, the focus isn't working, and the light meter doesn't...
Unfortunately, this is a serious problem.
If the focus ring is not working then there is serious damage inside the lens. This cannot be repaired easily and must be taken in for repair.
As for the light meter, this is slightly more worrying as it is damage inside the body. It could be something as simple as the battery contact. But it could also be somehting more serious.
I would recommend taking it for repair.
If repair turns out to be too expensive I suggest you have a look on ebay. Pentax cameras are available with a wide range of prices and so are compatible lenses. A good upgrade would be a Pentax MX or even an LX if you can afford it. The ME super is also an excellent model if you want soemthing simpler.
Feb 22, 2011 | Pentax K1000 35mm SLR Camera
Pentax K1000 35mm SLR Camera Lens will not turn or focus= stuck
Impact damage??? remove the lens and check the barrel for straightness. also the rear lens element must be perfectly straight. some of the latest lenses have a plastic helical gear that can be tapped out with a light hammer and a piece of wood ( 1in X 4in. ) used on the high end of the rear lens, if impacted.
Oct 16, 2009 | Pentax K1000 35mm SLR Camera
Pentax k1000 ....lens will not focus...(one 50mm...other 70-210mm)...happened once before...brought to camera store and of course it focused...nothing wrong...took some pics and worked ok...now not...
Try this first.
Set your lens focus to infinity and focus your screen at a far away object (like a distant lampost). If it,s not in focus, then you have a misaligned mirror. Adjust your mirror so that a infinity setting, the split-screen image merge well to form a well focussed image. Hope that helps.
Aug 06, 2009 | Pentax K1000 35mm SLR Camera
What kind of battery does the pentax k1000 35mm SLR camera take?
Yes the K100 uses LR44 or G13. I would recommend the G13
Nov 12, 2008 | Pentax K1000 35mm SLR Camera
Can't get my lense off!
You can use any mm lens you want as long as it was made to fit the K1000.
Is the lens a Pentax lens ?
Push the lens release button down and turn lens Clock-wise then while holding release button down quickly turn lens counter clock-wise, it should come right off.
If it did not then it must be disassembled to remove the lens.
Oct 31, 2008 | Pentax K1000 35mm SLR Camera
I BOUGHT A PENTAX K10D THAT CAME WITH A VERY NICE AUTO ZOOM LENS. I OWN SEVERAL OLDER PENTAX LENSES THAT I USED ON MY K1000 CAMERA AND I WANT TO USE THEM ON THE K10D. I CANNOT FIGURE OUT THE SETTINGS THAT...
I don't own a K10D, but I do own a K100D which I have successfully used both manual focus & auto-focus lenses from my old Pentax stash!
1) If it is a manual focus lens, you need to turn off Autofocus on the body of your K10D. On my K100D, there is a switch on the side of the lens mount that says [-MF or -AF]. "-MF" is manual focus mode & "-AF" is autofocus mode. Since your lens doesn't have autofocus capability, turn it to the "-MF" mode.
Also . . . When I press "Menu" and go to "Custom Setting", I change two settings . . .
1) I change "Using aperture ring" to "Permitted". This allows you to use manual lenses (M lenses) that do not have an auto(exposure) setting, and also lets you use Auto lenses (A, KA, KA2, FA, etc.) in either the Auto or manual aperture setting modes.
2) I change "Fl with S lens used" so that even with a manual focus lens, although I don't have autofocus capability, my K100D beeps and shows a little red square in the viewfinder when I have successfully focused manually!
The K10D should have the same options.
This should get you up and running!
I have had a load of fun with my old lens on my new digital Pentax!
Take care & Happy Imaging!
Glen
Jul 14, 2008 | Pentax K100D Super Digital SLR Camera
Lens damaged camera dropped camera body damaged pentax k1000
"To get the lens to retract, we tried to do a slight twist over to the left (looking at the camera like your the subject - camera lens is facing you). Sure enough it went back in! But now it has trouble focusing. That's another question now. Darn thing...we'll see what else we can jimmy :-)"
quoted from another solution.
Mar 15, 2008 | Pentax K1000 35mm SLR Camera
Cameras Logo
76 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
