Question about Poulan Garden
My Mod. SM705 trimmer starts w/the choke on but the engine dies as soon as I press on the throttle trigger. What is wrong and how can I fix it?
  • 604 Answers
You need to keep the choke on at least one half till the trimmer warms up. It may take 5 minutes to get to the point where you can take the choke off fully.
Posted on Mar 22, 2011
I have a Ryobi S430 4 stroke Weed Eater Trimmer. How many times do i pump the choke (primer) to start cold?
Page 4 and 14 of the manual. A choke is just a device that reduces air flow to the carburetor by closing a flap. You don't pump it, you just move it to the full choke position. I think you may be confusing the 'primer bulb' which pumps fuel from the tank to the carburetor.
http://lawnandgarden.manualsonline.com/manuals/mfg/ryobi/s430_ry34441.html
To start a cold engine:
? Slowly press the primer bulb 10 times.
NOTE: After the 7th press, fuel should be visible in the primer bulb. If it is not, continue to press the primer until you see fuel in the bulb.
? Set the choke lever to FULL CHOKE position.
? With the throttle trigger at idle, pull the starter handle sharply until the engine attempts to run. Do not pull the starter handle more than 4 times.
? Set the choke lever to HALF CHOKE position.
ryobi s430 4 cycle weed eater manual Google Search
Mar 20, 2018 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Starting procedure
Terry: According to eHow.com:
  • Put on a pair of safety glasses. Remove the fuel cap from the Weed Eater and set it aside. Fill the fuel tank with unleaded gasoline that has been mixed with quality 2-stroke oil in a 40:1 ratio. Replace the fuel cap.
  • Move the Weed Eater to a safe place and lay it flat on the ground. Depress the fuel bulb located beneath the carburetor approximately six times to prime the engine. Press it slowly so that fuel has adequate time to traverse the fuel line.
  • Slide the handlebar-mounted engine "On/Stop" switch to the "On" position. Slide the choke lever beneath the fuel tank to the "Full" position.
  • Depress the "Throttle Lock" lever located beside the engine "On/Stop" switch. Keeping the lever depressed, squeeze the throttle trigger. Release the throttle lock. This sequence holds the trigger in the depressed position, which aids in starting the Weed Eater.
  • Roll the Weed Eater so that it is resting on the engine and the trimmer head shield only. This will allow the spinning trimmer head to avoid contact with the ground. Brace the Weed Eater by holding it to the ground with one hand. Using your other hand, pull the starter rope quickly until the engine begins to run. Do not pull the rope more than a dozen times. If it fails to start by then, squeeze the throttle trigger and continue to pull until the engine starts.
  • Allow the Weed Eater to warm up for about 15 seconds, then slide the choke lever to the "Off" position. Let the trimmer run for another minute without touching the throttle lever. After the Weed Eater has warmed up, squeeze the throttle trigger once to disengage the throttle lock. The trimmer is now operational.
  • Read more : http://www.ehow.com/how_6720315_start-gas-weed-eater.html"
    Jun 08, 2015 | Garden
    Why wont my trimmer take gas after it starts ?
    Open, turn ccw, the high 'H' speed jet screw about .3 of a turn while holding the throttle wide open at the trigger. Engine should increase spread andyou may have to adjust. Failing that and assuming correct oil/gas mix it will likely be carburetion, clogged fuel filter or bad fuel line.
    May 02, 2014 | Husqvarna 128LD 17" Gas Trimmer
    Ryobi CS30 Trimmer starts and runs in full choke and half choke but stumbles and stalls on run. Not up to full rpms when in full choke and half choke....
    You probably need a slight carburetor adjustment. Try to turn the L mixture screw (the one near the bottom of the carburetor on the air filter side, closest to the engine) 1/8 to 1/4 of a turn counterclockwise. These mixture adjustment screws ( L and H) have odd heads on them and conventional tools won't turn them. I use an automotive type plastic wire connector (around 22 gauge) with a ring terminal end which I can hold. Tap the plastic end of the wire terminal connector onto the head of the screw with a small hammer and this will enable you to adjust the L screw. This adjustment will increase you high speed side and possibly allow it to run off choke in a regular manner.
    May 21, 2011 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
    I can't get it started and I"m following directions on side of machine.
    Those direction are not accurate all the time, I usually prime mine 4-6 times. put mine on full choke with the trigger pressed and pull 1 time any more will usually flood it, If you have the choke that kicks off after you press the trigger, put the choke back on to half and pull the cord pressing the trigger, Then pull the cord until it starts without pressing the trigger. As before if you press and hold the trigger during the start it will flood these trimmers..This should start the trimmer. You may have to let the trimmer set for about 15 min if it was flooded.
    Sep 19, 2010 | Troy-Bilt 4-Cycle Curve Shaft Gas String...
    Craftsman 25cc weedwacker (358.791030). Zama carburator (C1U-W19) Just rebuilt carb but did not adjust low speed/high speed screws. Starts on first pull (with choke lever actuated), and after warm up,...
    need to adjust the high sscrew. i do mine in 1/4 turns. start machine, full throttle, adjust the h(high) til it clears up.i would start by turning 1/4 counterclock wise, just remember to keep track, in case it runs worse, the put it back to orig. then try the other way. but i suggest 1/4 turn at a time
    example... think of a clock when turning screw. straight up and down, 12oc, 1/4 turn will be 3oc, another 1/4 will be 6oc, and so on. hope it helps!
    Sep 17, 2010 | Craftsman 25cc Gas Line Trimmer
    Weedeater dies when you open choke
    After you start it and are in the second stage of the choke (half choke ) let it run for awhile until it warms a bit then try openning choke and going to full throttle.
    May 21, 2010 | Poulan 25cc 2-Cycle Gas Powered String...
    Engine starts but dies when I pull throttle trigger
    you need to adjust the high speed needle turn it out in 1/4 increments as you throttle it, low speed may have to come out alittle but do high speed first. I had to answer this as I use to have a pastor john in sturgeon bay, miss him alot.
    Jul 22, 2009 | Ryobi Garden
    Garden Logo
    75 people viewed this question
    Top Poulan Garden Experts
    Jim Parker
    Jim Parker
    Phil Walker
    Phil Walker
    Are you a Poulan Garden Expert? Answer questions, earn points and help others
