Question about Honeywell Heating & Cooling
TH8110U1003 Touch screen thermostats. My problem is I don't have a manual to show me how to operate it. But the big problem I'm dealing with now is when I set a temp. say I set it for 75 and the house temp. is say 75 Well the temp. that I set well chang its self to 73 I don't know why it keeps changing all by it's self.
    Sergeant:
    Novelist:
  • 185 Answers
If your program that you have programed into the stat is set to 73 it will go back to that setting if the stat is in the program mode....... Push the HOLD button on the stat and keep pushing it till it say permanent HOLD right above the buttons on the bottom and then you can set your temp to what you want. Here is a download link for the manual from Honeywell..
http://customer.honeywell.com/techlit/pdf/PackedLit/69-1894EFS.pdf
Posted on Mar 22, 2011
Heating& CA
would think that the thermostat has failed .
Jul 07, 2016 | Honeywell Air Purifiers
Tip
Honeywell th8110u1003
The Honeywell TH8110U1003 thermostat is a universal programmable thermostat that gives you electronic control of 24V AC heating and cooling systems. It also has the capability to be used on 750mV heating systems
One of the best features of this thermostat is it’s big clear backlit display. The current temperature, the set temperature and the date/time of day are displayed at all times. Simply touching the screen also activates the back light feature.
This digital thermostat has a menu programming guide the helps you through the process of setting up your schedule. You are able to select multiple days and customize the thermostat for any kind of unique schedule you may have. This thermostat also let’s you take it off the wall and still be able to program it. This lets you watch TV and program it at the same time.
There are built in backups that will hold the time for you if the power goes out. This t-stat will also update for daylight savings time. There are HOLD features that allow you to modify your program and hold it and then go back to the original.
Change reminders that are built in include the air filter, UV light, humidifier service and of course the batteries of the thermostat. The blower of you furnace can also be programmed to run extra to help increase the air quality in your home.
If you decide you want to know the outdoor temperature you can purchase an additional sensor and then hook it to you thermostat. The outdoor temperature will then be displayed on you thermostat. This feature also gives you the capability of using the sensor to monitor indoor temperatures remotely.
This thermostat will keep you very comfortable as the variation typically in temperature from set point is less than 1 degree F. The thermostat after a period of time learns the characterizes of the way the house or building heats and cools and then adjusts to get the most efficient operation of the heating or cooling system while maintaining a very close temperature tolerance.
By changing a few of the parameters in the thermostat this can be can be configured for either single stage conventional heat/cool systems or any single stage heat pump system.
http://www.fixya.com/support/r3623083-thermostat_wiring_terminal_designations
http://www.fixya.com/support/r3869033-replacing_thermostat
http://www.fixya.com/support/r3894275-manual_honeywell_find_honeywell_manuals
http://www.fixya.com/support/r3892721-programmable_honeywell
on Jan 17, 2010 | Heating & Cooling
My thermostat showing on screen 76F when really room temperature is 70F and I HAVE MEASURED PROPER room sensor resistance OHMS to real room temperature. Why thermostat showing higher temperature and n
Where is the thermostat in relation to the return? Is there air flow or is the air stagnant in the area of the thermostat. Have you placed a thermometer in varios locations where the thermostat is located? Try these locations and see if the thermostat needs to be placed in a location better able to reflect room temperature. Also how long have you lived in the house? If it is a newer home I suggest that you contact the builder or the air conditioner/heater installer to see if they have a schematic of the placement of the thermostats.
Nov 25, 2014 | Honeywell TH8110U1003 VisionPRO 1H/1C...
Honeywell TH8110U1003, No heat reading, only two dashed lines, please help asap!
Sounds like the tstat communicates with a wireless remote sensor on the heating unit. The dashes usually mean there is something blocking/interupting the signal. Maybe another wireless device signal crosses its path.
Apr 24, 2017 | Honeywell Heating & Cooling
How do I install a honeywell thermostat TH8110U1003
* Click Here for the Owners Manual
* Click Here Installation Instructions
Hope this helps to solve it; good luck.
Mar 16, 2011 | Honeywell Heating & Cooling
Honeywell th8110u1003 touch screen frozen working but cant adjust at all
It sounds "locked". Refer to the installation/setup manual that came with the tstat for information on how to lock and unlock the thermostat.
Apr 06, 2010 | Honeywell Programmable Thermostat Heater
How do you reset a honeywell th8110u1003 thermostat honeywell 800 # will not tell me but he said it needed to be reset because off ee code on screen
http://www.pexsupply.com/Honeywell-TH8110U1003-VisionPro-Thermostat-1-Heat-1-Cool-3909000-p YOU MAY FIND THE ANSWER HERE BUT IF NOT YOU CAN FIND IT RESET BUTTON IN THE (FURNACE?) UNIT. THE REASON HONEYWELL WILL NOT GIVE THE INFORMATION IS BECAUSE THIS CONDITION USUALLY MEANS THERE IS A PROBLEM IN THE SYSTEM AND GAS IS NOTHING TO FOOL AROUND WITH. FYI HAVE YOUR IGNITER CHECKED OUT.
Mar 05, 2010 | Honeywell Programmable Thermostat Heater
Screen frozen TH8320U1016 honeywell
I got mine to work! Mine is the th8110u1003 and although the screen seemed to display, it was completely unresponsive to touch. Long story short, there is a flat watch battery behind the screen. Get to that and remove it for 15 seconds and reassemble. It powered right back up!
Jun 29, 2009 | Honeywell Programmable Thermostat Heater
Heating & Cooling Logo
296 people viewed this question
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
vance jones
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
