Question about Refrigerators
"3639534711 kenmore side by side
  • 3,740 Answers
Hi and welcome to FixYa, I am Kelly. I think all you have done is cause what we call a high side thermal overload condition. Unplug the unit for about 20 minutes then plug it back in. What has happened is that the coolant pressure is very high at the moment. The compressor WILL NOT restart with a high coolant pressure. All you will hear is the compressor attempt to start about every 5 minutes give or take 1 minute. Due to the high coolant pressures the compressor rotor is locked by the high pressure and will not rotate. All you need to do is let it stabilize for about 20 minutes and it should work fine again.
If after you unplug it for 20 minutes and restart it the compressor still does not run just respond here and I will help you.
Thanks for choosing FixYa,
Kelly
Posted on Mar 22, 2011
  • Kelly
    Kelly Mar 23, 2011
    I am just doing a follow up. Did this work for you? If it did would you indicate that by responding please. If you still have problems I would like to know that also. Thanks,
    Kelly
Kenmore Elite dishwasher won't clean and leaves white film
CHANCES ARE YOUR WATER TEMP IS TOO COOL and the 2nd
PROBLEM IS VERY HARD WATER THAT IS CAUSING THE WHITE RESIDUE. RAISE THE TEMP ON HOUSEHOLD WATER TO 140 F AND ADD SOME SALT TO THE WASH CYCLE. LASTLY USE A LIQUID DETERGENT LIKE LIQUID CASCADE.
Oct 13, 2012 | Kenmore Dishwashers
Kenmor side by side
possible causes:
dirty coils under the machine freezer side not defrosting door not sealing good weak compressor
Jun 28, 2008 | Kenmore Refrigerators
Our 11 year old side by side Kenmore, Model 896-50692000, was found to be low on freon. Additional freon was added. As a result I'm "gunshy" and bought thermometers to monitor temps in both...
Yes... if you are just seeing the temp. rise intermittently then it is related to the defrosting of the coil... a necessary evil that needs to be done periodically...
As long as the temps. drop again and do not stay up long term... (over 40 minutes) I would not get alarmed...
heatman101
Jul 02, 2011 | Kenmore Side by Side Refrigerator
GSS25KGPJWW side by side; refrigerator running almost constantly and my wife noticed that food in the "Fresh Produce" bin and the "Deli Fresh" bin was freezing. I now have the...
Try shutting the vent between the freezer and the produce bins, the freezer should be colder-down at least to 5 degrees, turn the freezer control to max cold and leave the fridge temp where you put it. the go from there
Jun 24, 2011 | GE Refrigerators
Kenmore refrigerator stop cooling but fan working
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
check defrost timer, defrost heater, defrost thermostat. In most newer models the timer has been replaced by an electronic control board. If the heater and thermostat are ok it’ll be the control.
You can turn the defrost timer till it clicks and everything shuts down. The heater should now come on. If it does, replace the timer. If it doesn't, check the heater and defrost thermostat. Turn the timer again till everything starts back up to end the defrost cycle.
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Apr 06, 2010 | Kenmore 53642 / 53644 Side by Side...
Kenmore Side by side unit has stopped working
turn both dials to 5 and wait for an hour, when it first conmes on they go into a defrost automatically, the defrost controller isa in the upper left hand side of the refrigerator compartment and may be an adaptive technology one that is just a circiuiot board thats about 4 by 4 and behind the area thats betwqeen the back dammper and the front of the unit. It may have fried and that wopiuld explain why your frig does not work.,
Mar 26, 2009 | Kenmore 51572 / 51574 Side by Side...
Kenmore side by side ice maker
in the freezer section where the front of the ice maker is a plastic face plate take that off and adjust the screw under neath it and ur problem can be solved
Dec 02, 2008 | Kenmore 53642 / 53644 Side by Side...
Kenmore Refrigerator stops cooling
You have a defective ( Bad) thermostat that controls the temperature. Have the thermostat replaced.
Jun 26, 2008 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
Refrigerators Logo
73 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Marvin
Marvin
