Question about Samsung Digimax 4010 Digital Camera
When I insert a SanDisk SD card 2GB it tells me there is a card error, is it the card itself?
  • Samsung Master
  • 4,738 Answers
There are several possible causes for "memory card locked", "memory card error", or "no memory card". The most common is trying to use a 4GB or higher SDHC card with an older camera made before SDHC format came out. Other causes include problems with the tiny slide switch on the side of the card, or the electrical contact switch internal to the camera. The problem may also arise from simple formatting problems if the card has never been formatted in the camera (note that this will also erase the card). Troubleshooting tips for this problem may be found at this link.
Posted on Mar 22, 2011
I forget password of sandisk 2gb micro sd memory card
you can unlock your sd card by formatting*.
formatting memory card will delete all datas
formatting method*
use a softtwaer phone for formatting.. (example nokia 6120c, 5800etc )
insert your sd card into the softwaer phone.. select SETTINGS > DATA MGR > MEMORY > OPTIONS > FORMAT MEMORY CARD
Oct 15, 2011 | SanDisk 2GB microSD Memory Card
I inserted my 2gb Sandisk chip into my blackberry curve, it says nedua card can not be accessed due to fatal errors. How do i fix that?
format the memory card with a software phone..
Insert the sd card into software phone(eg nokia 6120c, 5800, 5233 etc)
Select settings > data mgr > memory > options > format memory card..
Sep 23, 2011 | SanDisk 2GB microSD Memory Card
When i insert my sandisk 2gb micro sd card in my laptop, i get the error: This device cannot start. (Code 10)
your Os got some registry errors.
don't worry only go to this site and perform an instant scan.
reggenie.net
this site destroys all of errors from your registry freely.
Jan 08, 2011 | SanDisk 2GB microSD Memory Card
I have a 2GB micro sd card for my blackberry when i put it in. It says media card has inserted contains errors. yo correctthe errors use a disk error-checking utility on a computer. what do i need to do?
if this card working on yours phone then this problem related with window operating system if card have problem with phone then this is relsted with card , formatt this card with phone and restore it by system restore s/w.
Aug 02, 2010 | SanDisk 2GB microSD Memory Card
Is Sandisk Ultra 8 GB SDHC card compatible with a Panasonic Lumix DMC-FZ30GN camera? When inserted in Camera error message check card flashes
No. The DMC-FZ30 was designed to work with SD cards. While SDHC cards will fit into the slot, they do not work. You'll have to use SD cards, 2GB and smaller.
Jul 06, 2010 | SanDisk Cameras
Memory card Sandisk 4GB gives error memory card
The S50 uses SD cards. Your 4GB card is actually an SDHC card, and will not work in the S50. You will have to confine your choices to cards 2GB and smaller.
May 15, 2010 | Pentax Optio S50 Digital Camera
Memory card locked
On your SD card, there is a small tab near the top (similar to floppy a disks), just switch that the other way it should fix that lock error.
Jun 11, 2009 | SanDisk Ultra II 2GB Secure Digital Memory...
Cell but it is not reading the memory card
Check your manual to see if your phone supports 2gb's. It might only support 1gb or less. Hope that helps.
Jan 04, 2009 | SanDisk 2GB microSD Memory Card
Micro SD 2 GB just stopped working
The PIC or EEPROM inside these cards may not be working. I guess you best bet is to buy a new one try Kingston brand or go with another Sandisk.
Jul 02, 2008 | SanDisk 2GB microSD Memory Card
Samsung Digimax 4010 Digital Camera Logo
169 people viewed this question
Top Samsung Cameras Experts
Kazim ERGUNEY
Kazim ERGUNEY
Computer Links
Are you a Samsung Camera Expert? Answer questions, earn points and help others
