Question about Ovens
Re: Westinghouse Wall Oven/Grill .Timer carked! Please advise whether I'owner can replace with instructions or need electrician.Quote cost for replacement Timer ship to Main Beach Queensland 4217. Laurie
  • laurie_mulha Mar 22, 2011
    Model 663. I'm not comfortable in the replacement process---Please advise further Tks
  • laurie_mulha Mar 23, 2011
    Thanks Rick, I have called an electrician who will replace.Apprecviate your prompt help on the options,
  • Ovens Master
  • 12,061 Answers
Hi, well i tell you these units are a pain to get into the area where the wiring hooks onto the module... also there were a few variants, so the timer modules were different, this means one would have to have a service manual of the exact make model to even be able to source the bits, in the first place. This is the BIG problem, obtaining the exact parts.
My recommendation is to save yourself skinned knuckles and time and money, and call an an electrician for that "Quote'.
Posted on Mar 23, 2011
  • Ovens Master
  • 17,970 Answers
If your part keep instructional guide, could make yourself; We assuming that your are talking about Control Board.
Hope helps.
Posted on Mar 22, 2011
  • 1,998 Answers
Hello laurie,
what is the make and model number of your westinghouse oven and grill. So the timer has carked funny lil word havent heard that one before but if you can supply the model number I might be able to find you a schematic for your unit the timer is basicly an unplug said wires and plug same wires the same way you took them off into the new timer. The hard part is getting to the timer are you mechanically inclined to be able to disassemble and put back together the unit with instruction? message me back your reply as well as the model number of your grill and we can start from there Thank you
Rick
p.s do not remove the old timer until you get the new one
  • 1 more comment
  • Rick Ead
    Rick Ead Mar 22, 2011
    ok just want to confirm that this is your unit correct click the link http://www.appliancesonline.com.au/600mm...
    Thanks Rick
  • Rick Ead
    if this is not your unit please recheck the model number it would be a much larger number and would also be found under the upper cover as well as along the door the repair is basicly to shut off the breaker at your electrical box ,pull the entire unit out if you have it inside of a cabinet area. Then you would loosen the screws along the back on the top panel and remove the top panel you would then remove the top panel giveing you access to the timer. You would then replace the timer unplugging the old wires and pluging each in the exact same locations on the new timer there might be a small phillips head screw that holds the timer to the front plant you would need to inspect how the timer is held in place to be able to take the old timer out . If you still feel not confident about doing this repair I would suggest that you call a qualified technician it is always better to be safe then sorry when it comes to electricity Thanks Rick
  • Rick Ead
    Rick Ead Mar 23, 2011
    your welcome could you please remember to rank how helpful my opinions were it allows me to help others in similar situations in the future Thanks again for using Fixya
    Rick
    p.s you would rank by clicking end chat accepting solution and picking how helpful i was this is how we are able to stay helping people by your ranking us you can also at anytime message me back with any further questions on this or any other appliance after you have ranked Thanks again and god bless
    Rick
What are the dimensions of a chef baroness integra gas wall oven
You need the Chef Model number, then click on the model and then on 'More'.
chef integra baroness wall oven 92 60 chef Compare Cheap chef integra...
Chef EXC627W Wall Oven
Compare prices $849.00 Chef EXC627W 60cm electric fan forced wall oven with separate grill and 60 minute timer in white Separate grill 60 minute timer Easy clean formed shelf supports Cooler door temperatures with air cooled door Wall installation Cooling fan Oven size (cm): 60 Oven - internal dimensions (h x w x d) (mm): 376 x 475 x 432 Separate grill - internal dimensions (h x w x d) (mm): 216 x 475 x 432
Specifications Style of Oven
Separate grill/wall
Oven Type Electric
Width 888 mm
Depth 595 mm
Height 573 mm
Or contact them direct
Welcome to Chef
https://www.chefappliances.com.au/Explore Chef's range of products! ... The simple touches that make Chef functional and easy. Fingerprint. Anti-fingerprint. A special stainless steel finish means our ovens stay free of messy prints. Cooktop options. Gas, electric solid or ceramic. image 1. Boils faster than gas? Easy. The Induction cooktop provides modern, ...
Apr 08, 2018 | Ovens
The oven keeps turning its self off
It could be the thermal cutouts operating. First things first, is the cooling fan running and does it turn off about 10 mins after the ovens/grill are turned off? If it isn't running then the unit is overheating and the thermal cutouts will operate. If it is running normally, then the cutout could be switching in early due to them becoming old and ineffective. There are two cutouts in the oven. One controls the main oven and the other controls the top oven. However, the grill operates without the clock being set, i.e. it is independent of the clock. So, if both the top oven and grill stop working together, according to the wiring diagrams in the handbook, the only thing it could be is the thermal cutout for the top unit.
F.Y.I. The top oven switch controls both the grill and the oven elements. In other words, in its OFF position, the Grill works and the Oven doesn't and in its ON setting the Oven works and the Grill doesn't. However, I can't see this failing as you specify, but worth checking if you take the oven to bits. The Grill will only work if the oven door is down.
If you need to replace the cooling fan, you will have to take the whole unit out of the kitchen cupboard to gain access to the top and rear oven panels, which have to be removed to gain access to the cooling fan and wiring. If you do replace it, ensure all the vents for air circulation are free from dirt and grease before you put it all back.
Try espares for STOVES spares. If the item is not listed you can ask them for a quote.
Be aware that the cooling fan is controlled by a timer circuit board and an in-line resistor on the fan terminal block. Either or both of these two and or the fan could have failed if the fan is not running! Any competent electrician should be able to work out what has failed.
All the diagrams are in the Handbook. If you need a copy, supply an email address and I will send you a pdf copy.
If you do ask for a quote, I suggest you ask for prices for all the parts mentioned above, so once you have checked what has failed, you will have enough info on pricing and availability as to whether to proceed or not.
Mar 06, 2011 | Stoves 720EF Electric Double Oven
The oven and grill when in use switch themselves off after a while. They will switch themselves back on after a while.
Jan 18, 2011 | Stoves 720EF Electric Double Oven
STOVES 720ef Oven Programme won't go off automatic
This is a solution - of sorts - but probably not the one that you were hoping for.
My Stoves 720EF oven developed the same fault.
I tried pressing the buttons in various combinations and I tried switching the power off and on, restting the timer and the clock, no joy.
I then tried getting hold of a copy of the manual and trying to fix it, no joy. Called up Stoves and booked a visit from a specialist service engineer, costing £75 +VAT for the call out, and was advised that the engineer would attempt to repair it but it might need a replacement circuit board, costing a further £110 plus VAT.
engineer arrived on the appointed day and was straight onto swapping out the circuit board - not much scope for "attempt to repair" - so that was about £190 plus VAT to fix it. job took about 25 mins and didnt seem to need anything beyond what any electrician (or electrically-expert DIYer) could do.
comes with a 12 month warranty - hopefully it will work without any issues !
If you have a regular electrician you might prefer to buy the board and get your electrician to do the job - or do it yourself, assuming that you are suitably skilled and qualified.
hope this helps
cheers
David
Nov 07, 2008 | Stoves 720EF Electric Double Oven
Westinghouse Freestyle 476 Cooktop Oven
After getting an electrician out, apparently the time needs to be set on the oven. As we're in a rental & don't have a manual/ couldn't download one, we got it to work after holding the first two buttons in (the timer buton + the one that looks like a hot pot) along with the + button at the far right, which made the tim tick on, so it could be set.
The oven works now! : )
Aug 20, 2008 | Ovens
De Dietrich oven not working!
I suspect that it is the oven lock that needs replacing. I bought a De Deitrich oven (pyroclean) in Sept 2007. The oven failed to heat in Aug 2009. The oven lock needed replacing which meant the unit had to be removed from the wall. It was replaced under guarantee but failed again in June 2010 and was replaced at a cost of €140 by enginneer. I am very dissappoined in the oven and expected to have no problems with it considering the DeDeitrich name. I would not recommend it to a friend. By the way the clock is easy to use if you follow the instructions exactly. Oven used by two careful owners only.
Mar 31, 2008 | Ovens
Stoves Newhome GL916
The timer has broken and needs replacing
I had the same problem, we checked all the wires inside and all ok, so phoned stoves and they said that the it sounds like the timer as this is the first port
Replaced the timer and cooker is now working fine - only thing to remember when ordering the timer - my cooker is green and now has a red light instead of green
Hope this helps
Cost of timer from stoves £56.83 inc vat and delivery
Oct 28, 2007 | Ovens
Ovens Logo
91 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
