Question about Psi 2500 Mobile Pressure Washer 5hp Honda Engine
I have a honda 5hp pressure washer.I cleaned the carb and now when starts the gas fills the block!
    Sergeant:
  • 259 Answers
The float needle is not closing all the way and fuel keeps leaking in to the carburetor. Replace the needle and make sure the float is not damaged and that the float pin is clean.
Posted on Mar 22, 2011
Gas leaks out side of pressure washer
Your washer was sitting for a while I suspect. Check the carb and make sure it is tight to the engine. If it is then you will need to take the carb off, careful not to tear any gaskets. Then remove the fuel bowl and clean out all ports. Make sure to clean out the jet as well as I suspect the fuel is clogged in the carb and overfilling. Your needle valve is stuck open and then flooding your carb and spilling out the side of your engine. Make sure your needle valve and float can move freely before reassembling. Good luck
Jul 27, 2014 | Troy-Bilt TROY-BUILT 91215 - TROY-BUILT...
I have a wood splitter that has a honda GCV160 5HP engine, when I choke it to start, it does find, but when I push the choke in, the engine will not run smoothly, it acts like it's not gettingg en
Sounds like debris in the carburettor. The carbs on these are relatively simple things which come apart easily. Check for debris or water in the float-bowl, and ensure both your idle and main jets are clear and you can see daylight through them.
Oct 10, 2012 | Karcher 2500 PSI Pressure Washer
Honda pressure washer 5hp will only run with the choke on. Was running fine for about 1 hour
The problems you describe are usually indicative of a blockage in the fuel system somewhere in the carburator or a damaged gasket that's letting in too much air. With the choke on, the vacuum in the carb goes way up and forces more gas through. Remove the carb and check the gaskets and insulator if it has one. Then check the float bowl for debris and blow out all the passages in the carb.
Sep 16, 2012 | Garden
I have used my Honda Pressure washer 3 times over a period of 1-2 years. I could not get it to start today. I did not drain the old gas but added some new gas (which was probably a few months old). I...
check the oil level in the crankcase if it just spills out the oil fill hole it fine
drain tank and drain float bowl and clean fuel tap make sure the carb is not green and blocked if so give it a good clean out make sure all jets are clean and clear- make sure fuel flow is good and carb connection and @ fuel needle valve / seat
make sure has spark
make sure muffler has no mason bees blocking muffler
give it a try
cheers pauly46
Jan 15, 2011 | Honda Pressure Washer PSI 3000
I have an Excell model XR2600 pressure washer that will not start. I have had it stored for 3 years. I drained the gas tank and carb and put in fresh gas. Is there a fuel shutoff on this model ? It has a...
If it's been sitting for 3 years most likely the carb is gummed up. If it's getting spark, you could try a small shot of starting fluid into the carb. If it runs on this you know it's a fuel problem. Best bet would get all the MOTOR data, and buy a carb kit from you local lawn and garden equipment parts supplier. . Remove carburator and clean and install kit. Use sta-bil when you put it away next time, but even that only works about a year or so.
Jul 05, 2010 | Karcher 2500 PSI Pressure Washer
Won't start
Most likely blocked jets or the fuel switch isn't turned on or blocked. Check the tank to make sure the fuel is clean, new fuel is a good place to start. Then work your way to the carb cleaning as you go.
Great way to spend the weekend, Marshall
May 21, 2010 | Honda 8 HP Engine
I have a excell 2600 honda 5hp gc 160.It has not been used for over a year. I empted the old gas out & put in new gas. It will start but when I push the choke in it shuts off.
A couple of things....
Clean the air filter and make sure it is dry.
Check for any springs that have come off of the linkage.
With compressed air, blow out the carburetor.
Clean and clear out the fuel tube from the tank to the carb housing.
Be sure you have proper oil level.
Out of what you have said...it is something in the carburetor....probably needs a flushing with air.
Give it a try and post back!
Jan 19, 2010 | Honda Pressure Washer PSI 3000
Honda Pressure Washer HP 5 not starting
You can try spraying some carburetor cleaner into the carb. If it starts for a minute, your carburetor need cleaning. When you added new gas did you remove the old gas first? Is the air filter clean?
Jul 18, 2009 | Honda 8 HP Engine
Gas pressure washer will not start
I have a 5hp honda power washer sat for 2 years it will only run if I spray gas in the carb as soon as I stop spraying the engine stops I have took off carb and cleaned it
May 31, 2009 | Karcher 2500 PSI Pressure Washer
% hp Honda Motor runs on choke
Dear LC39B,
Is it possible you are blaming the wrong part of the machine? Did you try the Honda Motor on its own? I am asking , because if the pump of the washer has some fault or a bit jammed, this will demand a lot of power from the Honda. You can try the Honda with no water connection and no gun.
Regarding the Honda motor, you should check the electrical system also. I am saying this because you did not mention it, in your service procedure.
Regards,
MG.
Nov 02, 2008 | Karcher 2500 PSI Pressure Washer
Psi 2500 Mobile Pressure Washer 5hp Honda Engine Logo
341 people viewed this question
Top Psi Tools & Hardware - Others Experts
Marvin
Marvin
Tim Venetis
Mike Squire
Are you a Psi Tool and Hardware - Other Expert? Answer questions, earn points and help others
