Question about Garmin nuvi 200W GPS Receiver
No power I went to turn on my garmin 200 and dead... it will not charge or do anything!
I prayed about it, next day it worked!
Posted on Aug 03, 2008
I battery went dead. I have pluged it into my computer . It lights up and shows a picture of it attached to the computer and the word Garmin but it does not show it chargeing.
Please leave it to charge and after about 2 hours - check it.
The Garmins need an initial charge to run - it is not bypassed if dead. It will not run on adapter power.
If it will not charge in vehicle or home - the jack may be loose from the board - but more likely the battery has failed.
Garmin DOES repair for a flat fee - units that are OUT OF 1 year WARRNATY CLICK HERE.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Jun 27, 2010 | Garmin nuvi 265 Car GPS Receiver
My Nuvi 200 screen went black. I've tried turning
I can help you fix your Garmin Nuvi 200W.
There are three steps to take to get your Nuvi running like new:
  1. Back up your Favorites.
  2. Perform a Hard Reset.
  3. Download and then run Garmin WebUpdater to replace its firmware / system software.
I hope that helps.
___________________
Nuvi 200 series manuals available here.
Oct 28, 2009 | Garmin nuvi 200W GPS Receiver
Gps nuvi 250 wont charge, shuts off in a
It will shut off right away if the batteries are not charged.
Why doesn't it charge?
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} If your GPS unit powers down before it can fully boot up, the battery will need to be charged. Please charge the unit with the vehicle power cable or on a computer for at least three hours. After charging the unit, it should power on and function normally. If the unit will not charge in the vehicle, check the fuse in the power cable for the unit and the power outlet in the vehicle.
The nuvi 200 series, 300 series, 600 series, 700 series, 1000 series and the StreetPilot C300 and C500 series do not have user replaceable batteries. These units must be sent in to a Garmin approved repair facilities if a battery issue arises. Garmin and Raytech are the only Garmin approved repair facilities. Raytech is a repair facility for Canadian customers. To repair your device please contact the specific repair facility for your region. If your device is not still under the 1 year warranty, there will be a cost associated with the repair of your device.
Oct 17, 2009 | Garmin Nuvi 200w 250w 260w 580 660 670 680...
I charged my Garmin 305 and the screen read fully charged. I went to turn it on and there is no power. Now I can't even charge or download anything. It is fully dead.
Attach your unit to your computer and go to garmin.com, download webupdater and then go to my dashboard on garmin and follow the instructions
Oct 04, 2009 | Garmin Edge 305 GPS Receiver
Nuvi 255 dead and why?
Have you tried resetting the GPS,the reset buuton is on the bottom of the GPS under the serial number,
press and hold the reset button for several seconds.
If this fails try rebooting by holding the Power switch on for about 15 seconds.
Sep 21, 2009 | Garmin nuvi 255W GPS Receiver
Garmin Nuvi 200w while charging the battery it started to flash and went dead. It will not respond.
Your Nuvi has suffered the firmware or system software equivalent of a stroke.
I hope that helps.
___________________
Sep 04, 2009 | Garmin nuvi 200W GPS Receiver
Just brought nuvi 200 pink. I might be stupid but it doesnt seem to turn on at all. Even when plugged into charge. is there anything else I need to do?
It must charge for at least 6 to 8 hours before it will work. If you have already done that, then turn on the unit by pushing the power button and holding for a count of 3 to 5 and then releasing
May 08, 2009 | Garmin GPS
Has been working fine..now will not turn on.
It sounds like a dead battery?
When it is plugged into the car, you should see a charging symbol, or it will say charging if the screen is off.
Are you sure it is getting power from the car? Check the fuse for the lighter socket, also the power cord has a fuse in the end that goes into the cigarette lighter socket, if you twist the end of the adapter it should open and expose a fuse.
Check these fuses to be sure.
Hope this helps.
Apr 17, 2009 | Garmin nuvi 200W GPS Receiver
My garmin nuvi 200 worked fine the first 3 times
Connect your GPS to your computer with the USB cable and this will charge the GPS internal battery. Of course your computer will have to be on during the charging process. After a few hours turn on your GPS and see if it now works. If it now works then go to http://www.garmin.com and register the GPS. While you are on line also download the latest USB drivers for your computer and install them. When you reboot your GPS should be properly connected to the computer for Operating system downloads etc.
Apr 07, 2009 | Garmin nuvi 200W GPS
My Garmin c550 will not come on anymore. The screeen is black
Check the 12v power cord to make sure its still powering/charging the unit. Usually they have a light on them that will show if its receiving power or not. You can also unscrew the tip of those things (on most cables) and check the fuse to see if its blown. If its not lighting up and the fuse on the cable is ok check the one in your truck to see if it needs replacing.
If the cable is not the issue then the GPS is probably dead. If its not under warranty the flat rate repair fee from Garmin is $200
http://www8.garmin.com/support/outofwarranty.html
Jan 18, 2009 | Garmin StreetPilot c550 GPS Receiver
Garmin nuvi 200W GPS Receiver Logo
73 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
