I was given an old fisher 885 receiver, eq, and tuner. Dont know where all the wires plug in the back and cant get it to work. Any idea where the red and white input wires plug into where?
    Brigadier General:
  • 8,546 Answers
Do you mean the CA-885?
I couldn't find any free documentation but I did find pictures.
http://forums.audioholics.com/forums/showthread.php?p=227936
With the exception of PHONO, which is literal and for a turntable ONLY, any input will work with any standard analog stereo audio device output.
RCA Red and White connectors are interchangeable but usually consider Red to be the Right Channel and White to be the left Channel.
The two tape loops are for tape decks or external processors like equalizers. OUTs (RECord) go to INs (PlayBack).
Posted on Mar 22, 2011
Fisher equalizer-2322
"Rec" is considered a send (output from Fisher to an external device) and PB (playback) would be an input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
Dec 12, 2013 | Fisher Vintage Ca-880 Integrated Amp...
Fisher equalizer 2322
"Rec" is a send (output from Fisher to an external device) and PB (playback) is a input from external devices in to the Fisher. Remember all outs feed in's, and all in's feed outs...output from Fisher (Rec) IN to EQ. Out of EQ in to Fisher (PB). A quick test is to simply jumper the out to the in and check Fisher for proper operation. Also, in these modes you MUST press the "Tape Monitor" button for the audio signal to be routed through this In/Out loop.
I need manuals for hooking up my fisher stereo system model ca 871 amp fm 871 tuner cr-w890 tape deck eq 867 eq can not find manuals
I can't even find a reliable picture of the amp but it's not rocket science.
The Tuner output goes to, say, FM or Aux on the am, anything BUT Phono, which is ONLY for a turntable.
The EQ output goes to the first available Tape In; Input Comes from the same Tape Out. Select that tape function to engage it in line with any source and the downstream electronics (second tape, tone, volume, speakers).
The tape deck output goes to Tape In; Input comes from Tape Out. If there is not a second tape loop on the amp, nest the Tape Deck into the EQ's Tape loop. They always have at least one to replace the one they use. Select THAT tape function to engage it in line with any source and the downstream electronics.
Mar 13, 2011 | Audio Players & Recorders
I think I have my cables run improperly/no eq when playing tuner
You could tell us how the tuner, cd and eq are connected for a start. I suspect a Tape Monitor or Source/Tape switch is involved, either in the EQ itself or on a receiver if you have one.
Then you could start isolating for bad connections and cables by swapping the (separate???) tuner into wherever the CD is connected.
Jul 16, 2010 | AudioSource EQ200 Home Equalizer
I HAVE A OLDER KENWOOD STACK HOME STEREO SYSTEM WITH OUT MANUALS OR REMOTES AND NEED TO KNOW HOW TO HOOK ALL THE COMPONENTS TOGETHER. KC-206 STEREO CONTROL AMP KT-76 TUNER KX-96W CASSETTE DECK KM-106...
start with the tuner, hook up the equalizer to the tuner, then on the rear of the equilizer hook up all the peripherals except the amps which will go to the tuner outputs and all will feed thru the tuner to the amps and out to the speakers
Oct 23, 2009 | Audio Players & Recorders
Need help connecting my eq to my system.
You will want to connect all of your devices to the pre-amp or receiver, then connect the outputs of your pre-amp/receiver to the inputs of the EQ. Then connect the outputs of the EQ to the inputs on the amplifier or receiver. If you give me some model numbers, I would be able to tell you exactly which cables go where.
Mar 31, 2009 | Audio Players & Recorders
How to connect the FISHER EQ-273 equalizer to the FISHER CA-885
It goes between whatever you are using to create the sound and the input to the amplifier.
e.g. for a standard HiFi.. HiFi aux out to equalizer input... equalizer output to amplifier aux input.
Trying to keep left and right channels the same through out. They are usually colour coded. Red = right Left = white.
Hope that helps.
We all start somewhere
Mar 18, 2009 | Audio Players & Recorders
Cant get equalizer to work with my receiver
This might work fish76, The EQ needs a in & out source to operate correctly? If you have audio device connected to an aux input disconnect that & connect the EQ to that audio device & then plug the EQ to the Sony receiver AUX input. The tape monitor is the most important source for hooking up an EQ device, so you are very limited on a total receiver or amp tonal connection source. The bottom line is you can only use the EQ if another audio source to plug into it & the EQ plugs to your pre-amp input on the back of your rec or amp
Feb 03, 2009 | Sony Audio Players & Recorders
Hooking up an EQ on a Yamaha HTR 5860
Are you nuts? You dont need EQ to this system.This is such a nice syetem,inbuilt EQ gives very good output.Don't try to connect EQ if you are not an engineer.It can be connected with external source
Feb 10, 2007 | Yamaha HTR-5860 Receiver
124 people viewed this question
 Grubhead
Grubhead
