Question about Carrier Freezers
I need a gasket for an older upright freeazer. The model #U212B. Please let me know where I can locate one. Thanks!
  • lynorris Mar 22, 2011
    I still have no answer. The website did not give me any help.
  • lynorris Mar 23, 2011
    Tomorrow, I will try the Carrier phone #. Thanks!
  • 1,998 Answers
Firstly you could go directly to the manufacturer by clicking this link http://www.corp.carrier.com/vgn-ext-templating-carcom/v/index.jsp?vgnextoid=76a61d6b31c08010VgnVCM100000cb890b80RCRD
or if you choose you can go to one of there distributors to find the gasket which that same number on that link they will be able to put you in contact with I would not goto any of the other ones posted on google these tend to be less trustworthy then the actual manufacturer if you have any further questions message me back Thank you
Rick
Posted on Mar 22, 2011
  • 3 more comments
  • Rick Ead
    Rick Ead Mar 22, 2011
    did you call the number and ask to speak to there customer service. by doing this they will be able to either sell you the part directly or put you in touch with one of there distributors. Message me back if you are still unable to obtain the part after you call them or just message me back and let me know how you made out by calling them Thanks Rick
  • Rick Ead
    1.800.CARRIER (1.800.227.7437)
  • Rick Ead
    Awaiting your reply Thank you Rick
  • Rick Ead
    Rick Ead Mar 23, 2011
    ok please message me back with how you made out after you contact them I try to achieve 100% customer satisfaction in all my chats thanks
    Rick
  • Rick Ead
    Rick Ead Mar 24, 2011
    Hello just inquiring how you made out with carrier Thanks again Rick
    p.s I will not be available tuesday to thursday be flying aross the country Thanks Rick
INSTRUCTIONS on Using Vaseline and hairdryer heat to help create a better seal on Kenmore upright manual defrost Freezer gasket??
cleaning the gasket first is a must . warm soapy water .then check the seal gasket with a magnet .before greasing it with vaseline,unless this unit is OLDer than I am it is a magnetic seal but they do split and need replacing .
Oct 17, 2015 | Kenmore Freezers
How do i install a new door gasket/seal on my Frigidaire upright freezer model # LFFH21F7HWA ?
Good Morning Friend,
I understand you want to know how to install a new door gasket on your Frigidaire freezer, model# LFFH21F7HWA. Typically this is not a do it yourself repair, as there are no step by step instruction manuals that will tell you how to do this. I suggest either contacting the manufacturer or your local authorized technician for further assistance. The technician has been trained on your specific appliance, and should be able to replace the new gasket with ease. Hope this is helpful.
-Best Regards-
WP
May 29, 2014 | Frigidaire 20.3 cu. ft. Upright Freezer...
OLDER G&e UPRIGHT FREEZER PLUGGED IN RUNNING BUT
replace the ptc overload/relay on the compressor and it will cool again
Sep 11, 2011 | GE Freezers
We have a frigidaire upright (ffu17m7hwd) which formed a lot of ice and we are in the midst of defrosting and don't want to experience this again. Can you assist please? Had to throw food out due to...
Freezer burn to food is caused by air & moisture in contact with it.
There should be a tight seal by the rubber gasket along all the inside edges of the freezer door. This gasket prevents unwanted hot moisture and hot air from entering the freezer compartment and causing ice build up. You can test the integrity of the rubber gasket seal by seeing how the freezer door will pinch a slip of paper in various spots around the freezer door. If the slip of paper pulls out easily, there is not a good seal at that spot. If that's the case (which I believe it is), the door gasket needs to be replaced. By the way, ice will build up over time because you need to access the food in the freezer, hence you will introduce moist air each time you open the freezer door.
Aug 28, 2011 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Top freezer door opens when bottom door closes
Sorry to read about your problem, I hope this helps you out.
you lower gaskets are getting weak. sorta normal on older models
I tried to help you. Please help me and Rate/Vote on my response, thanks and good luck
Dec 24, 2010 | Frigidaire Freezers
Need a manual for 253-9284215 Kenmore Upright Freezer
The first three number are who made your refrigerator, Gibson (Frigidaire) Below are the model numbers that the user manual falls under, Click Here=> 253.9284215
KENMORE Upright Freezer Model: 25321711103, 216769200, 25321402101, 25321741102, 25329201002, 25321402102, 2539280415, 2539287215, 25321041100, 25321201102, 2539280214, 25321411100, 25321211101, 25321421104, 2539284215, 25320211002, 25321111103, 25321421101 If you have questions please let me know, Thanks, Sea Breeze
Oct 06, 2010 | Freezers
Compressor not running - food starting to thaw - older model 14.6 c/f upright model
dear sir/madam
please check the thermostat setting and make sure this thermostat device is working if it,s good and working then please check the compressor relay device and all electrical connections.
and contact to your service technician , for further maintenance.
hope answer the question
thank you
please vote!
Aug 29, 2010 | Whirlpool 16.7 cu. ft. Upright Freezer...
I have a Whirlpool Model EV 200N Upright Freezer which is having ice freeze on the bottom of the freezer. What can I do?
If there is frost forming at the bottom to the door, your door gasket is leaking at that location. You may be able to relax gasket back in place with hair dryer, be carefull you can melt gasket. If it is sheets of ice, your defrost drain may be frozen
Aug 28, 2010 | Whirlpool 19.6 cu. ft. / 555 liter Upright...
Door gasket for Kenmore upright freezer model 2539239712
Go to sears parts direct website. It's part #3206261 and is in stock, $93.07. Good Luck! countrycurt0
Aug 08, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore upright older freezer coils frost up
the tech was telling you to put it in defrost and if ater the time you didn't hear the click the defrost timer is defective but like you are describing the defrost thermostat (bimetal) could be bad. here's a simple test (if your handy with a screwdriver) just dissasemble the panel and you will see the coil and defrost heater. if your handy with a voltmeter (please disconnect power first!) locate the two wires to the defrost element put the meter in "audible" mode and check for continuity on the defrost heater if you hear a beep it's good if it dosen't beep it's bad just replace heater w/ bimetal and your ready 2 go! email me @ hvac.tech7872pr@gmail if you have any questions
Jun 09, 2008 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Freezers Logo
65 people viewed this question
Top Carrier Freezers Experts
Dennis Boxerman
Dan Webster
Dan Webster
mike cooper
Are you a Carrier Freezer Expert? Answer questions, earn points and help others
