Question about Hilti Drills
I am looking for the trigger switch for a Hilti TE 76 ATC rotary hammer
  • 2,176 Answers
Go to Hilti.com and you can buy direct, they also have a locator so you might be able to find it faster. You can also call them at 1-800-879-8000 for assistance and to place an order. Let me know if you need more assistance.
Posted on Mar 22, 2011
How to reset service light on hilti te 76 atc??
Only factory service can reset certain faults.
Test kit is available to run drill without electronics.
Sep 17, 2012 | Drills
What does the p stand for on a hilti te-76 p atc
That means it has available Hilti's theft protections system. You can purchase a electronic key that when you swipe it over the tool it programs itself to that tool. After the tool is unplugged for 20 minutes after it is programmed it will not run again until you swipe the tool with the key.
Jun 22, 2011 | Hilti Drills
I am trying to find a trigger switch for a Hilti TE72 can you help? thanks colin.
Hilti only sells parts directly...
http://www.us.hilti.com/holus/
heatman101
May 14, 2011 | Hilti TE 7-C 120V Rotary Hammer Drill
How to reset Active Torque Control in the handle of Hilti model TE76P-ATC Rotary Hammer Drill
Active Torque Control (only TE 76-ATC / TE 76P-ATC)
The TE76-ATC / TE 76P-ATC is equipped with the Active
Torque Control system in addition to the mechanical
torque limiting clutch. This system offers additional protection
while drilling by rapid shutdown upon uncontrolled
rotation in the axis of the drill bit, e. g. when the
drill bit jams due to hitting rebar or when the insert tool
is tilted unintentionally.
When the ATC system has become activated, the tool
can be restarted by releasing the control switch and reengaging
it after the the motor has stopped rotating
("click"-sound signals readiness for use).
Always choose a working position in which the electric
tool is free to rotate in a counter-clockwise direction
(as seen by the operator). If this is not possible, the ATC
system cannot react.
Mar 01, 2011 | Hilti Drills
Hi.I am trying to find a triger switch for a Hilti TE72 The switch fitted is a ''MARQUARDT 1264 1601 but any alternative would sufice. Thanks Keith
this is quite an old machine and the switch will no longer be abailable from hilti. However the TE805 has a very similar switch. instead of a trigger switch its a rocker switch, but it is possible to unscrew the top off your old switch and attach it to the new one. the part number is 17904
Mar 29, 2010 | Hilti TE 7-C 120V Rotary Hammer Drill
Parts for my hilti te 76
Call 1-800-879-8000 or go to Hilti.com for a schematic or call for assistance.
Sep 22, 2009 | Hilti Drills
Service light
You can reset the light. What you need to do it remove the handle assembly from body of tool. The contacts will unplug. Then plug the cord in and pull the trigger and sometimes the light will blink, while holding the trigger in the on position unplug the cord. reinstall the handle and the light should go out. Sometimes you have to pull the trigger while plugging cord in but this should work. and then while holding unplug cord.
Sep 21, 2009 | Hilti Drills
Hilti 76 p atc
Hi . The solution offered by rowdy (pull the trigger and hold it until light goes out) will only work on older machines, the newer machines have more complex electronics that need reseting using an optical reader which plugs into a PC , you will also need the Hilti ODA Software. this is not available to the general public. you may have to send it back to hilti for service and reset. this is free if the machine is less than 2 years old.
Jul 02, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Hilti Hammer Drill 76p atc wont spin, has flashing led
Sounds like it needs new brushes. Schematics can be found on hilti.com. tech support - rotary hammers/ combi. Look up model number. Some of the older stuff is obsolete. Should find info there.Please rate me
Apr 01, 2009 | Hilti TE 7-C 120V Rotary Hammer Drill
Drills Logo
343 people viewed this question
Top Hilti Drills Experts
woodzowl307
John Trevino
Are you a Hilti Drill Expert? Answer questions, earn points and help others
