Question about Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine
Super vienna Drips coffee but also leaks about a cupfull of water into the tray dont know where the leak is coming from (out of sight) any Ideas?
  • 515 Answers
If you take out the brewing unit and look in the chassis where the brewing unit was, you will see a hole. Make sure that hole is clean.
Posted on Aug 03, 2008
Leaking Saeco lpus vienna machine
Keep cleaning...make sure that run off spout the leads to the tray is 100% clear. Run water through it (with a sponge for example) to make sure you get all the sludge out. Careful about what sort of coffee you use. I have had bad luck with Illy coffee unfortunately.
Apr 01, 2014 | Saeco Vienna Espresso Machine
Saeco Vienna machine...after brewing a couple of cups of coffee, water leaks from somewhere and comes out underneath the front grilled tray and onto the counter. Can I do the repair with the proper parts?
Depending on your ability to do some technical and minutious manual work, unmounting and remounting the machine is feasable.
Concerning the leaking, what I've seen most is a leak from the seal under the water tank. Any leaks coming form there would occur even though no coffee would be dispensed. (i.e: Idle mode)
If leak is ONLY occurring when brewing cofee, I would check the following:
1- Check if the water inlet on the back of the brew unit is filled with residue (the inlet looks like the end of a smoke pipe)
2-Open the machine, take out the interior, and verify the water tubes coming in and out of the boiler. They both should be sealed with 2 small o-rings. After time, o-ring tend to expand under heat and may start to leak.
Hope this helps
Feb 27, 2011 | Saeco Vienna De Luxe Espresso Machine
Saeco vienna leaking water from bottom of machine
The o-rings of the water tube coming out of the boiler need to be changed. Rubber O-ring tend to expand after extended exposure to heat.
Jan 03, 2011 | Saeco Vienna SuperAutomatica Coffee...
My Saeco Vienna Superautomatica leaks
Check the little chamber under the white plastic valve behind the brew unit, that might be blocked with coffee.
Apr 06, 2010 | Saeco Vienna SuperAutomatica Coffee...
Leaking coffee grounds and water
HI
There should be a small amount of coffee residue and about an oz. of water going into the drip tray. This is the pressure relief process, when the machine finishes the coffee making. If it didn't release the pressure thhis way you could have an explosion of coffee when it cycles back.
Jan 04, 2010 | Saeco Vienna Espresso Machine
Resover leaking
The easy fix for leaking under the machine is check to see if the drain is clogged. Open the front and remove the brew unit. You will see a small hole that will drain the excess into the Plastic tray. Usualy I find Coffee grounds clogging the drain hole. Use Pipe Cleaner , Q-Tip to clear the drain hole. you can also wipe out from the other side with paper towel or Q-tips. once the clog is clear. Flush our with water.
Feb 24, 2009 | Saeco Vienna SuperAutomatica Coffee...
Leaking water
Take out the brewing unit and look in the chassis behind where the brewing unit was, you will see a little hole, put in your finger and make sure the hole is clean.
Have a nice day
/Mirran
Oct 20, 2008 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna De Luxe Espresso is leaking water
It can be the steam valve or the boiler that is leaking.
Aug 05, 2008 | Saeco Vienna De Luxe Espresso Machine
Saeco Vienna leaking
We had this problem and it was overflow from a clog -- check the hole where excess water drains into the drip tray to see if it is full of grounds. Cleaned it out with a twistie tie and flushed w/ water. That stopped the water on our counter!
Oct 16, 2007 | Saeco Vienna SuperAutomatica Coffee...
Saeco Vienna SuperAutomatica Coffee Maker/Espresso Machine Logo
120 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
espressofixr
Level 1 Expert
just-ice
83bj60
Level 1 Expert
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
