Question about Sport & Outdoor - Others
I have a Schwinn 815 treadmill and have misplaced the manual. How can I tell if the distance is in miles or km? I do my warm up walk at 3.5 and then run at 6.0 for 8 minutes and walk for 2 minutes at 4.0. By the end of my 45 min I have usually gone 3.7. I am hoping it is miles! Any ideas?
SOURCE: Ford 2003 Expedition starts then shuts down
The only idea I hbave is for you to buy a OBD II sensor code reader. Know half the time the codes are generic, BUT also if you go buy a Advance auto they will read the code for you for free. And that code is the correct answer to your problem. Just make sure if your truck loses the code when you cut it off, that you don't cut it off when you get to advance auto.
brian_brackett2004@yahoo.com
Posted on Jan 28, 2009
SOURCE: I need an owner's manual for a Denise Austin Trimwalk
how to open the battery compartment.
Posted on Aug 27, 2009
  • 3 Answers
SOURCE: kettler treadmill "silikon wartung"
Hi eirik,
Your treadmill needs lubricating.
Get a an aerosol with silicone lubricant and spray it under the belt & on top of the ground board.
Then turn the belt by hand (treadmill switched off!) until you've lubricated the whole belt.
Next leave the machine running for 5 minutes at 5 KM/H (3 M/H) without any load on it.
That should do the trick.
Posted on Aug 30, 2009
  • 43 Answers
SOURCE: my honda sky scooter runs for about 2/3 miles and
Your automatic choke enrichener is stuck open likely, or the wire controlling it is disconnected.
Posted on Dec 31, 2009
  • 103 Answers
SOURCE: Nordictrack EXP 1000 Treadmill Quits after 10 Minutes
Hello There, Thank you for all the information. It appears as if your walk belt is worn. What is happening is the friction from the bottom of the belt is actually causing the motor to overheat (there is a thermal cutout inside where the 2 blue wires go) When the belt wears the cloth on the underside becomes flattened out causing too much surface area to contact the walk board, thus the extra friction.
To check your walk board you can loosen the adjusting bolts on the rear and while lifting the walk board look underneath. If there is any wear/white areas then you will need to replace the board as well. You will be able to tell by just rubbing your hand across it and check for any places where the black film may be coming off.
Also the only time you really need to replace any of the rollers is when the bearings go bad or the pulley on the front roller separates. The rollers are about a 1% chance of causing this problem.
Good Luck! and great question, Tim
Posted on Feb 21, 2010
How do I fix error 3 on schwinn treadmill
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Feb 25, 2015 | Schwinn 6100/6300 Walking Belt
Schwinn 250 Units setting
replace the batteries by new ones. and clean the contacts batteries very well.
2) adjust the Reed switch, see the diagram, test for open or fulty, clean it, and tight the conector v. well.
However you must to back to the display are small orifice, Use the point o eraser pens, and click the small switch for to change. the Km or miles or vice. versa.
Jan 20, 2013 | Schwinn 250 Recumbent Bike
Does horizon adventure 925t is distance in miles or km ??
Dear ir:
Any treadmill you can RUN in miles or Km whatever you decide.
You can adjust in your menu, or read the instruction manual for adjust. If you do not have any user manual , download for free in www. horizon.com or www. fitness.manualsonline.com give your model and ready.
sincerely. God bless you.
ernesto cuadra
managua,nicaragua. c.a
Apr 04, 2012 | Exercise & Fitness
Is the Welso Cadence 927 Treadmill in miles or Km?
hi, the console can display speed and distance in either kilometers or miles!
step 1/ move the key and hold down the stop button.
step2/ reinsert the key into the console, after you hear a bleep tone release the stop button and an "m" for kilometers or an "e" for english miles will appear in the display. press the speed in-crease button to change the unit of measurement.
step 3/ when you have chosen the miles take the key off and reinsert it. hopefully you should have changed your units to whatever you have chosen.
Nov 08, 2010 | Cadence Weslo 927 Treadmill Walking Belt
How do you adjust the slack on the belt? This is for a 815 model.
If the walking belt slips when walked on, first remove the key and UNPLUG THE POWER CORD. Using the hex key, turn both idler roller bolts clockwise, 1/4 of a turn. When the walking belt is correctly tightened, you should be able to lift each edge of the walking belt 2 to 3 in. off the walking platform. Be careful to keep the walking belt centered.Then, plug in the power cord, insert the key, and carefully walk on the treadmill for a few minutes. Repeat until the walking belt is properly tightened.
May 04, 2010 | Schwinn 820 P Treadmill Silver Service...
I've misplaced my manual for my Free Spirit (Sears Canada) treadmill and can't remember how to change the distance calculator from miles to kilometers. I recall it being very simple to do. Anyone know?
[from my Owner's Manual]...
On MY Free Sprit mdl 309180:
1. Remove the safety tether from the treadmill.
2. Press POWER button and hold.
3. While pressing the POWER button, insert the safety tether.
4. After lights on the LED display go out, release POWER button. You will hear a beep.
5. Press POWER button again. You are now in kilometers per hour.
* Repeat steps 1 - 5 to convert to miles per hour.
* If you are in kilometers per hour mode, you will see a "Si" in the time section when the safety tether is inserted.
* If you are in the miles per hour mode, you will see a "bri" in the time section when the safety tether is inserted.
Hope this helps,
gyro_john in Saskatoon, SK Canada
Jun 29, 2009 | Exercise & Fitness
Reset distance mode in miles/not km
http://www.sportline.com/manuals/345.pdf
to change from km to miles or from miles to km... press and hold the reset button for (at least) 5 seconds (while in the distance mode.) This will reset your already walked info.
Jan 12, 2009 | Sportline 345 Electronic Pedometer
2002 Jeep Grand Cherokee Limited pre form service needs to be erased
Service Interval
When this feature is selected a service interval between 2,000 miles (3,200 km) and 6,000 miles (10 000 km) in 500 mile (800 km) increments may be selected. Pressing the STEP button when in this display will select distances between 2,000 miles (3,200 km) and 6,000 miles (10,000 km) in 500 mile (800 km) increments.
Reset Service Distance (Displays Only if Service Interval was Changed)
When this feature is selected the current accumulated service distance can be reset to the newly selected service interval. Pressing the STEP button when in this display will select "Yes" or "No."
Nov 02, 2008 | 2006 Jeep Grand Cherokee
Sport & Outdoor - Others Logo
98 people viewed this question
Top Sport & Outdoor - Others Experts
Bill Eager
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
