I want to wire a conventional wall mount thermostat to it. getting NO HELP from GE. can it be done? if so, how?
  • Joe A H. Mar 22, 2011
    If it is a regular split system then you should be able to mount a regular thermostat.... You will need to post model # of the system and what type you have. Regular AC with a Furnace or Air Handler or is it a Heat Pump with an air Handler. Or is this a through the wall Heat Pump Unit. They all wire differently. Basic AC and Furnace......R Y G W C (Furnace) hook to R Y G W C (Stat) Y C from furnace hook to two low voltage wires from the AC. So you will have two wires landed on Y & C at the furnace.
  • 46 Answers
Put a line voltage cooling thermostat on the electrical supply wires that feed the air conditioner. Set the air conditioner on high and the line voltage thermostat will cut-off at what ever setting you set it at.
Posted on Mar 22, 2011
  • kipluna Mar 22, 2011
    its a ge. i'm looking for wiring instructions to convert AZ38H15DABM1 window unit to conventional wall mount thermo-stat . my hvac guy has had no luck..
    any thoughts
  • William Erickson Mar 22, 2011
    You don't have to get into the internal wiring of the unit. A line voltage thermostat will interrupt the electricity feeding the unit at whatever setting you choose and turn it on or off. Call your local electrical supply house to see if they have a thermostat to fit your application. I've done a web search and am not sure whether it is 110volts or 230 volts - there are thermostats or either.
GE pss26lgrb defrost mode Freezers
There is a problem with your self defrosting system which has 3 different parts. You need an ohm meter to test 2 of them. The defrost heater and safety thermostat are mounted to the cooling coils in the freezer behind the back wall panel. The safety is a round disk at the coil top with 2 wires coming out of it. When it is cold the reading across the 2 wires should be like a closed switch. The heaters are in a glass tube near the bottom and should read around 20 ohms. If no reading from end to end of the heater it is burned out. The main mother computer board in mounted on the outside back wall under a square cover panel. Any one of these parts will cause a freezer ice build up. The main board is the most expensive average price $150.
Mar 02, 2015 | GE Refrigerators
What thermostat will work for my gas fireplace?modelwh060396b 07/2006 has remote want a wall mount
A search for that model number did not yield any results. A brand name would help.
That said, if your gas fireplace has a milivolt valve with "TH" and "TP/TH" terminals on the side (for hooking up a remote, thermostat, or switch), then you can use a universal wireless wall system.
You can find wireless wall systems for gas fireplaces HERE.
Dec 23, 2012 | Heating & Cooling
Dpsr483ea1ww how to replace thermostat
  • Unplug the dryer's power cord from the wall connection. You will be working around the dryer's wiring, which can be dangerous if the power is connected.
  • 2
    Remove the rear cover of the dryer. Most dryers have four screws, one at each corner. Flathead screwdrivers will work for most models, but some require Phillips-head screwdrivers.
  • 3
    Locate the thermostat. The thermostat is circular or oval with a wire connection on each side. Remove the screws keeping the wires connected to the thermostat. Set them aside--you will be reusing them to install the new thermostat.
  • 4
    Disconnect the thermostat from the wires, then unscrew the thermostat from its mounting bracket. The thermostat will easily pull away from the wires once you have removed the screws. Discard the old thermostat.
  • 5
    Install the new thermostat on the mounting bracket. Be sure to tighten the screw enough to keep it secured. Connect the wiring to the thermostat and reinstall the screws to hold the wiring in place.
Jan 13, 2012 | GE Dryers
I have tried replacing my honeywell twice in the past year. My problem is that I have to push and try and move my thermostat around for the ac to kick on. Once I can get the ac on, it turns off again and I...
Hello, sounds like the problem Is a wiring issue, there might be a loose wire in the wall causing this problem with your thermostat, however usually the wires don't get loose in the wall unless they were spliced. Also, make sure the connections on the thermostat sub base are tight to each terminal and that the thermostat is mounted securely to the wall.
Mar 18, 2011 | Heating & Cooling
How to connect to my Air conditioner AZ28E15DABm1 GE a thermostat model TR400 HC-A SECO?
carefully follow the below steps;
Turn off the circuit breaker that controls the air conditioning system. Turn the thermostat to the "On" position to make sure that all power is cut off and the air conditioner cannot accidentally operate.
Remove the cover of the existing thermostat and remove the colored wires from the terminals. Take out any screws that secure the thermostat to the wall, and remove the thermostat.
Mount the new thermostat on the wall. Feed the wires through the unit, with enough slack to allow you to make the new connections.
Connect the red wire to the thermostat terminal labeled "RH," "RC" or "R." The red wire carries the power from the transformer.
Connect the green wire to the thermostat terminal labeled "G." This controls the relay that controls the fan. Attach the yellow wire to the "Y" terminal of the thermostat. This powers the main control. Connect the white wire to the "W" terminal. This is the heating control wire.
Close the thermostat's cover and turn the breakers back on. Turn the new thermostat to the "On" position to test it and that would be all.
I hope the above helps. If it is not helpful, please let me know so that I may direct you further.....
Good luck.
Feb 25, 2011 | GE Zoneline AZ38H12DAD Split System Air...
What is easy way to replace the thermostate in
Hi, that thermostat should be a wall mount. This heater has only 2 wires and any "Heat only", "millivolt" thermostat will work. Remove the old T-Stat and mount the new one on the wall, only 2 wires and less than a volt so no shock danger, doesn't even matter which wire goes where. Good luck and comment back if you need any help.
Jan 09, 2010 | Cozy Heating & Cooling
My Cozy Wall Heater won't turn off! Even when the thermostat is in the off position it just keeps running. I need to physically turn off the gas supply to get it to stop. When it turn it back on i need to...
If the unit has a wall thermostat, remove one of the wires from the thermostat. If the unit stops it indicates a bad thermostat. If it continues to heat, remove one of the wires coming from the thermostat going to the gas valve inside the heater. If it continues to heat you have a bad gas valve. If the heater shuts off, you have a bad thermostat wire (short).
Oct 20, 2009 | Cozy (W352E) Heater
I need the squematic wiring GE 24" Built-In Gas Oven
I have the same problem -- did you ever get this question answered?
Feb 28, 2009 | GE 24" Built-In Single Gas Wall Oven
GE P7 Wall oven had bad thermostat????
IF YOUR HEATING ELEMENT IS GETTING ORANGE HOT, AND CYCLING, I WOULD SUSPECT THE THERMOSTAT TO BE THE SOURCE OF THE PROBLEM. YOU MAY FIND IT HARD TO FIND ONE THOUGH DUE TO ITS AGE.
Jan 28, 2009 | GE JKP50SH Electric Double Oven
Heating & Cooling Logo
102 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
