Question about General Electric Refrigerators
I have a side by side GE refridgerator and the freezer side works fine but the refridgerator side is warm no air is blowing out of vent. what could be my problem
    President:
  • 2,468 Answers
Your damper door vent is either frozen shut from condensation or the damper door moror is bad or lacks power to operate
Posted on Mar 22, 2011
  • ajusino1984 Mar 22, 2011
    where can this damper and motor be found
GE Profile Refridgerator side warm, freezer ok?
Fridge gets cold air from freezer to cool it. Your freezer is fine but not enough cold air is getting into fridge compartment. U have some dampers or louvers that direct air flow to fridge and if they are not set properly cooling will not be adequate. Check those out.
Sep 19, 2017 | GE Profile CustomStyle PCF23NGT Side by...
Kenmore Refridgerator/Freezer does not work.
check your damper vent door located between the fridge and freezer and make sure its opening up to let cold air into the fridge,also check the evaporator fan motor and make sure its operating to blow the air around the inside of the unit
May 23, 2010 | Kenmore 55612 / 55614 / 5561 / 655619 Side...
The freezer side does not freeze on the top shelf. The refrigerator freezes everything in the bottom but reads 47 degrees and doesn't cool the top shelves. The fan under the fridge runs fine.
Behind the back wall of the freezer about halfway down, probably behind the light bulb (if there is one there) there is a fan. My guess is that the fan isn't working, or is slow. To test, open the freezer door, then hold the door switch closed and listen for the fan.
This fan should be blowing air up the back of the freezer, and send some of the cold air through a vent at the top of the freezer into the fridge. The air then descends through the fridge and reenters the freezer through a vent at the bottom. If the fan is broken, or if the upper vent is somehow blocked or broken, the cold air will enter (rather than exit) the fridge side at the bottom vent. Because cold air tends to descend and warm air rises, the cold air will freeze the stuff at the bottom of the fridge, and the thermostat (at the top of the fridge) will say it is warm.
Dec 04, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Freezer is working fine, but frig is warm,
Look for the return vent near the bottom probably behind the crisper. You'll have to remove it to see the vent. There may be an adjustable flap in to to adjust the meat keeper area. Make sure it's open.
Aug 22, 2009 | Kenmore 53642 / 53644 Side by Side...
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Warm refrigerator compartment
There is a fan that blows the cold air down from the freezer to the fridge compartment. It is usually called a freezer fan. Most of them are behind the plastic lining in the freezer. I just noticed that your fridge is a side by side. I have never wored on a side by side but I imagine there is fan in them as well.
Jul 06, 2009 | GE GSH25KGRWW Side by Side Refrigerator
Freezer side working fine. Refrigerated side very
Sounds like circulation fan for frig is fr worn out.May be able to take of and free up my manually turning and lubricate around shaft with 3 in one oil.
Jun 18, 2009 | Maytag MSD2458G Side by Side Refrigerator
GE TFX22R SIDE BY SIDE
you defrost problem or check condenser fan at the back of refrigerator see if it runs
Apr 07, 2009 | GE Profile 21.6 cu. ft. Side-by-Side...
Refridgerator
Does freezer back wall have ice build up ? if so a defective heater is the most likely problem
Oct 15, 2008 | GE GSS25JEMWW Side by Side
Freezer works but refridgerator warm
you could find ice behind the back panel - worth a check. however the problem is probably ice in the return vent from fridge to freezer and the only way to cure is to switch off and leave for a day with doors open. if im right and you try this, if it re-occurs you may have a problem with the defrost system
Apr 06, 2007 | Kenmore 50522 / 50524 Side by Side...
Refrigerators Logo
209 people viewed this question
Top General Electric Refrigerators Experts
Van Allen II
Van Allen II
Darrell
Day Coker
Are you a General Electric Refrigerator Expert? Answer questions, earn points and help others
