By activating the dryer as usual after about 20 minutes I found water on the floor .... and appeared on the digital display the inscription and 04. I consulted the manual d instructions and reports this error as "water-filled machine too" a this point I checked unloading and exhaust pipe but are free from obstructions ... now What should I do!!-??????? help help help.
  • 51 Answers
Hmm after 20 minutes well you could have smething in the pump take the back off if possible or push it out enough from the wall get behind it with cover off be careful okay turn it on check to see if it does this in the rinse or spin you may have a crack in the pump or a loose hose going to the pump i've seen them come loose over use. you may need a flashlight if it's a loose clamp unplug it before you attempt to fix it okay
Posted on Mar 22, 2011
The dryer is not running full cycle
Hello Joann,
Thier is no model or brand listed in your question but if it has a timer and not a digital display it could be a simple as the dial that shows where the timer is set is broken so ya think your setting it for 40 minutes or what have ya but its actually being set for lets say 20 minutes...check teh dial,if its digital display and time is controlled by the computer let me know the brand and model number and i will think why its happening.
GENE
Nov 06, 2011 | Dryers
Basement flooded and got approx 12 inches of water in bottom of dryer let sit for a week to dry before trying when pushing start button will come on but wont continue running unless you hold button in ...
Sorry to say but you will need to replace the motor. After water gets in you can rarely save the motor no matter how long you let it dry.There is an internal over load inside the motor that is cutting out after 30 seconds and once it cools for 15 or 20 minutes then it resets .Hope you found this information helpful and thank you for using Fix ya.
Jun 24, 2011 | Whirlpool Dryers
How do i set timer
How to program Raindrip R673CT
Download R673CT manual at raindrip
Other models
R683CP
R672CT
Raindrip drip water guide
R673CT
Install 2 AAA batteries to power display
Set current time:
Press TIME and hour digit flashes > Use up-down arrows to set 24 hour clock
Press SET to confirm hour
Use up-down arrows to set minute
Press SET to confirm minute
Use up-down arrows to set day of week
Press SET to confirm day
Program review
Timer can set 16 watering schedules
When programming, look at display:
Notice: PROG for programming mode, #1, start time, run time, SU MO WE for days
Press PROG and display appear just like image above
Use arrows to select 1, 2, 3, 4 through 16 different watering schedules
Programming
Start time hour will flash
Once hour flashes, use arrows to select hour
Minutes will flash
Use arrows to select minute
Press SET to confirm minutes
Run time hours will flash
Use arrows to set run time hours duration (0 to 9 hours)
Run time minutes will flash
Use arrows to set run time minutes
Press Set to confirm
Now #2 shows on display this is about which days the timer will water
Decide 1) every other day, 2) every third day, or 3) watering at will
1) To water every other day:
While 2nd is flashing, press SET and SU TU WE FR will appear in display
2) To water every third day:
While 2nd is flashing, press down-arrow
3rd will start flashing and TU WE SA will display
3) To water at will:
While 2nd is flashing, press down-arrow twice
SU will flash
Press down-arrow to go to MO TU WE etc
Press SET when day you want appear on display
To set another watering program
Scroll back up to "programming" on this page
Press arrows to select programming 1 thru 16
Repeat programming sequence
After programming is set, press clock button and current time will show
Oct 07, 2010 | Raindrip R673CT Digital Water Timer
I have 16.7 upright Frigidaire Ultrafreeze freezer, Model AFFU1766DW3 & SERIAL #WB51720061, manufactured 04/05 that I purchased new 11/05. Water was on the floor next the the freezer but the light on...
Your evaporator coils frost up in normal use and every eight hours or so the entire unit shuts down and the defrost heater comes on to melt the frost. This cycle last about 20 minutes. The melted frost drips into a drain pan and through a drain tube to the drain tray under the freezer/refrigerator where it's evaporated by the condenser fan.
Your drain tube may be stopped up with ice at the upper end because it drains too slow because it's stopped up at the lower end in the evaporator pan under the unit at the floor. It can get dust and mold in it. Once you get the ice out at the top a little pressure with a turkey baster will usually clear it out. Flushing it out with hot water and clorox may help.
Make sure it drains quick enough to prevent refreezing. . The drain should be located below the evaporator coils on the lower back of the freezer.
Oct 24, 2009 | Frigidaire Freezer 16.7 Upright Freezer,...
Electrolux premier eco freezer leaking. Water appearing on the floor. Ice building up inside the freezer.
Oct 11, 2009 | Freezers
Water appearing regularly on the floor and under the salad bin
If I interpret this right you just don't know why the water keep appearing. The temp. doesn't have anything to do with it.
And in case your's is stopped up...
Aug 22, 2009 | Hotpoint RLA50 Refrigerator
Water all in laundry room floor
Did the washer overfill or do did it leak the water out from somewhere? Typically, if the washer is overfilling it is caused by a faulty water level switch. This is a diaphragm like device with a small clear plastic tube attached between the switch and the bottom of the washer's outer tub. As the water level rises, pressure increases on the air in the tube and when it reaches a certain point, it activates the switch to turn off the water and signals the timer to agitate. Look for any obstructions in the tube and the switch can be tested for continuity with a multimeter. No continuity means the switch is defective. Hope this helped and best wishes.
Aug 02, 2009 | Kenmore 98702 Stacked Washer/Dryer
Sharp AR-M237 DISPLAY READS CALL FOR SERVICE CODE H4-20
ussually h4 appears when the heater lamp is busted. but to really be sure just simulate C # C interupt (enter )04 then press start. if problem persist. chect the lamp and if find busted repalced it.
Dec 16, 2008 | Sharp AR-M237 Digital Copier
DRYER NOT WORKING
E10 means theres no water going into the machine.Your machine has a triple water valve the 1 that feeds the dryer has proberly failed. Comes as a comp unit.
Dec 02, 2008 | Zanussi FJS1225W Front Load Washer
TIMEX IRONMAN TRIATHALON DIGITAL WRISTWATCH
ANALOG TIME
Pull CROWN and turn to set HOUR and MINUTE hands. TIME AND DATE A. Press and hold SET. SECONDS digits will flash. B. Press SPLIT/RESET to set SECONDS to zero. C. Press MODE to select HOURS. D. Press SPLIT/RESET to advance hours digits. Go through 12 hours for AM or PM. E. Press MODE to select MINUTES, press SPLIT/RESET to advance. F. Repeat to set MONTH, DATE, DAY, 12- or 24-hour time display. G. Press SET when done. BASIC OPERATIONS Press MODE to cycle through CHRONO, TIMER, and ALARM modes. Press INDIGLO to illuminate watch face. In any mode, press MODE to view time display. Press any button to stop alarm or timer beeps. INDIGLO INDIGLO CHRONOGRAPH A. Press MODE until CHRONO appears. B. Press START/STOP to start. C. Press SPLIT/RESET to record lap time. Display pauses. D. Press MODE to resume display of lap and split time (automatic after 10 seconds). E. Press START/STOP to pause chrono. F. Press START/STOP to resume. G. Press START/STOP to stop. H. When timing is stopped, press SPLIT/RESET repeatedly to recall last eight lap and split times. I. Press and hold SPLIT/RESET to reset chrono. MODE MODE START/ STOP START/ STOP SPLIT/ RESET SPLIT/ RESET SET SET CROWN COUNTDOWN TIMER A. Press MODE until TIMER appears. B. Press SPLIT/RESET to select timer operation (Countdown and Stop; Countdown and Repeat; Countdown and Start chrono). C. Press SET. HOURS digits will flash. Press SPLIT/RESET to advance digits. D. Press MODE to select TENS of MINUTES. Press SPLIT/RESET to advance. E. Repeat to set MINUTES, TENS of SECONDS, and SECONDS. F. Press SET when done. G. Press START/STOP to start timer. H. Press START/STOP to pause, press again to resume. I. When timer is stopped, press SPLIT/RESET to reset timer. Watch will beep when countdown reaches zero. ALARM AND CHIME A. Press MODE until ALARM appears. B. Press SET to select HOURS. Digits will flash. C. Press SPLIT/RESET to advance digits. Go through 12 hours for AM or PM. D. Press MODE to select TENS of MINUTES. E. Press SPLIT/RESET to advance. Repeat for MINUTES. F. Press SET when done. G. Press START/STOP to turn alarm on or off. H. Press SPLIT/RESET to turn chime on or off. When alarm time is reached, watch will beep for 20 seconds, or until any button is pushed. Alarm will repeat every 24 hours until deactivated. INDIGLO® NIGHT-LIGHT WITH NIGHT-MODE® FEATURE A. Press INDIGLO to activate light. Patented (U.S. Patent Numbers 4,527,096 and 4,775,964) electroluminescent technology used in the INDIGLO® night-light illuminates watch face at night and in low light conditions. B. Press and hold INDIGLO for three seconds (beep will sound) to activate or de-activate NIGHT-MODE® feature. C. While in NIGHT-MODE® feature, press any button to illuminate watch face for 3 seconds. Chime on Alarm on If your watch is water-resistant, meter marking or ( ) is indicated. Water-Resistance Depth p.s.i.a.* Water Pressure Below Surface 30m/98ft 60 50m/164ft 86 100m/328ft 160 *pounds per square inch absolute WATER AND SHOCK RESISTANCE WARNING: TO MAINTAIN WATER-RESISTANCE, DO NOT PRESS ANY BUTTONS UNDER WATER. 1. Watch is water-resistant only as long as lens, push buttons and case remain intact. 2. Watch is not a diver watch and should not be used for diving. 3. Rinse watch with fresh water after exposure to salt water. 4. Shock resistance will be indicated on the watch face or caseback. Watches are designed to pass ISO test for shock resistance. However, care whould be taken to avoid damaging crystal.
Oct 27, 2008 | Timex Watches
Washing Machines Logo
12 people viewed this question
Top Washing Machines Experts
Marvin
Marvin
