Question about Baby Gear
It is too low, is going to be too low for me to handle
  • Nicholas Lemarr
    Nicholas Lemarr Mar 22, 2011
    What's the model? Are you asking how to raise it up?
    Scholar:
  • 112 Answers
Hi.. you forgot to put in the product name and manufacturer.. thanks! :)
Posted on Mar 22, 2011
The battery of my Renault Scenic is flat, I need to open the bonnet to fit a new battery. How do I do that
There should be a bonnet release handle in the vehicle low and almost under the dashboard. Pulling that handle is the first step. After pulling that handle if you go to the front of the vehicle then under the bonnet there should be an additional handle to move right or left to completely release the hood.
Oct 12, 2013 | 2003 Renault Renault Scenic 1.6
Front shake when letting go of handle bars
Try a different manufacturers tires. I am not dunlop fan for this reason.
Jul 20, 2013 | 1987 Honda GL 1200 Aspencade Gold Wing
Handle leak
You need to replace the "guts" go to your local hardware store (Lowe's/Home Depot) and go to the plumbing section. They should have replacement parts for your faucet.
Apr 28, 2013 | Plumbing
Danze opulence diverter handle does not work
you have to replace diverter....if its in the tub spout unscrew and go to lowes or plumbing supply and match up style and replace...use pipe dope and screw back on tight...good luck
May 01, 2012 | Danze & Single Handle Tub And Shower...
I have a single handle Danze shower. I can't turn on the water. The handle just turns all the way around.
sounds like handle is not engaged....pull handle...may need allen wrench...after handle is off see if you can turn water on with pliers...should go from right to left...if that works...install handle and tighten with allen wrench....handle should set from off area...see if handle is stripped out or not on proper...if need new handle...pick up at lowes or plumbing supply...good luck
Jan 16, 2011 | Danze & Single Handle Tub And Shower...
I have my jvc rx-778v that always overloads. why is that?
There could be a couple of reasons that its overloading one is make sure that there is no bare wire touching at all.The other thing it could be is the ohms rating over your speakers may be to low for you receiver.Most receiver can handle 8 ohms to 6 ohms there are a few that can handle 4 ohms check your speaker ohms rating then check how low your receiver can handle with out going into overload.
Sep 25, 2010 | JVC RX-778V
Vacuum height won't go on low carpet setting. Dial will go on medium and high, but not low.
Make sure you're not trying to adjust w/ handle in upright locked position because thewre is a cam which raises the vacuum head a little bit when handle is locked in upright position. If this is not the problem, turn vacuum upside down with handle in unlocked position and power cord not plugged in(for safety reasons obviously), unscrew and remove 3 screws that hold belt/beater brush assembly cover in place(2 are in corner near ends of beater brush and 1 is towards motor housing) tilt end of cover with 1 screw up and remove cover(there are 2 tabs at beater brush end of cover). Right above this is the height adjustment assembly with 2 rollers, raise up the assembly gently and using your finger or a bristle bottle brush,etc. make sure there is no debris caught between the height assembly and the hose(you will understand when you see it), if there is no debris you can now see the pattern on the bottom of the height adjustment knob and the lobe that rides on it, just check to make sure nothing is broken and/or missing, hope this helps!!
Dec 29, 2009 | Hoover Vacuums
Levels/Settings
These height adjustments are designed so that they will not adjust when the handle is in the "back" position. This is so they will stay where they are set and not self-adjust while you are vacuuming. To change the setting, you need to return the handle to the upright position and the adjust the setting and the machine will go to that position when the handle is lowered.
Jan 25, 2008 | Hoover Elite Rewind Bagless Upright...
Baby Gear Logo
Top Baby Gear Experts
Jennifer Rock
Jennifer Rock
Douglas Dinnebeil
Douglas Dinnebeil
Are you a Baby Gear Expert? Answer questions, earn points and help others
