Question about Vacuums
Do you happen to have the service manual for the pfaff 118? We corrected the straight stitch timing but can not do the zig zag timing. Can you help?
  • 710 Answers
Http://s2.vsmgroup.com/VSM/Pfaff/pfaffmanual.nsf
This is the webpage where you can download the pfaff 118 .pdf manual.
Handie Andie
Posted on Mar 22, 2011
Cannot use my 1/4 inch foot as the needle is not positioned properly on my elna contessa 410
Set the stitch width to zero or set for straight stitch, as opposed to zig zag or button hole.
Aug 20, 2011 | Vacuums
I have a Tacsew T20U73-1 straight stitch/ zig-zag machine and I am wondering how I go about making my machine go from zig-zag to straight stitch?
There has got to be a selector of some kind on the machine. Usually it will be marked with symbols indicating straight or zig-zag stitch. You may also try varying the width of the stitch. The wider the stitch, the more pronounced the zig-zag effect.
Aug 18, 2011 | Vacuums
Trying to find out what machine my mam had. My dad bought it in 1978 and was told it was the latest model. it had a zig zag function, double needle, button hole and embroidery capability. Do you have any...
hi.
if you go to www.singerco.com hover on customer support, and then click on instruction manuals, it tells you exactly how to identify your machine, and you can also download the instruction manual for the machine in pdf format free of charge at the same time. hope this helps.
Aug 16, 2011 | Singer Vacuums
I am looking for a Manual for a Singer Stylist Zig Zag Model 418 sewing machine. Serial no. is FC693045
http://www.chung-sim.com/singer.zig-zag.html I believe the manual is on this link in a PDF file for you please rate my research and reply Thanks
May 15, 2011 | Vacuums
Setting of the stictches meaning how do i set it to normal straight stitch.
You do not indicate what machine it is. Look for a lever or knob that moves the needle from left to right. With this lever/knob, position the needle in the position where it no longer zig zags. There may be two adjustments, one selects the size of the zig zag and the other selects between straight and zig zag. Check you selection of the lever by turning the hand wheel until you have the setting you want.
HAVING A PROBLEM WITH MACHINE JAMMING UP AROUND BOBBIN AREA WHEN TRYING TO FREEHAND EMBROIDER IT STARTS OFF OK THEN QUICKLY JAMS UP HAVE ADJUSTED THE FOOTPLATE SO THERE ARE NO TEETH
Check your tension first by sewing a wide zig zag stitch. Does the top of the stitch and the bottom look identical? The sides of the stitch should look like a hole where the thread disappears to the other side, with no extra thread from the other side coming through. It also should lie flat and not be puckering in the middle. When it looks identical and no puckering the tension is correct. Use the same type of material and thread you will be using for the embordery. The bottom side of the stitch is effected by the TOP tension. The top side of the stitch by the BOTTOM tension.
Are you stretching the material you're hand embordering with a hoop?
The dog feed needs to be totally down and if your machine has an adjustment the tension on the foot should be lessened too. (not all machines allow for that adjustment).
Last but not least make sure you have the right needle for the job and material.
Jamming up in the bobbin area would most likely be from the top tension being too loose but also make sure the material isn't getting pulled down in by stretching it with an embordery hoop. Do use a presser foot... a wide clear one is best.
Apr 26, 2011 | Vacuums
I bought it from a yard sale, with no instruction book, and i cant get it to sew a strait stich, it sews zig zag only even if i change knob control, I cleaned it oil it, help?
Hello:
You don't say what model this sewing machine is, or how old. Some older machines had cams that created different stitches. (they sort of look like weird little cogs)
Did it sew ok before you clean/oiled it?
Mar 12, 2011 | Vacuums
Dressmaker deluxe pushbutton zig zag mo. swa-2000 looking for a manual
Free manual for 1950 zig zag dress maker sewing machine
Jan 29, 2011 | Vacuums
Sewing machine problem. . . . . .Hello Rick, My machine is an old Bernina 830. The instructions in your blog make sense and should have fixed my problem, but didn't :-( Question: There are 2 pins that...
Yes, from the information I have on your machine the metal disk you refer to is basically a program disk. It operates like the old self playing pianos did with the holes. You stated that the model number is 830. Is that the model number that is written on the machine?
Jan 17, 2011 | Vacuums
Vacuums Logo
187 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
