Question about IBM ThinkPad (22P9163OB) (22P9163-OB) CD-RW/DVD-ROM (Combo) Burner
I was using my IBM T40 without the main power supply connected and went to sleep without switching off the laptop, the battery died and the laptop went dead, I woke up and connected the main power supply and tried switching on the laptop and the screen did not dispaly anything, it simply went dead, i tried charging the battery for an hour but it did not help at all, when I switched on the laptop it beeps more than twice but the sceen is black, no dispaly.
    Sergeant:
  • 296 Answers
It sounds to me like the GPU overheated.
Posted on Mar 22, 2011
How to reset bios password ibm t40
remove main battery ,then internal backup battery,,wait for 15 minutes then reinstall both batteries & power on pc
Mar 21, 2015 | IBM ThinkPad T40 2373 Notebook
Battery of my Acer Aspire 4810T does not work. With the power supply plugged in, the indication of the battery is "85% available (plugged in, not charging). If the power cable is disconnected, the...
There are three possible reasons why your computer is experiencing this power problem. What you need to do is to isolate the component that's causing it.
These are the parts which should be checked:
1. Power supply
2. Battery
3. Motherboard of the laptop.
Here's the procedure that you have to follow:
1.
Remove the battery from the computer.
2. Power the computer up with the power cord only without the battery on it.
3. Check if it works perfectly without any problems even if the battery is out. If it works, then, the battery needs to be replaced. (Note: Batteries are disposable parts. They usually die after 2 years of usage depending on how you use it.)
4.If no go even without the battery on it, check the ac adapter or cord if there's a light lit on the box of the cord. If no lights on it, double check the connection. If connections seem ok but no power, then, replace the power cord.
5. If power cord seem fine, check the hole in the computer where you plug in the cord. What you need to check is if there are any sign of damages. Wiggle the cord and see if there are lights lit in the laptop.
I hope this help.
CARLO
Apr 13, 2011 | IBM ThinkPad T40 2373 Notebook
My ibm laptop, was working great until this morning, the screen started to flicker, then the icons started to dim and completely disappear and then the screen went to a coloured test pattern and finally...
Check the power supply.Hope the notebook receives power from the battery or the Ac adapter.We need to ensure there is no issue with the power supply.boot the notebook to the safe mode.If it boots to the safemode perform a system restore.In case the notebook does not boot to the BIOS,connect to an external monitor.If we still do not get a display,its the video card
Mar 02, 2010 | IBM ThinkPad T40 2373 Notebook
Probleme power ibm thinkpad t40
Check your Battery if it take charge. Then check if ever your laptop start without the battery.
Feb 15, 2010 | IBM ThinkPad T40 2373 Notebook
Laptop does not boot except when on AC, not a battery problem.
estas en lo correcto hazle revisdar el cmos y la ram que cuando estan por dañarse ocasionan alogunos problemas
Aug 24, 2009 | IBM ThinkPad T40 2373 Notebook
THINKPAD Dead!!
There are no fuses in the thinkpad there are power transistors and i would think that the main transistor has blown. If a USB plug was faulty it is possible it shorted out when you connected the canera and blew the transistor. It could be quite expensive to have this repaired, especially considering you can buy a toshiba L300 for about $400.
Aug 16, 2009 | IBM ThinkPad T40 2373 Notebook
T40 intermittently crashes and recovers "from a serious problem"
If you have not upgraded of changed your power supply, you probably should. Also, you could be having troubles with your RAM. Have you try to perharps repair or re-intall window?
Let me know
Apr 13, 2009 | IBM ThinkPad T40 2373 Notebook
IBM LAPTOP T40- NO POWER
I had a T20 with the same problem.  Com to find out it was a bad power supply cord.  Replace the whole thing.  Get one off ebay really cheap.  That should solve your problem.
Mar 02, 2009 | IBM ThinkPad T40 2373 Notebook
I have IBM LAPTOP thinkpad T43 SERIES. it was working tiil yesteraday. Suddenly it turns switch off. I thought its the problem with AC adapter. I bought a new one. It shows it turn it on but its switch...
It's not necessarily hardware related, can you boot into Bios? If you can try to boot info safe mode, that's F8 for most PCs. I would suspect something with your motherboard drivers, then again it could just be your battery. Not all laptops will operate with the battery out, there is some kind of failsafe to prevent overheating in some, because without a battery the power supply can be fried sometimes.
Hope this helps
Dec 04, 2008 | IBM ThinkPad T40 2373 Notebook
My IBM do not turn on.. IBM A21M..
check power ac adapter and batery if the batery is ok or charge do a test to the hard drive and memory ram loock on BIOS
Jan 03, 2008 | IBM ThinkPad A21m 2628 Notebook
IBM ThinkPad (22P9163OB) (22P9163-OB) CD-RW/DVD-ROM (Combo) Burner Logo
60 people viewed this question
Top IBM Computers & Internet Experts
Alun Cox
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
