Question about Husqvarna 24HP 54" Yard Tractor ()
Husqvarna 54 inch mower won't pull itself - Husqvarna 24HP 54" Yard Tractor ()
  • Phil Walker
    Phil Walker Mar 28, 2011
    Are you saying it has no drive at all and is it a hydrostatic drive system?
  • 4 Answers
SOURCE: Husqvarna, GTH2454T Hydrostatic power loss.
If it's like mine the transmission is sealed and cannot be serviced. A local repair shop told me most likely the problem isn't with the transmission but rather the engine pulley is worn. He said if sand or debris gets between the belt and the pulley which has a definite "V" shape to it that it will wear down to a "U" shape. Now mine has a foot clutch on the left side so he had me pull back on the pedal which manually tightens the belt. I did this and it works like a champ. This winter I'll change the pulley.
Posted on Sep 16, 2009
  • 53 Answers
SOURCE: Husqvarna 54 inch rider, fairly new, bought used.
the Rake adjustment is critical on this mower make sure the front to back is within 1/4 inch of each other with front being the lower this adjustment is on the front if its a single rod the bracket that attaches it to steering axle is probably sprung back this happens from running the mower into something with the deck.
Posted on Dec 03, 2009
  • 9 Answers
SOURCE: 2007 Husqvarna Riding mower blade will not engage
Sounds like you electric blade clutch is bad. I just had the same thing happen to my exmark mower. I was cutting grass and the engine just shut down. It would not crank over. Checked the fuses and replaced one blown fuse. The engine wanted to crank over but it was locked up. I looked the engine over and seen that the bearing in the electric clutch seized up causing the clutch to melt.
Posted on Apr 25, 2010
Testimonial: "Thank you! That doesn't sound like an inexpensive solution. We appreciate your help, though."
ftw1952
  • 10319 Answers
SOURCE: My 54" Husqvarna L&G tractor
the internal clutch has gave out. On the Honda brands the clutch plate can be reversed to repair this situation if happening. On yours I have no idea if that will work for I never had one of these apart before
Posted on Apr 30, 2011
kel1guy2002
  • 3740 Answers
SOURCE: Husqvarna CTH180XP rideon lawn mower 42" rear
Hi Sue and welcome to FixYa, I am Kelly. You have been quite lucky to get 7 years out of your battery. Given the age of the battery that is currently installed this is most likely your problem. You have voltage but very little amperage due to thinned out battery plates.... (
Let me know how it goes.
Thanks for choosing FixYa,
Kelly
Posted on Aug 09, 2011
Diagram for 25 horse 54 inch drive belt for husquvarna
PDF]OM, LGT 2554, 96043006100, 2008-12, Ride Mower
www.husqvarna.com/.../HUSO2008_USen_O0802072...
Husqvarna GroupLGT2554. Owner's Manual / 96043006100 / 2008-12. 03002 ..... mower blade drive belts in the Service and Adjustments sec tion of this manual. Verify that the .
Aug 25, 2015 | Garden
Husqvarna manuals online
Here is a link to a manual I found online via google, I believe it is for the model you are looking for!
Husqvarna MZ5424SR CA Operator Manual
Aug 08, 2014 | Husqvarna MZ5424SR 54 inch 24 HP Kawasaki...
54 inch Husqvarna zero turn B & S engine issue-misses at all speeds
do a compression test and check the valve adjustment
May 28, 2012 | Husqvarna Garden
My 54" Poulan Pro riding mower dies when the
battery weak replace or charge, mower has electric clutch which pulls amps from battery
Jun 26, 2011 | Husqvarna 24HP 54" Yard Tractor ()
The mower starts but the blade switch won't conect yth1542xp
Husqvarna uses an electronic clutch to engage the mower deck. When the clutch works itself out of adjustment it will quit working. Sometimes it will blow the 20 fuse and the tractor will continue to run, but the blade won't engage. When you then shut off the tractor it won't crank again until you replace the fuse. When you attempt to engage the blades again, the fuse will blow again.
Follow this link for a detailed description of the adjustment process:
http://www.lawnsite.com/showthread.php?t=164509&highlight=clutch+adjustment
Nick
Apr 22, 2011 | Husqvarna Riding Lawn Mower Yth24v48ls 48...
Husqvarna 54 inch rider, fairly new, bought used. Deck will not fully lower or raise even after levelling per manual. Are 54 in decks more susceptible to this type issue?
Dec 02, 2009 | Husqvarna Lawn Tractor - 54in. Deck, 26...
Husqvarna 24HP 54" Yard Tractor () Logo
147 people viewed this question
Top Husqvarna Garden Experts
Jim Parker
Jim Parker
Phil Walker
Phil Walker
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
