Question about Compaq Computers & Internet
Laptop is not charging.whether charger problem or any other pl.suggest
    President:
  • 3,278 Answers
Hello.
The most common reasons are the battery, power jack and power adapter/cord.
Power off and remove the battery. If the laptop powers on with just the adapter connected, your battery is faulty.
If you move/wiggle the power adapter at the point where it connects to the laptop, and the power goes off and on, the power jack is the problem.
The power jack is inside the laptop and either needs soldering or replacement.
If no change, the power adapter is probably faulty and needs replacement.
Hope this helps.
Posted on Mar 22, 2011
It won't charge and the power and batter light are all blinking
The first steps you could apply are-
1. Check the plug points. Test some other charger on the same plug point. If it's working, then go for the next step.
2. Use an alternate acer aspire 3000 charger. If you have a friend with the same laptop / same charging adaptor, borrow it and see whether the laptop is being charged from that. Or you could go to an electronics shop and see whether they have a spare charger just for checking purposes. If no adapter works, then it's not the adapter's fault, it's the fault of the laptop charging port.
3. To be sure, you could attach your adapter to an extension cable (a spike guard would be suitable. It prevents sudden peaks in current, thereby protecting your laptop from damage) . If it doesn't charge still, it's a fault within the laptop.
To check the charging port within the laptop, you'll have to go to a hardware specialist (assuming that like me, you're not adept at hardware!) . The specialist should guide you properly.
If the laptop is within the warranty period, you could try the service centre. Hope I've helped :)
Dec 18, 2012 | Acer Aspire 3000 Notebook
I have a HP Compaq CQ50-130us notebook. Yesterday I had it on and it just turned itself off after that I tried turning it back on the power button lights up and the cd drive you can hear turn on. But it...
hi aliyoow, i am happy to assist you, Step - 1 did you check whether your laptop is working without battery , just take your battery out and plug your charger in DC jack and check whether your laptop is getting on or not. If it get on mean you have problem with battery.
Step 2 - Use some-other charger of your friends laptop which is same averatec laptop and check whether your laptop getting charge or not. if your laptop get charge mean you have problem with your charger. if you change it , i will start to work again.
Step 3 - take you charger put in some-other laptop find-out it charging that particular laptop or not, if it get charge mean your charger was is good condition you have problem with your DC jack.
Step 4- take your charger put in DC jack on your laptop switch on power and try to move it side wise softly right and left and top and bottom check whether your charger light glow in your laptop , if it get glow at any point mean you have problem with your DC jack so try to change it so that you can able to bring back your laptop normal working mode.
If you have warranty on the laptop you can directly go to showroom and change it , they will help you without cost. if you don't have warranty just check the steps i have mentioned.
Good luck ! if you think your problem solved don't forget to rate
Jan 02, 2011 | Computers & Internet
I want to know whether I can recharge the battery as my camera is not working. If so can you pl instruct me as how I shld go about it Thanks
Yes, the battery is rechargeable. To charge the battery, remove it from the camera, insert it into the supplied charger, and plug the charger into a wall outlet.
Dec 07, 2010 | Polaroid t1031 Digital Camera
Is not charging
check your chargewr whether it is working or not. In the chargers, normally there is a light which turns on when it is inserted in the plug. Secondly when the cable is connected to the laptop there is a bulb for showing the charging which turns on whether the laptop is on or off, if the light is turning on when connected then the charger is ok. Then you need to check your battery.
Sep 18, 2010 | Computers & Internet
Battery is not charging beyond 29%.
You would have to check the voltage from the adapter to verify proper voltage to rule out the power supply. Since the laptop is on and functioning, I would assume that the charger is working fine. Just based on my experience I would say the battery isn't any good, either bad cells, old, or both. Do you know of anyone who has the same battery that you can test?
Also, however unlikely, it may be the charging system itself, which would be a costly motherboard repair.
Jul 21, 2010 | Acer Extensa 4620 Notebook
TOSHIBA SATELLITE A200 BATTERY PROBLEMS
This problem is very common and can be because of any of these reasons-
1-Wrong Charger,in case you are using some other charger ..i mean other than the one which came with your TOSHIBA laptop.
2-The transformer of the charger is releasing more than the rated voltage.
3-The earth terminal (one of 3 terminals of charger pin) is short (not working)..
I would recommend you to get TOSHIBA CHARGER OF SAME MODEL from your friend or go to TOSHIBA STORE and ask them for TOSHIBA (ORIGINAL) and connect it to see whether laptop its charging or not.
If it works then you need to change your charger
and if not,then you need to get the charging circuit repaired.
NEVER USE SOME OTHER CHARGER (OTHER THAN TOSHIBA) IT CAN SHORTEN THE LIFE OF YOUR BATTERY AND CAN EVEN SHORT YOUR CHARGING CIRCUIT.
have a nice time ahead...take care
Jun 25, 2010 | Computers & Internet
MY HP COMPAQ LAPTOP IS NOT CHARGING PL HELP ME
go to near by redington service center .... Acme Plaza,6th Floor,,Andheri-Kurla Road,Andheri East, Mumbai - 022 28395830
Jun 29, 2009 | Computers & Internet
I NEED TO INSTAL WIN XP, BUT ITS NOT SUPPORTING. PL SUGGEST
Your drivers are here, most drivers for this system are loaded by Windows itself.
http://h10025.www1.hp.com/ewfrf/wc/softwareList?os=228&lc=en&dlc=en&cc=us&product=3860108&lang=en
Let me know if there is anything else you need.
Please rate FixYa Experts assistance, whether your rating is good or bad helps The experts immensely.
Thank you for taking the time.
May 26, 2009 | Compaq Presario CQ60-220US PC Laptop
Computers & Internet Logo
16 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
