I have duet whirlpool washer and it reads f 2 and suds what does that mean?
  • 5,081 Answers
F02 error means if the drain time has exceeded more than 8 minutes. After four minutes suds will be displayed on the screen and again after 4 minutes the F02 error code appears.
Check the drain line for any clogs or blocks which hinder the draining procedure..Use of more detergent can even cause this condition..Be sure you are using only 2 tablespoons of HE soap and not more than that.
Check your drain filter also and replace them if needed. Remove the 3 Torx head screws (located left, center, and right) from the front bottom kick panel of the washer. The drain/filter/pump is right in front.
Posted on Mar 22, 2011
S6 mean on my duet washer
1) this means overcurrent by the motor,the controller sense SUD detected. Indicating bad pump, or extra heavy load,excessive detergente, or SUDs. Press STOP/CANCEL for clear the display
God bless you
Jul 18, 2012 | Whirlpool Duet GHW9150P Front Load Washer
What does it mean if you get the SUD when you first start the washer and,no water is in the machine
To much Soap! Suds lock. What that could be from is a suds lock up, you could just try to unplug for 5 min plug back in restart machine and run washer empty clean out.
Another thing you could do is pour 2 cup white vingar run washer will clean out system. This should take care of your problem.
Aug 23, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Machine read sud
SUD means too much soap was used. Run the washer with a few empty loads and no detergent and the SUD should go away.
Dec 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
What does sud mean on the washer?
it means suds, u have either used an unapproved detergent that suds up to much or u used to much soap
Sep 23, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Sud code comes up and stops and just beeps
Are you using HE detergent (for all front load washers ) or regular detergent ? SUD means suds lock from regular detergent .
Jul 12, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washer flashes P 2 and now SUD will not finish cycle
F-2 IS ERROR CODE SUD MEANS NOT USING H E DETERGENT,, REMOVE DEBRIS FROM PUMP AND SHOULD RESOLVES YOUR PROBLEM ,, REMOVE BOTTOM PANEL 3 SCREWS ONCE REMOVE PUMP FILTER RIGHT IN FRONT BE SURE TO HAVE ALOT OF TOWLES READY MACHINE STILL STORES 3 GALLONS OF WATER
Nov 28, 2008 | Whirlpool Duet GHW9150P Front Load Washer
Display panel reads SUDS
The SUDS message relates to overdose of detergent detected during the Wash Cycle. This may signify a bad pump, an extra heavy load, excessive detergent or excessive suds. If too much detergent was used, run the washer through a Rinse/Spin cycle, then a Normal cycle, without adding any detergent. This should clear the unit of the excess detergent. Check the drain hose and make sure it is not plugged or kinked. Good luck!
Oct 28, 2006 | Whirlpool Duet 3.8 cu. ft. Front Load...
Washing Machines Logo
51 people viewed this question
Top Washing Machines Experts
