Question about General Electric 30 in. Profile PP975 Cooktop
I had cooktop on low and it started making noise. The ceramic top pitted in two places. Is it still safe to use. I used a flat skillet.
    Sergeant:
  • 296 Answers
Sounds like there might be a short. If you are adventurous, I would tell you to open the top and look for shorts, otherwise, you will have to replace it because of the fire hazard.
Posted on Mar 22, 2011
My clients ceramic hob has small scratches appear on one of the pan areas it's only a week old how can this happen the pans seemed clean underside .
ceramic tops are not made for sliding pans or skillets on . as on GAS ranges. give them a bottle of cook top cleaning creme
Dec 22, 2015 | Bosch 233331 - GLASS CERAMIC HOB TOP
Ceramic glass hob
One of the things that can cause a glass cooktop to crack and pit is having sugar spill on it while it is hot. You can still use it. Also they are expensive to replace. In some cases a new stove is cheaper.
Mar 13, 2014 | Cooktops
Gas burner won't light unless gas is turned down to the low position.
I've had this happen before,first make sure that the black burner cap is clean underneath and it's making good contact with the aluminium burner,also make sure the igniter is sparking across to the burner, check the ceramic coating around the igniter isn't cracked or the wires shorting out . Good luck.
Feb 20, 2014 | Jenn-Air Cooktops
I have a frigidaire ceramic cooktop. It started making a "popping noise" and there was a burned smell, but the stove was not on. I had to turn off the breaker to stop this.
Either there's ashort in the stove top or the wiring going to the appliance. Sorry but I would have to see it to see exactly how to fix the problem. the top needs to be removed and inspect the wiring to it. Test the top with a voltmeter forshorts.
Oct 16, 2010 | Frigidaire 31 in. GLEC30S8 Electric...
Have a kitchenaid gas cook top with the flat cooking surface in the middle for griddling. But its all dark brown and discolored especially around the back. I cant see to get it clean or get the brown...
A few cycles in the dishwasher may help. Oven cleaner on the surfaces (pre warmed if possible). Please do NOT use anything abrasive (no metal scrubs, no steel wool, etc.). Ceramic surface cleaner (Ceramibright?) can be used safely.
Oct 12, 2009 | Cooktops
CAN YOU USE CAST IRON SKILLETS ON RADIANT GLASS COOK TOPS?
you CAN use the skillet, but not with great results id assume, it holds too much heat, and problaby a bit too rough underneath and would probably scratch the glass top, in a family business for over 20 yrs. now and thats my recomendation, my brother also in the same feild swears his wife uses it with no issues!!!
Dec 30, 2008 | Jenn-Air 30 in. CCE3401 Electric Cooktop
Maytag gemini schott ceran stove top
Sugar spills on a hot surface will 'pit' the glass surface. There is no way to repair. The damage caused to the surface is only cosmetic and will not affect the performance or operation.
Jun 16, 2008 | Cooktops
General Electric 30 in. Profile PP975 Cooktop Logo
176 people viewed this question
Top GE Cooktops Experts
Dan Webster
Dan Webster
Dave Harrison
Are you a GE Cooktop Expert? Answer questions, earn points and help others
