Question about Vivitar Cameras
I have a Vivitar 285HV flash and I'm wondering if the firing voltage is low enough to use with a Canon Rebel Xs digital camera?
  • 2,509 Answers
I know some older vivitars do have trigger volts in excess of 100v. If you have a friend with a voltmeter you can measure yours, but in any event it is not worth the chance of frying your camera, buy a slave and connect the vivitar to that, they aren't that expensive (one which you can use with pre flash is best).Look on Amazon or ebay for examples (flash trigger slave etc.)
regards
Posted on Mar 22, 2011
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Vivitar Master
  • 102,366 Answers
According to Vivitar, the 285HV has a trigger voltage of 12V, which should be safe for use with modern digital cameras.
Will it work with my canon rebel xs
You must make sure that the voltage of the flash gun is not too great for the camera if it is then you may damage your camera electrics. Test it using radio triggers off camera.
Dec 18, 2015 | Vivitar Auto Thyristor 2600 Flash Unit 4...
Auto flash does not pop up on 7D
Does the flash fire? If it fires when closed then it is a mechanical issue with the release mechanism. Probably got something jamming the release. Unfortunately this requires opening the camera. Best to consult your nearest canon dealer if your not confident enough to try yourself.
Jan 05, 2014 | Canon EOS Digital Rebel XS / 1000D IS...
Vivitar 3500 flash
Not recommended. Older flashes have the full voltage across the hot shoe contact. If that voltage touches one of the dedicated contacts in the hot shoe it will damage the circuit of the camera. 300+ volts does major damage to 6 volt circuits!
To test the flash, measure the voltage between the hot shoe contact and the metal contact on the side of the hot shoe. If the flash is fully charged and you measure 300 volts then the flash should not be used.
Later flashes put a low voltage circuit with a transistor switch in its place to protect cameras.
Oct 13, 2013 | Canon Cameras
Can I use the vivitar 285HV flash for a canon S5 IS?
The 285HV should be safe with modern digital camera. Its trigger voltage is specified as 12V max.
Feb 21, 2012 | Canon PowerShot S5 IS Digital Camera
My canon rebei xs will not work at night,when it is too dark it will not take pictures, like the flash will not work or fire. WHY
use the manual mode or aperture priority. or use automode. if still not working reset the camera to default
Oct 23, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
When using Canon Rebel XS sometimes it takes several seconds before I can take another shot. it reads busy. What can i do to correct this. I am losing perfect picture opportunities
This can depend on the picture quality you have selected, try using JPEG only, no RAW. If this is still not fast enough, you can try a faster SD card, going up to a SDHC Class 6. The Canon XS is a low-end of the EOS Digital Rebel and the slowest, if speed is absolutely required past JPEG only and a Class 6 SDHC, your only hope is upgrading to a faster Rebel.
Jun 20, 2010 | Canon EOS Digital Rebel XS / 1000D IS...
Older Vivitar Flash for new Canon SX10
Not compatible.
Get slave triggers and use them as remote flashes, or buy another film camera.
It seems Vivitar no longer is in the flash business. Get a Sigma or Sunpak digital flash for your SX10
Aug 28, 2009 | Vivitar 285HV Flash
Vivitar 2000 with canon xs
Trigger voltage doesn't have anything to do with the power source. Even though you're only giving it 6V (4 1.5V batteries), it ramps it up internally for the photo tube.
Old cameras used a mechanical switch to fire the flash, so the voltage didn't matter.
New cameras, like your XT, have an electronic switch and eventually will burn out, like Anonymous said. They want 6V at the hotshoe. You're giving it 56V... I know it works now, but it'll fry it eventually. You can get a hotshoe adapter that will isolate the voltage from the camera.
Dec 25, 2008 | Vivitar 2000 Flash
Can I use my Vivitar 385 with my Pentax K200?
Yes, you can use the flash if your camera has a PC connector.
Or, check the trigger voltage: under 7VDC = OK on hotshoe.
atlee@netzero.com
Oct 31, 2008 | Vivitar 285HV Flash
Will a Vivitar 285HV fry my Canon EOS 40D? I'd like to experiment with a Vivitar 285HV as an on-camera hot shoe flash. However, I'm reluctant to proceed because of conflicting reports about voltage...
Personally, I would not try it. While the Canon has a protection system built into the camera, the trigger voltage on the Vivitar is pretty high. I have had good results using a 283 on a slave shoe, you will have to stop down more with the extra light
Jan 08, 2008 | Vivitar 285HV Flash
Cameras Logo
63 people viewed this question
Top Vivitar Cameras Experts
Steve
Are you a Vivitar Camera Expert? Answer questions, earn points and help others
