Question about Kyocera Office Equipment & Supplies
Installed new yellow toner and it say toner container improperly installed
romsky79
  • 822 Answers
SOURCE: Toner low we installed new toner. then message
remove plastic cover from toner yellow or any color and install toner properly.
Posted on Jun 04, 2009
  • 214 Answers
SOURCE: Toner Not Installed - After replace black
pleas clean toner chip reader, remove pc drum and all toners, under the toner rack there is a 3 pin chip reader, use pressure air to clean it. if the new BK toner is not original, it will say only not genuine toner but will print.
Posted on Jul 01, 2008
SOURCE: replace waste toner container message
I have a CLX-2160N and have just emptied my own waste toner container. (Disclaimer: not sure how toxic or environmentally friendly this is).
Emptied carefully and thoroughly (fine dust). Immersed in bowl of warm soapy water, and vigorous shaking to get nice and clean.
Shook all water out well, and dried off as much as possible. Reinstalled. Turned printer back on. Hey presto - seems happy.
Posted on Apr 17, 2009
JackHeath
  • 1049 Answers
SOURCE: I just installed a new toner cartridge. I now get
Are you sure that you removed the plastic strip that is used to ship the toner? If so unseat and re-seat the cartridge, and make sure that your installing a compatible cartridge.
Posted on Oct 06, 2009
iron_luiggi
  • 91 Answers
SOURCE: Red prints a faded orange to yellow even though
imagen.jpg?w=399&h=138Well look this picture, (the children) are exactly the same, printed with the same cartridges are just in different printers. The right has all its correct tones, and the left is pale, clear, as if he lacked the magenta hue.
Mirror dirty laser scanner
The laser mirrors get dirty due to many things, the main blame lies about hp, and who had no rubber gaskets to "optical box" as it says, and the dust that comes in, causing us to blow a printer or same internal fan of the printer is stored in the bottom of the printer to finish the last piece together the laser mirror is the magenta, and that's why when the printer form the mirror image and transfer it to go faulty because the mirror does not project well in the dust which is on the surface. Thus forming the image pale color and lack of final results.
What should we do?
Clean mirrors, p ut to reach them we must completely disarm the printer, which is why I will leave some links to download the manuals.
1) Service Manual Printer hp2600n (English), just for reference but also helps explains how to get to certain parts of the printer, and tell us where are all the sprig, I recommend first ojearlo
I downloaded here: http://cid-4c0169bf00ee97eb.skydrive.live.com/browse.aspx/Manual% 20of% 20servicio% 20Hp2600n? Uc = 1
Now lower the compressed file that says "LaserJet 2600n Series
2) Manual cleaning of the laser (translated into Spanish), I was compiling info from www.hp.com www.fixya.com and forums, there are people who have disarmed the printer, and good will compile this information and there is a detailed manual with photos and 23 steps, and also gives details of the tools to use.
Click Here http://cid-4c0169bf00ee97eb.skydrive.live.com/browse.aspx/Manual% 20of% 20servicio% 20Hp2600n? Uc = 1
Now lower the word document that says "dismantling the printer to clean the laser"
Posted on Mar 29, 2010
How do i clear f2-73 after using program 88-6 how can i revers it back to normal
F2-73 refers to an improper yellow toner cartridge detected in your machine. The fault usually lies with the small chip installed on the rear of the toner cartridge.
The first thing to try is turning the machine off & then back on using the main switch inside the front door. The switch is located in the bottom left corner.
If that fails then you will have to replace the yellow toner cartridge.
If after replacing the cartridge, the error code re-occurs then you may have a toner motor supply problem. In my experience, replacing the relevant toner cartridge resolves the error code.
Hope this helps.
Dave.
Mar 07, 2016 | Sharp Office Equipment & Supplies
Not installed toner check Y error message
replace the yellow toner container with OEM NOT THIRD PARTY
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jan 27, 2016 | Konica Minolta Magicolor 4690 MF Laser...
Get message " toner container is improperly installed."
Hi - What have you tried?
Process to check - simple but worth going back to basics
1 - Remove toner and reseat
2 - check you have removed all transport tags stickers etc
3 - Chck all arrears where a sensor could be blocked
4 - try a 2nd new toner (1st may be faulty)
4 - if there is a waste bottle or OPC drum attached to the toner itself ensure it is seated properly and fully locked into place
if none of the ablve work consult a printer repair or IT company
Jun 24, 2014 | Kyocera FS-C2126MFP Printer
I have just replaced my imaging unit - now it wants me to replace/install waste toner bin
When the life span of the waste toner container has expired or it's full, the smart panel program window appears on the computer, indicating the waste toner container needs to be replaced. Otherwise your machine stops printing.
To replace it follow these instructions:
-Turn the machine off, then wait a few minutes for the machine to cool.
-Using the handle, completely open the front cover.
-Pull the waste toner container out of the machine using its handle.
-Remove the container's cap from the container, and use it to close the waste toner container opening. Do not tilt or turn over the container.
-Take a new waste toner container out of its package.
-Insert the new container into position and then push it to make sure that it is firmly seated in place.
-Close the front cover firmly. If the front cover is not completely closed, the machine will not operate. -Please make sure all toner cartridges are installed properly. If any toner cartridge is installed improperly, the front cover do not close.
-Turn the machine on.
Dec 17, 2010 | Samsung CLX-3175FN Printer
Code F2:72
F2:72 is for Toner cartridge improper cartridge detection (MAGENTA).
Check and see if the right toner cartridge is installed. If it is the proper cartridge I would suggest placing a service call.
Oct 12, 2010 | Sharp MX-2700N Color Copier
Hl 5240 i installed new toner cartridge still status is solid red toner is solid yellow
The new toner cartridge is not properly installed. Remove the toner cartridge and reinstall it.
Download and read the service manual
http://ekse.pp.fi/Fixya/sm/BROTHER%20HL-5240,%20HL-5240L,%20HL-5250DN,%20HL-5270DN,%20HL-5280DW%20Service%20Manual.pdf
Page 3-2 to 3-6 has the instructions on how to properly install the toner cartridge.
The page numbers are 63 TO 67 if you look at the page counter.
Oct 08, 2009 | Computers & Internet
Xerox Model 2515 Will not clear Toner Empty Stop Error
I had one today with a toner low light with new toner installed. Turns out they broke the green cartridge retainer clip.
The toner sensor pn# 130K45680 btw.
let us know if it was the sensor.
Aug 03, 2009 | Xerox Office Equipment & Supplies
Jun 04, 2009 | Brother MFC-8460N All-In-One Printer
HP 2550L low yellow toner -- can i still print just black???
Unfortunately if one colour is out, then you cant print. These cartridges contain a chip and once depleted will not print until a new cartridges is installed
Dec 12, 2008 | HP LaserJet 2550L Printer
1,682 people viewed this question
Top Kyocera Office Equipment & Supplies Experts
Kyocera HP Expert
Chris Schutte
Are you a Kyocera Office Equipment and Supply Expert? Answer questions, earn points and help others
